On Sat, 30 Oct 2004 07:50:06 -0400, Rick McPherson
wrote: Hello All, I've been lurking in the shadows of this group for the duration of my ifr training and subsequent passage of my ride. Thanks to all of you for the great info. Now, my question is about maintaining currency, the Regs state:"No person may act as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR, unless within the preceding six calendar months that person has performed: (i) at least six instrument approaches; (ii) holding procedures; and (iii) intercepting and tracking courses through the use of navigation systems." 1. Can I file ifr in vfr or marginal weather, fly 3 or however many approaches, and use them to remain current, or do I need to be "solely by reference to the instruments" i.e., actual or simulated with a safety pilot in order for them (approaches) to count? If you were not current it would be a violation to file IFR, since you weren't current and thus didn't meet the parts of 61.57(c) you quoted. To file IFR you have to be current, regardless of whether it's IMC or not. Combined with that, is the part of 61.57(c)(1) you omitted (but alluded to) above, which starts "(1) For the purpose of obtaining instrument experience in an aircraft (other than a glider), performed and logged under actual or simulated instrument conditions, either in flight in the appropriate category of aircraft for the instrument privileges sought or in a flight simulator or flight training device that is representative of the aircraft category for the instrument privileges sought" - meaning safety pilot, or instructor if VMC, or done while still current in actual IMC. 2. How many of you use "handheld gps onboard" in the remarks field and ask for "direct" enroute. Thanks in advance. I believe this would be considered a violation if you're caught. I know it's only advisory, but the AIM in section 1-1-19, section (d)(1)(a) "General Requirements - 1 Authorization to conduct any GPS operation under IFR requires that (a) GPS navigation equipment used must be approved in accordance with the requirements specified in Technical Standard Order (TSO) C-129, or equivalent, and the installation must be done in accordance with Advisory Circular AC 20-138 or 20-130A." It also has a table which shows which classes of GPS units are approved for what, based on their TSO-C129 approvals, and handheld and VFR panel-mount are not checked off in the approved "IFR enroute" column, and has a footnote which re-iterates a previous "VFR and hand-held GPS systems are not authorized for IFR navigation, instrument approaches, or as a primary instrument flight reference. During IFR operations they may be considered only an aid to situational awareness" statement. Good luck! |
In a previous article, Peter Clark said:
On Sat, 30 Oct 2004 07:50:06 -0400, Rick McPherson wrote: 2. How many of you use "handheld gps onboard" in the remarks field and ask for "direct" enroute. Thanks in advance. I believe this would be considered a violation if you're caught. I A violation? Not if he didn't ask for or recieve a GPS routing. What do you is you ask for a radar vector direct and follow it using your GPS. In some situations, you can even prompt them for it by saying "can you give me a radar vector 332 degrees direct to ALB". You're not using the GPS as primary nav, you're using the radar vector as primary nav, and monitoring it using the GPS. If the GPS died, you'd still be able to fly the heading bug on your DG. -- Paul Tomblin http://xcski.com/blogs/pt/ You've got to love a newsreader with a menu option named "Kill this Author". Does it work? And if so, is the death traceable? Nah, but Dave the Resurrector will just bring 'em back again. |
On Sat, 30 Oct 2004 14:24:01 +0000 (UTC),
(Paul Tomblin) wrote: In a previous article, Peter Clark said: On Sat, 30 Oct 2004 07:50:06 -0400, Rick McPherson wrote: 2. How many of you use "handheld gps onboard" in the remarks field and ask for "direct" enroute. Thanks in advance. I believe this would be considered a violation if you're caught. I A violation? Not if he didn't ask for or recieve a GPS routing. What do you is you ask for a radar vector direct and follow it using your GPS. In some situations, you can even prompt them for it by saying "can you give me a radar vector 332 degrees direct to ALB". You're not using the GPS as primary nav, you're using the radar vector as primary nav, and monitoring it using the GPS. If the GPS died, you'd still be able to fly the heading bug on your DG. Your use would be covered under the "situational awareness" clause. I bet you don't file /G or say "handheld GPS onboard" in your flight plans with only a handheld, right? His intent clearly appears to be using the handheld GPS for direct routing (otherwise why would there be a comment in the flight plan and the request for direct enroute?) and that's clearly against the objective of the rule. Basically, if you only have a handheld, rule says you can't use it for anything other than a backup to what's in the aircraft, why mention it in the first place? It doesn't appear to buy anything in the IFR enroute environment. |
![]() Peter Clark wrote: I bet you don't say "handheld GPS onboard" in your flight plans with only a handheld, right? Why wouldn't you say "handheld on board" if you didn't actually have a handheld? His intent clearly appears to be using the handheld GPS for direct routing (otherwise why would there be a comment in the flight plan and the request for direct enroute?) Because you get the vector and then use your handheld. That is legal. |
