"Jose" wrote in message
. com... I wonder how one can legally practice engine-out procedures (trim for best glide, find a suitable field...) since part of the practice is to see if one can actually =make= the field one has picked out by using the procedures one is practicing. FYI... As it happens, I just flew with an instructor yesterday, doing my BFR. During our ground discussion, he told me that he was involved in an incident in which the FAA cited him for violating the minimum safe altitude regulations. In his case, he was not doing engine-out practicing, but that did come up, and here's what the local FAA inspector said... * There is no "sparsely settled" area anywhere within the Puget Sound region, even in locations where it is miles to the nearest structure. The FAA does not provide any guidance as to what *is* a sparsely settled area, but apparently if there's any settlement anywhere within some apparently long distance, that's not "sparse". * There is no exception to the minimum safe altitude rules for the purpose of practicing engine-out procedures. If you are not over a sparsely settled area (of which there are none around here, and by this interpretation there would be none around ANY significantly populated region), then you may not descend below 500', and that goes up to 1000' above the highest obstacle within 2000' of the aircraft if the area is considered "congested" (note that they don't restrict that to man-made obstacles...if there's a 100' tree around, quite common here in the Northwest and elsewhere, your minimum altitude is actually 1100' AGL, for example). * The inspector readily admitted that there is no formal definition of the terms, and declined to offer any formal definition of the terms. They are playing by the rules set forth by the NTSB in past judgments, in that the FAA is permitted to interpret their rules as they see fit, and are not required to make any explicit statements about the specifics of the rules. So, if they see a pilot flying lower than the FAA inspector thinks he should be, and the altitude is below *some* minimum safe altitude specified, the inspector need only describe the area as an area where a higher altitude is required, and there's no defense that the pilot can mount against that. So, as far your actual question goes...it depends on what you mean by "see if one can actually make the field", but if that would require flight below 500' and you're not at an airport, then no, you can't do that practically anywhere that people live. If you're flying in a congested area (and remember, there's no formal definition of "congested area"), that minimum is the 1000' given. With a minimum altitude of 1000' above the highest obstacle within 2000', I'd say it'd be pretty hard to know for sure that you've got the field made. An experienced instructor could make a reasonably accurate judgment call, but from that altitude, all sorts of things could screw up the glide. Frankly, I think it's pretty lame for the FAA to have rules for which they don't include definitions of the terms used. I'm not one to just broadly paint the FAA as being bad, but this is certainly one area in which they need some serious improvement. Pete |
Achtung, I'm from the FAA and I'm hear to define words the
way I want. Papers! § 91.119 Minimum safe altitudes: General. Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes: (a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface. (b) Over congested areas. Over any congested area of a city, town, or settlement, or over any open air assembly of persons, an altitude of 1,000 feet above the highest obstacle within a horizontal radius of 2,000 feet of the aircraft. (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. (d) Helicopters. Helicopters may be operated at less than the minimums prescribed in paragraph (b) or (c) of this section if the operation is conducted without hazard to persons or property on the surface. In addition, each person operating a helicopter shall comply with any routes or altitudes specifically prescribed for helicopters by the Administrator. Important words above... OVER Every place that isn't OVER a town, city, settlement or crowd is by the above list SPARSELY and I'm pretty sure Puget Sound has lots of water. Except for congested areas, a tree is not an item of concern, the term structure can mean the outhouse or porta potty or a tent, but a road sign along a vacant highway doesn't count as a structure. "Peter Duniho" wrote in message ... | "Jose" wrote in message | . com... | I wonder how one can legally practice engine-out procedures (trim for best | glide, find a suitable field...) since part of the practice is to see if | one can actually =make= the field one has picked out by using the | procedures one is practicing. | | FYI... | | As it happens, I just flew with an instructor yesterday, doing my BFR. | During our ground discussion, he told me that he was involved in an incident | in which the FAA cited him for violating the minimum safe altitude | regulations. In his case, he was not doing engine-out practicing, but that | did come up, and here's what the local FAA inspector said... | | * There is no "sparsely settled" area anywhere within the Puget Sound | region, even in locations where it is miles to the nearest structure. The | FAA does not provide any guidance as to what *is* a sparsely settled area, | but apparently if there's any settlement anywhere within some apparently | long distance, that's not "sparse". | | * There is no exception to the minimum safe altitude rules for