And pilots are supposed to anticipate that and control the
airplane at all times, pushing on the elevator as the power is applied and getting aggressive with the trim. Done correctly, a passenger would never know anything "special" was happening. Similarly, an engine failure in a light twin should have almost no visible yaw because the pilot will be on the rudder with 150 pounds of push and the nose won't hardly move. -- James H. Macklin ATP,CFI,A&P snip | On 23 Jul 2006 12:57:53 -0700, "minoad" wrote: |snip | | The strange thing that I noticed is this. While on my first flight | today I expiereinced significant 'Fear' while in a climb of almost 50 | degrees. This was my mistake as I had tried to trim before using the | yoke and had trimmed the wrong direction. My instructor smiled at me | and simply asked me to fix it. | | Some aircraft are very good at popping the nose way up there on a | go-around or balked landing and it becomes instinctual to push the | nose back down, but again I'm assuming you had never felt the | sensation of feeling the pull up from excessive nose high trim. I'd | guess you are currently at the stage where you recognize a problem, | think of the proper correction, and then make the control inputs to | get the desired correction. | snip |
Soldiers Fear the Needle - The Pentagon still fights for its anthrax vaccine | Roman Bystrianyk | Naval Aviation | 0 | March 23rd 05 11:58 PM |
Fear of Sanding | Stuart Grant | Soaring | 7 | January 17th 05 05:28 PM |
Fear of Flying | Frequent Flyer | Piloting | 0 | October 15th 04 05:30 AM |
Bush prematurely left his Texas National Guard unit because nerves, fear and a possible drinking problem? | Larry Dighera | Piloting | 10 | October 4th 04 01:29 PM |
Living In Fear Abroad - Welcome to Bush & Blair's More Dangerous World | Matt Wiser | Military Aviation | 1 | March 18th 04 06:41 PM |
