On Sat, 29 Jul 2006 15:16:27 GMT, Jose
wrote in :: The operators probably have to eyeball the airspace over the 160 acres being photographed. [...] They ought to be able to see full-scale aircraft entering the airspace and command the UAV to descend or change course to avoid the traffic. How reliably can you eyeball 160 acres and see all aircraft in time to descend or change course? 160 acres is only a half mile square. How often have you not seen traffic called out to you by ATC? How long does it take for you to find traffic in the pattern when you come in to a new airport to land? Do you find it all? The operators will not want to have mid-airs any more than other pilots. If the operator has a midair, he gets a reprimand. Under what regulation is a reprimand mandated? If a pilot has a midair, he dies. Therein lies the iniquity. |
Under what regulation is a reprimand mandated? None. I presume that whoever owns the UAV would be upset with its loss, and will communicate that upsettedness to the operator. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
On Sat, 29 Jul 2006 22:56:04 GMT, Jose
wrote in :: If the operator has a midair, he gets a reprimand. Under what regulation is a reprimand mandated? None. I presume that whoever owns the UAV would be upset with its loss, and will communicate that upsettedness to the operator. So, while it appears that NavCanada has given the little UAV it's blessing to operate below 2,200', there are no regulations governing the competence of its operators. That should change. |
Under what regulation is a reprimand mandated? None. I presume that whoever owns the UAV would be upset with its loss, and will communicate that upsettedness to the operator. So, while it appears that NavCanada has given the little UAV it's blessing to operate below 2,200', there are no regulations governing the competence of its operators. That should change. Ok, perhaps I should say "none that I know of". One should not infer from my comments that there are no rules in place. However, I infer from other's comments that the rules so far presented to me are insufficient. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