the purpose | of practicing engine-out procedures. If you are not over a sparsely settled | area (of which there are none around here, and by this interpretation there | would be none around ANY significantly populated region), then you may not | descend below 500', and that goes up to 1000' above the highest obstacle | within 2000' of the aircraft if the area is considered "congested" (note | that they don't restrict that to man-made obstacles...if there's a 100' tree | around, quite common here in the Northwest and elsewhere, your minimum | altitude is actually 1100' AGL, for example). | | * The inspector readily admitted that there is no formal definition of the | terms, and declined to offer any formal definition of the terms. They are | playing by the rules set forth by the NTSB in past judgments, in that the | FAA is permitted to interpret their rules as they see fit, and are not | required to make any explicit statements about the specifics of the rules. | So, if they see a pilot flying lower than the FAA inspector thinks he should | be, and the altitude is below *some* minimum safe altitude specified, the | inspector need only describe the area as an area where a higher altitude is | required, and there's no defense that the pilot can mount against that. | | So, as far your actual question goes...it depends on what you mean by "see | if one can actually make the field", but if that would require flight below | 500' and you're not at an airport, then no, you can't do that practically | anywhere that people live. If you're flying in a congested area (and | remember, there's no formal definition of "congested area"), that minimum is | the 1000' given. | | With a minimum altitude of 1000' above the highest obstacle within 2000', | I'd say it'd be pretty hard to know for sure that you've got the field made. | An experienced instructor could make a reasonably accurate judgment call, | but from that altitude, all sorts of things could screw up the glide. | | Frankly, I think it's pretty lame for the FAA to have rules for which they | don't include definitions of the terms used. I'm not one to just broadly | paint the FAA as being bad, but this is certainly one area in which they | need some serious improvement. | | Pete | | |
"Jim Macklin" wrote in message
news:rc9yg.84362$ZW3.50803@dukeread04... [...] Important words above... OVER Every place that isn't OVER a town, city, settlement or crowd is by the above list SPARSELY and I'm pretty sure Puget Sound has lots of water. Do you even bother to read the posts to which you reply? Or are you saying that you don't believe what I wrote? I specifically wrote exactly the interpretation that the FAA is using here, and it isn't anywhere *close* to the interpretation you'd like it to be. In particular, the person who was cited by the FAA for violation of 91.119 was NOT over "a town, city, settlement, or crowd" and yet was found to NOT be flying over a "sparsely populated area". As far as "I'm pretty sure Puget Sound has lots of water" goes, that's fine, but nothing that I wrote pertained to flight over water. The question is what constitutes a "sparsely populated area", and in the Puget Sound region, there is NO place that meets that description, according to our local FSDO. Pete |
Yes, I read your words and my opinion is that your FSDO is
insane. If some FAA inspector told me what you are saying, I would be in contact with my Congressman and FAA HQ. The FAA publications teach missed approaches, low approaches and all manner of low flight. If you are OVER a town, it can be identified and a pilot knows what altitude he is expect to fly. When over open range, trees, water or an area with no concentration of houses or buildings, that constitutes "sparsely" by common definition. Laws in order to be enforced must be written so a common person can abide by the words written in that law. The FAA interpretation you say the FAA enforces in your region is nonsense and since they have brought cases, it is open to challenge, Congressional over-sight, and public demonstration. The FAA does issue waiver to these rules for airshows, some times it is a blanket for the airport/event [Oshkosh] and sometimes it is for the pilot and the airspace. But any pilot expects to be able to fly a low approach and do a go-around. Many CFIs have their students fly along and just a few feet above the runway, planning not to land, even though the speed is right ay 1.3 Vso. Some times we do have tire contact, but it wasn't planned. If an agent of the Administrator asks you to do something or clears you to do some something, that is approval by the Administrator. The FAA has many agents, some like airplanes and some still think they are a Col. in the USAF. If you take a NASA night photo of the area and it is dark, it is sparsely populated. If you are a mile away from a densely populated area and any area of buildings, vehicles [that includes tractor and trucks] structures [that includes tower and oil rigs] people and that includes Mexicans walking over the border, stay 500 foot radius away. But just because you say it, I say it, the FAA says it or even an NTSB law judge says it, it may not be correct. Congress and the US Supreme Court are the final say. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Peter Duniho" wrote in message ... | "Jim Macklin" wrote in message | news:rc9yg.84362$ZW3.50803@dukeread04... | [...] | Important words above... OVER Every place that isn't OVER a | town, city, settlement or crowd is by the above list | SPARSELY and I'm pretty sure Puget Sound has lots of water. | | Do you even bother to read the posts to which you reply? Or are you saying | that you don't believe what I wrote? | | I specifically wrote exactly the interpretation that the FAA is using here, | and it isn't anywhere *close* to the interpretation you'd like it to be. In | particular, the person who was cited by the FAA for violation of 91.119 was | NOT over "a town, city, settlement, or crowd" and yet was found to NOT be | flying over a "sparsely populated area". | | As far as "I'm pretty sure Puget Sound has lots of water" goes, that's fine, | but nothing that I wrote pertained to flight over water. The question is | what constitutes a "sparsely populated area", and in the Puget Sound region, | there is NO place that meets that description, according to our local FSDO. | | Pete | | |
