"Peter Duniho" wrote: "Jonathan Goodish" wrote in message ... There is nothing in the FARs that would suggest that runway "fly overs" are illegal. If there is no intent to land, I'd say 91.119 certainly can be read as just such a prohibition. Please explain how an intent to land is a requirement of FAR 91.119? FAR 91.119 (a) says that I may not fly below an altitude allowing a safe emergency landing, irrespective of whether I intend to land or not. The language, "Except when necessary for takeoff or landing," provides me with an exception to the rest of 91.119 as long as I am taking off or landing. But, it does not indicate a violation for low-level flight as long as I meet the requirement if paragraph (a) without violating anything in paragraphs (b) or (c). Aside from any other argument, it would be very difficult for anyone to argue against an intent to land for someone performing a low-pass on an open runway. JKG |
FAR 91.119 (a) says that I may not fly below an altitude allowing a safe emergency landing, irrespective of whether I intend to land or not. The language, "Except when necessary for takeoff or landing," provides me with an exception to the rest of 91.119 as long as I am taking off or landing. That's not what my book says. The "except when necessary..." clause is in front of everything. The (a) anywhe ... allowing a safe landing... means ANYWHERE you fly, you must be albe to land without undue hazard... IN ADDITION, even if you could land without undue hazard, other restrictions apply (500', 1000', etc) Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
Jose wrote: Please explain how an intent to land is a requirement of FAR 91.119? FAR 91.119 (a) says that I may not fly below an altitude allowing a safe emergency landing, irrespective of whether I intend to land or not. The language, "Except when necessary for takeoff or landing," provides me with an exception to the rest of 91.119 as long as I am taking off or landing. That's not what my book says. The "except when necessary..." clause is in front of everything. The (a) anywhe ... allowing a safe landing... means ANYWHERE you fly, you must be albe to land without undue hazard... IN ADDITION, even if you could land without undue hazard, other restrictions apply (500', 1000', etc) Jose "Except when necessary for takeoff and landing" grants you an exception to any other requirements in 91.119 for minimum altitudes. However, I could fly along at 100 feet AGL over sparsely populated areas, as permitted by 91.119(a) and (c). Last time I checked, an airport runway was pretty sparsely populated, and I could certainly use it for an emergency landing if I lost power. JKG |
was pretty sparsely populated... Oh, I don't know about that. There are probably airplanes around within five hundred feet, and people in them or working on them. There may also be structures. I was at an FAA safety seminar in which the Hudson River was stated to be "congested", as is the middle of Pennsylvania wherever there is a highway. The context was flying the Hudson corridor. The presentor said that the FAA granated a special document (I don't know what they call them - memorandum of understanding?) in which they acknowledge that it is not possible to fly over the George Washington Bridge while remaining in the corridor (you must remain 1000 feet above it, which puts you in class B), but they "promise not to prosecute" people who violate the FARs by flying the corridor. It looks like they are setting themselves up again to enforce anything they want, by using this document as a precedent for anything being considered "congested". Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
Jose wrote: Last time I checked, an airport runway was pretty sparsely populated... Oh, I don't know about that. There are probably airplanes around within five hundred feet, and people in them or working on them. There may also be structures. It depends on the airport and what's occurring on the surface. I would venture to guess that most airports are rather sleepy most of the time, and people and structures are beyond 500 feet from the runway. Regardless, though, you'd have a tough time arguing that someone who does low approaches, go arounds, or low passes down the runway didn't initially intend to land. JKG |
Jonathan Goodish wrote:
Regardless, though, you'd have a tough time arguing that someone who does low approaches, go arounds, or low passes down the runway didn't initially intend to land. I think speed is a factor here. I can buzz a runway in a a plane at speeds a lot higher than would be safe for landing. |
does low approaches, go arounds, or low passes down the runway didn't initially intend to land. No I wouldn't. The issue (of course) isn't whether the pilot =eventually= intended to land (somewhere), but whether the pilot =at that time= intended to land =there=. Somebody practicing low approaches would be hard put to say he botched the approach so badly every time that a go-around was warranted. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
... [...] Last time I checked, an airport runway was pretty sparsely populated There is no way that a runway is in and of itself considered a "sparsely populated area". |
... There is nothing in the FARs that would suggest that runway "fly overs" are illegal. If there is no intent to land, I'd say 91.119 certainly can be read as just such a prohibition. Please explain how an intent to land is a requirement of FAR 91.119? Um...all of the minimum altitudes apply unless for the purpose of a takeoff or landing? Duh. The requirement is to be given an exception to 91.119. FAR 91.119 (a) says that I may not fly below an altitude allowing a safe emergency landing, irrespective of whether I intend to land or not. (a) is the broadest, least-likely-to-apply situation. It prescribes the absolute minimum altitude anywhere. 91.119 isn't a menu, where you get to choose which paragraph you want to comply with. You have to comply with them all. The language, "Except when necessary for takeoff or landing," provides me with an exception to the rest of 91.119 as long as I am taking off or landing. But, it does not indicate a violation for low-level flight as long as I meet the requirement if paragraph (a) without violating anything in paragraphs (b) or (c). If you are at any public, municipal airport, there is no way you are meeting the requirement of (a) without violating (b) or (c). Aside from any other argument, it would be very difficult for anyone to argue against an intent to land for someone performing a low-pass on an open runway. If you'd bothered to read the related thread, "Case law on runway buzzing/flyovers", you'd understand why that statement is just plain false. There are many cases where the FAA has successfully argued against an intent to land for someone performing a low-pass on an open runway. Two prime example situations are when the runway was never a suitable landing site for the airplane in the first place, or when the approach to the runway was not made in a manner conducive to an actual landing (that would, of course, require a reliable witness to describe the entire approach). Pete |
Our runway is being bulldozed! | Jay Honeck | Piloting | 28 | July 23rd 06 03:02 AM |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Owning | 114 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 05:40 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
