How many pilots are using technology
Old July 27th 06, 11:19 AM posted to rec.aviation.piloting
Matt Whiting
Default How many pilots are using technology
Roger wrote:
I've always been an "Early Adopter" when I could afford it and my
degree and profession are in computer science. Having said that I use
a portable GPS and even fly IFR using it. I also have RNAV in the
panel. The rest of the stuff is "gadgets" to me. If I can bring the
charts up on the panel (moving map display and approach charts) that
is fine, but costs too much and I'd not abandon paper charts for VFR,
Enroute, or approach. The GPS makes flying much easier. Having the
approach charts on GPS is even finer, but again I'd never give up the
paper as its batteries never die although they do fly out the door
seal once in a while.
Your batteries fly out the door seal? You must have that new really,
really thin battery technology! :-)
Matt
  #32
Old July 27th 06, 11:21 AM posted to rec.aviation.piloting
Matt Whiting
Chris W wrote:
Private wrote:
It is an old joke, but the answer is that; 'we will see the paper-less
cockpit (and office) the same day we have a paper-less bathroom.'
ISTM that computer usage has resulted in more paper and not less.
While it is true that computers have resulted in more, not less, paper
being used, a paper-less office is very possible (depending on the
business). One of the reasons computers initially generated more paper,
is because of the larger amount of data they could provide, and the fact
that few had the computers on their desk. Not to mention that the
monitors were small and very low resolution. Today a paper-less office
is not hard to achieve with a little effort. However, I wouldn't even
consider having a paper-less cockpit. I also wouldn't want a
computer-less cockpit either though.
True, but paper is still the most reliable form of long-term storage.
Every electronic or optical medium developed thus far deteriorates with
age at a much faster rate than does paper.
Matt
  #33
Old July 27th 06, 02:20 PM posted to rec.aviation.piloting
Gig 601XL Builder
"Newps" wrote in message
... A computer can display a page as nice as paper but it may take
longer to access the information.
No it cannot.
Yes it can.
http://www.arinc.com/news/2006/07-23-06.html
If that is using the technology I think it is it is really kind of neat. It
uses almost no battery power except when it redraws the page.
  #34
Old July 27th 06, 03:15 PM posted to rec.aviation.piloting
Jose[_1_]
Every electronic or optical medium developed thus far deteriorates with age at a much faster rate than does paper.
.... and the most important "aging" effects is from the software. I have
plenty of documents I can no longer read because the software is
incompatible with today's versions, and the old software is incompatible
with today's hardware, and the old hardware no longer works.
Jose
  #35
Old July 27th 06, 04:30 PM posted to rec.aviation.piloting
Andrew Gideon
It uses almost no battery power except when it redraws the page.
One of the stated advantages is:
Based on new “persistent display” technology, the screen requires
very little power and no backlighting. The display can run during long
hours of flight over several days on a single charge.
That's pretty impressive. At least during an approach (ie. no chart
changing), one isn't likely to lose the plate due to a power failure.
I also liked:
The “electronic paper” screen also captures and stores handwritten
notes from pilots using the stylus.
which is another common difference between paper and computer displays.
- Andrew
  #36
Old July 27th 06, 05:00 PM posted to rec.aviation.piloting
Dylan Smith
If the documents are underneat not encrypted, and not in any weird
character set, it is possible to recover them without too much
difficulty (although the formatting will be gone).
I suspect non-proprietary formats though (such as jpg or png for images)
will have a much longer shelf life than proprietary document formats.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
  #37
Old July 27th 06, 05:47 PM posted to rec.aviation.piloting
Jose[_1_]
Yes, I've managed to extract the text of the ones I need, however, there
are text fragments scattered throughout, which may be updates ("quick
saves"), to the solid text parts, which would be older versions.
Jose
  #38
Old July 28th 06, 03:03 AM posted to rec.aviation.piloting
Roger[_4_]
On Thu, 27 Jul 2006 10:19:44 GMT, Matt Whiting
Yah ever take a look at the gap under a Cherokee 180's door without
the rubber seal?:-))
But yes, the batteries in the paper charts are really thin and never
go dead. Unfortunately they don't handle water well.
www.rogerhalstead.com
Matt
  #39
Old July 28th 06, 04:58 AM posted to rec.aviation.piloting
John Galban
It can happen with a door seal too. The door hardware gets old and
bent and the gaps can be there even with a seal. I'm planning on
redoing my hardware and rehanging the door because I found a gap at the
bottom of the door that I didn't know was there.
I was on the first test flight with my new engine and my IA handed me
the break-in instructions just before takeoff for a 45 min. orbit over
the field. Once I got to altitude, I grabbed the sheet and laid it on
the passenger seat for reference. 2 seconds later, right before my
eyes, the sheet vanished without a sound. Apparently, I had a gap on
the bottom side of the door. Fortunately, I'd already memorized the
instructions.
I was just hoping that the sheet didn't float down and land in front
of my IA. He might have taken it personally :-))
Flying site : http://www.johngalban.com/
  #40
Old July 28th 06, 10:09 PM posted to rec.aviation.piloting
Roger[_4_]
On 27 Jul 2006 20:58:17 -0700, "John Galban"
Many years ago I was on a cross country in a Cherokee 180 about 100
miles from home. I had just checked the ATIS frequency on the chart,
laid the chart on the passenger seat and was setting in the frequency.
I saw movement, I grabbed, heard a loud snap and found I was still
holding the corner (bout a 6" piece) of what had been a new chart.
That whole opened chart shot out under that door like a flash.
It's almost impossible to get lost in Lower Michigan due to the
geography unless you are flying really low, but there are gunnery and
bombing ranges it'd be a good idea to avoid.:-)) Living here, I know
where they are.
instructions.
Bob Barbanes repost 5: " Neophyte questions " [email protected] Rotorcraft 0 February 26th 06 03:01 AM
Here we go again Roger Piloting 39 April 7th 05 07:20 AM
FAA Mandatory Pilot Retirement Rule Challenged Larry Dighera Piloting 0 March 20th 05 08:56 PM
Disruptive Technology Steelgtr62 Home Built 13 October 24th 04 07:32 PM