news:bAeyg.84402$ZW3.76333@dukeread04... Yes, I read your words and my opinion is that your FSDO is insane. Perhaps they are. I have no facts to suggest otherwise. However, be that as it may, they are interpreting the FARs, and the NTSB has found that where the FARs are vague, the FAA's interpretation is the one that is used, even if that interpretation is contrary to "common definition" (and frankly, the actual "common definition" of "sparsely" is even more vague than any official definition...can you tell me exactly how "widely spaced" the intervals between population need to be in order to qualify as "sparsely" under the common definition of "Occurring, growing, or settled at widely spaced intervals"?). The FAA publications teach missed approaches, low approaches and all manner of low flight. Beyond missed approaches, low approaches, takeoffs, and landings, what flight below 500' does the FAA teach? More specifically, what low flight that cannot be accomplished at an airport does the FAA teach? If you are OVER a town, it can be identified and a pilot knows what altitude he is expect to fly. When over open range, trees, water or an area with no concentration of houses or buildings, that constitutes "sparsely" by common definition. And yet, there's at least one pilot who was found in violation of 91.119 while flying below 500' in "an area with no concentration of houses or buildings". I don't agree with the interpretation, but given the broad latitude the FAA is granted in enforcing their regulations, it's important for every pilot to understand the precedents. [...] The FAA interpretation you say the FAA enforces in your region is nonsense and since they have brought cases, it is open to challenge, Congressional over-sight, and public demonstration. I agree it would have been more informative had this pilot contested the violation. As it happens, he was let off without so much as a suspension, and so he was happy to not make waves. However, I am not so naive as to think that he would have had an open and shut case in contesting the action. [...] But any pilot expects to be able to fly a low approach and do a go-around. Again, completely irrelevant to the question of "sparsely populated". Many CFIs have their students fly along and just a few feet above the runway, planning not to land, even though the speed is right ay 1.3 Vso. Some times we do have tire contact, but it wasn't planned. Yes, I know. I even benefited from this practice, and I've never heard of anyone being cited because of it. However, still completely irrelevant to the question of "sparsely populated". If an agent of the Administrator asks you to do something or clears you to do some something, that is approval by the Administrator. Again, completely irrelevant. The FAA has many agents, some like airplanes and some still think they are a Col. in the USAF. If you take a NASA night photo of the area and it is dark, it is sparsely populated. A relevant claim, but unfounded in this context. I'm aware of no FAA interpretation that describes "sparsely populated" in that manner. [...] But just because you say it, I say it, the FAA says it or even an NTSB law judge says it, it may not be correct. Congress and the US Supreme Court are the final say. Well, if you're aware of such a case in which the FAA opinion was overruled, I'm all ears. If not, then your own interpretation of "sparsely populated" (which I generally agree with) carries no weight whatsoever. Pete |
Your Congressman sets the FAA budget every two years. The
FAA has to answer Congress' requests on demand. Call your Congressman and I'll can mine and raise the issue. I know my Congressman personally and have his phone number memorized and call his staff by first name. Let's start a movement, everybody call your Congressman about stupid FAA rules and interpretations. There is an election November 7, they will listen to you now and they will be "home" looking to talk face to face. -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Peter Duniho" wrote in message ... | "Jim Macklin" wrote in message | news:bAeyg.84402$ZW3.76333@dukeread04... | Yes, I read your words and my opinion is that your FSDO is | insane. | | Perhaps they are. I have no facts to suggest otherwise. | | However, be that as it may, they are interpreting the FARs, and the NTSB has | found that where the FARs are vague, the FAA's interpretation is the one | that is used, even if that interpretation is contrary to "common definition" | (and frankly, the actual "common definition" of "sparsely" is even more | vague than any official definition...can you tell me exactly how "widely | spaced" the intervals between population need to be in order to qualify as | "sparsely" under