Scared of mid-airs
Old July 30th 06, 02:32 PM posted to rec.aviation.piloting,rec.aviation.student
Jose[_1_]
Default PED Scared of mid-airs
Near miss. No, I've never had one that almost missed me.
That would be a "nearly miss". A near miss is a miss. A deep lake is a
lake. A red rose is a rose. A heavy rain is a rain.
Jose
Old July 30th 06, 02:45 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
ATC has a box around each IFR airplane, no other airplane
should be in that box. The size of the box changes, but in
general [somebody will surely correct me] is 1,000 above and
below within a distance of from 5 to 20 miles. Anything
closer and it is a near-miss. When you are close enough to
see the individual rivets or make out the color of the other
pilot's eyes, it is also a near-miss.
{I know, loss of separation}
"Jose" wrote in message
deep lake is a
| Jose
music.
Old July 30th 06, 06:30 PM posted to rec.aviation.piloting,rec.aviation.student
Orval Fairbairn
In article 5Z2zg.84642$ZW3.6823@dukeread04,
The above posting is not correct. IFR planes have a unique box *only*
against other IFR traffic -- VFR traffic is not mentioned. That is why
you *have* to keep a lookout for traffic when you are under IFR.
An IFR may report a "near miss" when a VFR does not consider it to be a
threat. The "1000 above or below within 5 to 20 miles" applie only to
Class A airspace, *not* to B, C, D, etc.; else traffic flow would
trickle to a halt.
Old July 30th 06, 07:09 PM posted to rec.aviation.piloting,rec.aviation.student
Tom McQuinn
trickle to a halt.
That's the way I understand it. My closest encounter ever was while IFR
in VMC. My instructor said, "I have the airplane", and we went into a
steep dive. I pulled off the hood to see a Cessna pass over that we
would have hit head on. We complained to ATC and they showed no
interest. I did some reading and came to the conclusion that their
primary job is to keep IFR traffic separated. If they have time, then
yeah, they can and should route you around a storm cell or some VFR
traffic but those tasks are not their primary mission.
I'm sure any errors and omissions in the above will be taken care of by
folks more knowledgeable than I am in this area.
Tom
Old July 31st 06, 06:22 AM posted to rec.aviation.piloting,rec.aviation.student
Er... what do you mean by "keep a lookout for traffic under IFR"?
Lookout on the radar, surely??
Ramapriya
Old July 31st 06, 07:30 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
If you're not in a cloud, you are required to look out the
windows.
unique box *only*
under IFR.
under IFR"?
| Ramapriya
Old July 31st 06, 03:24 PM posted to rec.aviation.piloting,rec.aviation.student
Jose[_1_]
Nope. Traffic out the window.
In brief, "IFR" is a set of rules to fly by, which permits flying in the
clouds. "IMC" means weather in which one cannot see out the window.
Only IFR airplanes can fly in IMC.
"VMC" means weather in which you =can= see out the window. In that kind
of weather, you can still fly IFR (in fact, if you are in and out of
clouds, you will be in VMC and then in IMC and then back in VMC...).
However, other airplanes may be flying VFR (which is a different set of
rules to fly by). Under VFR (rules), the pilots look out the window and
avoid each other, since they can see.
The upshot is that under IFR (rules), air traffic controllers separate
other IFR traffic from you. They do not separate VFR traffic from you.
If you are in IMC (i.e. clouds) and can't see, there should be no VFR
traffic for you to avoid. If you are in VMC, then (like all other
pilots), you need to look out the window. But, since it's VMC, you can.
Jose
Old July 31st 06, 04:43 PM posted to rec.aviation.piloting,rec.aviation.student
Thanks a lot, Jose and Jim; much appreciated
Ramapriya
Jose
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
The kids are scared, was Saddam evacuated D. Strang Military Aviation 0 April 7th 04 10:36 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
