Non-precision approach without a published MAP?
Old July 30th 06, 09:03 PM posted to rec.aviation.ifr
Stefan Lörchner
Default Non-precision approach without a published MAP?
Until this approach, I had not encountered a non-precision approach without
a published missed approach point. Is this more common than my experience
has provided to date?
almost every VOR-A with the VOR at the airport.
Instrument flying Handbook 8-20:
In nonprecision approaches, a final descent is initiated at the
FAF, or after completing the procedure turn and established
inbound on the procedure course. The FAF is clearly
identified by use of the Maltese cross symbol in the profile
view. When the FAF is not indicated in the profile view,
the MAP is based on station passage when the facility is on
the airport or a specified distance (e.g., VOR/DME or GPS
procedures).
In nonprecision
procedures, the pilot determines the MAP by timing from
FAF when the approach aid is well away from the airport, by
a fix or NAVAID when the navigation facility is located on
the field, or by waypoints as defined by GPS or VOR/DME
RNAV.
Old July 30th 06, 09:22 PM posted to rec.aviation.ifr
Sam Spade
Peter R. wrote:
Last Friday I flew with another pilot to Starke County, Indiana (KOXI) to
pick up my stranded Bonanza.
The airport is only served by one instrument approach, a VOR/GPS approach,
linked he
http://www.myairplane.com/databases/.../06847VG18.PDF
The plan view makes the MAP quite clear.
Old July 31st 06, 01:49 PM posted to rec.aviation.ifr
Dave Butler[_1_]
linked he
I found it interesting that BOPIJ is a CNF (computer navigation fix) but appears
on this chart to be identified by VOR/DME.
Old July 31st 06, 02:19 PM posted to rec.aviation.ifr
Sam Spade
Dave Butler wrote:
approach,
linked he
appears on this chart to be identified by VOR/DME.
Looks like a NACO error.
Old July 31st 06, 02:51 PM posted to rec.aviation.ifr
Sam Spade
Dave Butler wrote:
approach,
linked he
Disregard my previous response.
Note the procedure has optional DME minimums. A DME stepdown fix is
permitted in an On-Airport, No-FAF, VOR IAP. Since the DME stepdown fix
is at 4 miles it became cooincident with the sensor FAF (CNF) when GPS
overlay was authorized.
Our first IFR cross-country trip: NY-MI-IL-MI-NY Longworth Piloting 16 July 15th 05 08:12 PM
Video of VOR A approach into MBO in actual A Lieberman Instrument Flight Rules 1 May 2nd 05 03:35 PM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 05:22 PM
Backup gyros - which do you trust? Dan Luke Piloting 23 July 17th 03 08:06 PM