the common definition of "Occurring, growing, or settled at | widely spaced intervals"?). | | The FAA publications teach missed approaches, low approaches | and all manner of low flight. | | Beyond missed approaches, low approaches, takeoffs, and landings, what | flight below 500' does the FAA teach? More specifically, what low flight | that cannot be accomplished at an airport does the FAA teach? | | If you are OVER a town, it | can be identified and a pilot knows what altitude he is | expect to fly. When over open range, trees, water or an | area with no concentration of houses or buildings, that | constitutes "sparsely" by common definition. | | And yet, there's at least one pilot who was found in violation of 91.119 | while flying below 500' in "an area with no concentration of houses or | buildings". | | I don't agree with the interpretation, but given the broad latitude the FAA | is granted in enforcing their regulations, it's important for every pilot to | understand the precedents. | | [...] | The FAA interpretation you say the FAA enforces in your | region is nonsense and since they have brought cases, it is | open to challenge, Congressional over-sight, and public | demonstration. | | I agree it would have been more informative had this pilot contested the | violation. As it happens, he was let off without so much as a suspension, | and so he was happy to not make waves. However, I am not so naive as to | think that he would have had an open and shut case in contesting the action. | | [...] But any | pilot expects to be able to fly a low approach and do a | go-around. | | Again, completely irrelevant to the question of "sparsely populated". | | Many CFIs have their students fly along and just | a few feet above the runway, planning not to land, even | though the speed is right ay 1.3 Vso. Some times we do have | tire contact, but it wasn't planned. | | Yes, I know. I even benefited from this practice, and I've never heard of | anyone being cited because of it. However, still completely irrelevant to | the question of "sparsely populated". | | If an agent of the Administrator asks you to do something or | clears you to do some something, that is approval by the | Administrator. | | Again, completely irrelevant. | | The FAA has many agents, some like airplanes and some still | think they are a Col. in the USAF. If you take a NASA night | photo of the area and it is dark, it is sparsely populated. | | A relevant claim, but unfounded in this context. I'm aware of no FAA | interpretation that describes "sparsely populated" in that manner. | | [...] | But just because you say it, I say it, the FAA says it or | even an NTSB law judge says it, it may not be correct. | Congress and the US Supreme Court are the final say. | | Well, if you're aware of such a case in which the FAA opinion was overruled, | I'm all ears. If not, then your own interpretation of "sparsely populated" | (which I generally agree with) carries no weight whatsoever. | | Pete | | |
The sectional charts show 'populated' areas in yellow. If it is not yellow, then is it 'unpopulated'?
http://www.naco.faa.gov/content/naco...FR_Symbols.pdf "Peter Duniho" wrote in message ... : "Jim Macklin" wrote in message : news:bAeyg.84402$ZW3.76333@dukeread04... : Yes, I read your words and my opinion is that your FSDO is : insane. : : Perhaps they are. I have no facts to suggest otherwise. : : However, be that as it may, they are interpreting the FARs, and the NTSB has : found that where the FARs are vague, the FAA's interpretation is the one : that is used, even if that interpretation is contrary to "common definition" : (and frankly, the actual "common definition" of "sparsely" is even more : vague than any official definition...can you tell me exactly how "widely : spaced" the intervals between population need to be in order to qualify as : "sparsely" under the common definition of "Occurring, growing, or settled at : widely spaced intervals"?). : |
Actually, the yellow area is a representation of the way a
city looks at night, the pattern of the lights. see http://quickfacts.census.gov/qfd/states/20/20071.html and then browse to find useful info. For instance Greeley Co. Kansas has 2 people per square mile. ".Blueskies." wrote in message . com... | The sectional charts show 'populated' areas in yellow. If it is not yellow, then is it 'unpopulated'? | | http://www.naco.faa.gov/content/naco...FR_Symbols.pdf | | | | "Peter Duniho" wrote in message ... | : "Jim Macklin" wrote in message | : news:bAeyg.84402$ZW3.76333@dukeread04... | : Yes, I read your words and my opinion is that your FSDO is | : insane. | : | : Perhaps they are. I have no facts to suggest otherwise. | : | : However, be that as it may, they are interpreting the FARs, and the NTSB has | : found that where the FARs are vague, the FAA's interpretation is the one | : that is used, even if that interpretation is contrary to "common definition" | : (and frankly, the actual "common definition" of "sparsely" is even more | : vague than any official definition...can you tell me exactly how "widely | : spaced" the intervals between population need to be in order to qualify as | : "sparsely" under the common definition of "Occurring, growing, or settled at | : widely spaced intervals"?). | : | | |
Our runway is being bulldozed! | Jay Honeck | Piloting | 28 | July 23rd 06 03:02 AM |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Owning | 114 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 05:40 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
