Earlier, Bob Gibbons wrote:
The sleeve wall thickness is just too thin for robust use. That may well be so. However, consider that the part may have been engineered (or at least developed) that way so as to protect the fin socket. I'd rather replace the frangible aluminum probe plug than cut open the fin and replace the probe socket any day! I've got a lathe, and making a replacement aluminum plug was my very first thought. I try to buy as few glider parts as possible, and when I do I try to buy as many at a time as I can to get volume discouts. But if Tim has a thing like that in stock, he'd be my first call. Business is definitely business. Bob K. |
![]() "Bob Kuykendall" wrote in message ups.com... Earlier, Bob Gibbons wrote: The sleeve wall thickness is just too thin for robust use. That may well be so. However, consider that the part may have been engineered (or at least developed) that way so as to protect the fin socket. I'd rather replace the frangible aluminum probe plug than cut open the fin and replace the probe socket any day! I've got a lathe, and making a replacement aluminum plug was my very first thought. I try to buy as few glider parts as possible, and when I do I try to buy as many at a time as I can to get volume discouts. But if Tim has a thing like that in stock, he'd be my first call. Business is definitely business. Bob K. Bob, I'm sure the O-ring groove was not intended as a 'breakaway' point to protect the fin socket. The O-ring seats far enough into the socket that something else would give first - probably the carbon fiber tube part of the probe. Bill Daniels |
JPI EGT probe failure typical signs | Robert M. Gary | Owning | 5 | March 3rd 06 11:29 PM |
CHT probe + resistor installed (final) | Jim Burns | Owning | 8 | September 10th 05 02:34 PM |
T.E. Probe Question | KP | Soaring | 2 | July 27th 05 02:58 PM |
Cleaning a 3-way TE probe | Jack Glendening | Soaring | 37 | November 5th 03 06:45 PM |
Broken line to Oil Temperature Probe, Repairable? | rkane33 | Owning | 2 | July 25th 03 03:19 AM |