![]() Is there any benefit to noting "handheld" or "VFR GPS" in the remarks? Or do you just file /U or whatever and ask for a radar vector once you're up there? "Newps" wrote in message ... Peter Clark wrote: I bet you don't say "handheld GPS onboard" in your flight plans with only a handheld, right? Why wouldn't you say "handheld on board" if you didn't actually have a handheld? His intent clearly appears to be using the handheld GPS for direct routing (otherwise why would there be a comment in the flight plan and the request for direct enroute?) Because you get the vector and then use your handheld. That is legal. |
![]() C Kingsbury wrote: Is there any benefit to noting "handheld" or "VFR GPS" in the remarks? Or do you just file /U or whatever and ask for a radar vector once you're up there? You ask for a vector and also, in the same breath, tell him what heading will be good. |
On Sat, 30 Oct 2004 12:16:32 -0600, Newps wrote:
Peter Clark wrote: His intent clearly appears to be using the handheld GPS for direct routing (otherwise why would there be a comment in the flight plan and the request for direct enroute?) Because you get the vector and then use your handheld. That is legal. OK, but the original post didn't say anything about vectors. It said "put a comment in the flight plan 'handheld gps onboard'" - to me that implys the poster is attempting to tell ATC "I can do RNAV /G, I don't really have that equipment so I can't file /G, but hey it's cool, you can give me that direct routing anyway because I have this neat handheld GPS". Is that legal? If not, why bother with the "handheld gps onboard" comment? It doesn't make any difference to ATC - vectors are vectors, whatever you're using to turn to them, and if it's not legal for RNAV it still doesn't matter whether you have it, right? |
On Sat, 30 Oct 2004 15:01:22 -0400, Peter Clark
wrote: On Sat, 30 Oct 2004 12:16:32 -0600, Newps wrote: Peter Clark wrote: His intent clearly appears to be using the handheld GPS for direct routing (otherwise why would there be a comment in the flight plan and the request for direct enroute?) Because you get the vector and then use your handheld. That is legal. OK, but the original post didn't say anything about vectors. It said "put a comment in the flight plan 'handheld gps onboard'" - to me that implys the poster is attempting to tell ATC "I can do RNAV /G, I don't really have that equipment so I can't file /G, but hey it's cool, you can give me that direct routing anyway because I have this neat handheld GPS". Is that legal? If not, why bother with the "handheld gps onboard" comment? It doesn't make any difference to ATC - vectors are vectors, whatever you're using to turn to them, and if it's not legal for RNAV it still doesn't matter whether you have it, right? Peter, Your right. I have no intention of flying strictly via garmin 195, that would be illegal. I file /U. However, through some interesting discussion here, I do see how atc can accommodate me legally. I fly in Western PA and am rarely out of radar coverage. thanks for your help. ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= East/West-Coast Server Farms - Total Privacy via Encryption =--- |
On Sat, 30 Oct 2004 16:02:36 -0400, Rick McPherson
wrote: Your right. I have no intention of flying strictly via garmin 195, that would be illegal. I file /U. However, through some interesting discussion here, I do see how atc can accommodate me legally. I fly in Western PA and am rarely out of radar coverage. thanks for your help. We both learned something today. Seems like the presence of radar is they key - vector monitoring via handheld GPS should be OK, just have the good 'ol standbys ready incase the radar craps out ![]() Take care, P |
On Sat, 30 Oct 2004 15:01:22 -0400, Peter Clark wrote: On Sat, 30 Oct 2004 12:16:32 -0600, Newps wrote: Peter Clark wrote: His intent clearly appears to be using the handheld GPS for direct routing (otherwise why would there be a comment in the flight plan and the request for direct enroute?) Because you get the vector and then use your handheld. That is legal. OK, but the original post didn't say anything about vectors. It said "put a comment in the flight plan 'handheld gps onboard'" - to me that implys the poster is attempting to tell ATC "I can do RNAV /G, I don't really have that equipment so I can't file /G, but hey it's cool, you can give me that direct routing anyway because I have this neat handheld GPS". Is that legal? If not, why bother with the "handheld gps onboard" comment? It doesn't make any difference to ATC - vectors are vectors, whatever you're using to turn to them, and if it's not legal for RNAV it still doesn't matter whether you have it, right? Peter, Your right. I have no intention of flying strictly via garmin 195, that would be illegal. I file /U. However, through some interesting discussion here, I do see how atc can accommodate me legally. I fly in Western PA and am rarely out of radar coverage. thanks for your help. Unless you fly over Tidioute VOR. Every time I fly over that, I am out of radar contact for 10-15 miles. Matt |
regaining night currency but not alone | Teacherjh | Instrument Flight Rules | 11 | May 28th 04 02:08 PM |
Holds for currency requirements | Paul Tomblin | Instrument Flight Rules | 8 | March 12th 04 06:49 PM |
Night Currency | Doug Campbell | Instrument Flight Rules | 21 | October 17th 03 10:53 PM |
Infrequent flying & IFR currency | Marty Ross | Instrument Flight Rules | 12 | August 22nd 03 10:45 AM |
Which of these approaches is loggable? | Paul Tomblin | Instrument Flight Rules | 26 | August 16th 03 05:22 PM |
