On Tue, 1 Aug 2006 07:18:09 -0600, "Jeff Crowell"
wrote in : [...] You have been claiming that the speed of the USAF flight was "480 knots (550 mph) at impact" (your post, 7/14), when actual recorded speed at impact was 356 KCAS per the accident report. [That would be Message-ID: ] AIB Report mentions the 480 knot closure speed twice: AIB Report: "The closure rate of Cessna 829 and Ninja 1 based on radar-measured conflict alert data just prior to the collision was approximately 480 KTAS." "Based on their closure rate of approximately 480 knots," ... With regard to your 356 KCAS airspeed at the time of impact, that is not given as Ninja 2's speed in the AIB nor NTSB reports. Here's the only reference to that number I was able to find in either document: AIB Report: "Ninja 1’s displayed airspeed at the time of the midair was 356 KCAS" ... You'll recall that Ninja 1 was not the aircraft that impacted the Cessna. (I find the fact that the AIB report equates 'displayed airspeed' with calibrated air speed a bit puzzling. Do F-16 airspeed indicators actually display calibrated airspeed?) So, lacking evidence to the contrary, I used the closing speed as the speed at the time of impact. That may be incorrect, but lacking better information, it seems reasonable to me, and not an exaggeration nor hyperbole. [...] The USAF Accident Investigation Board's report: "Ninja flight's mistake was in transitioning to the tactical portion of their flight too early, unaware that they were in controlled airspace." That was President, Accident Investigation Board Robin E. Scott's opinion. It is not fact. Despite the fact that Parker failed to brief terminal airspace prior to the flight as regulations require, I personally find it difficult, if not impossible, to believe Parker was unaware, that the 60 mile diameter Tampa Class B terminal airspace lay below him at the time he chose to descend below 10,000' into it. That's opinion, too, annit? I suppose it is my reasoned opinion. If you disagree, perhaps you could explain how Parker could have been unaware of a chunk of terminal airspace 60 miles in diameter and 10,000' feet high on a clear day; I can't. He surely must have been able to see the large international airport beneath him. Every pilot knows there is controlled terminal airspace around such airports. Additionally, Parker was attempting to contact ATC to obtain a clearance to enter the Class B airspace immediately before he chose to descend with out the required ATC clearance. Given those facts, how could Parker possibly have been unaware of what he was doing? Lacking an answer to that question, in light of the circumstances, logic and reason demand, that I conclude, that Parker deliberately chose to violate regulations prohibiting his descent into congested terminal airspace without the required ATC clearance. Per the F-16 Dash 1 he was allowed to be at 350 knots at that altitude, and was traveling only slightly faster at the time of the collision. What about that statement (from the accident investigation) do you not understand? Jeff, I understand that 450 knots within congested terminal airspace is about one third faster than the 350 knot speed limit you state above. One third is not 'slightly faster'. It is _significantly_ faster. (The 450 knot figure is quoted from the AIB report at the beginning of this follow up article.) Perhaps you can provide the reasoning you used in arriving at your conclusion. Speed of the F-16 at impact was 356 KCAS. Limiting the discussion to your 356 KCAS speed at the time of impact figure disregards this fact: Final NTSB Report MIA01FA028A: http://www.ntsb.gov/NTSB/brief2.asp?...A028A &akey=1 "Speeds of up to 450 knots were noted during the descent." Why would you overlook that 450 knot speed? Does the F-16 Dash 1 only pertain to the speed at time of impact? :-) |
Jeff Crowell wrote:
You have been claiming that the speed of the USAF flight was "480 knots (550 mph) at impact" (your post, 7/14), when actual recorded speed at impact was 356 KCAS per the accident report. Larry Dighera wrote: [That would be Message-ID: ] AIB Report mentions the 480 knot closure speed twice: AIB Report: "The closure rate of Cessna 829 and Ninja 1 based on radar-measured conflict alert data just prior to the collision was approximately 480 KTAS." "Based on their closure rate of approximately 480 knots," ... With regard to your 356 KCAS airspeed at the time of impact, that is not given as Ninja 2's speed in the AIB nor NTSB reports. Here's the only reference to that number I was able to find in either document: AIB Report: "Ninja 1's displayed airspeed at the time of the midair was 356 KCAS" ... You'll recall that Ninja 1 was not the aircraft that impacted the Cessna. (I find the fact that the AIB report equates 'displayed airspeed' with calibrated air speed a bit puzzling. Do F-16 airspeed indicators actually display calibrated airspeed?) I certainly grant the difference between Ninjas 1 and 2. Don't you think that if Ninja 2 was flying form on Ninja 1, their speeds must have been pretty close? And, I say again, blithely using closure speed as speed of the mishap aircraft is purposely deceptive. As for KCAS versus KIAS in displays, I have no time in F-16s, so I can't answer that categorically. But since KCAS corrects for system error, it is more accurate than KIAS, so why not? It would not surprise me if what's displayed on the HUD, for example, and therefore recorded by the tapes, is KCAS, since data displayed there has been massaged by the aircraft's air data computer (or some analogous system)... So, lacking evidence to the contrary, I used the closing speed as the speed at the time of impact. That may be incorrect, but lacking better information, it seems reasonable to me, and not an exaggeration nor hyperbole. It doesn't strike you as even a little bit inflammatory in light of your usage of that number? What the hey, you're only off by 25%. Close enough, huh? Per the F-16 Dash 1 he was allowed to be at 350 knots at that altitude, and was traveling only slightly faster at the time of the collision. What about that statement (from the accident investigation) do you not understand? Jeff, I understand that 450 knots within congested terminal airspace is about one third faster than the 350 knot speed limit you state above. One third is not 'slightly faster'. It is _significantly_ faster. (The 450 knot figure is quoted from the AIB report at the beginning of this follow up article.) Perhaps you can provide the reasoning you used in arriving at your conclusion. Speed of the F-16 at impact was 356 KCAS. Limiting the discussion to your 356 KCAS speed at the time of impact figure disregards this fact: Final NTSB Report MIA01FA028A: http://www.ntsb.gov/NTSB/brief2.asp?...A028A &akey=1 "Speeds of up to 450 knots were noted during the descent." Why would you overlook that 450 knot speed? Does the F-16 Dash 1 only pertain to the speed at time of impact? :-) Somewhere during the entire flight, Ninja 2's speed might easily have been supersonic; would that have had any influence on the collision? (other than the cosmic scheduling of it all-- obviously, anything which might have occurred to either F-16 or Cessna to speed or delay their movements throughout their respective flights that day would have prevented this tragedy). Seen that way, if Ninja had gone even a little faster then this would have been nothing more than a close miss. I never debated that Ninja flight recorded a speed of 450 knots during the flight. I'm simply saying that the speed that really matters is the speed immediately prior to the collision. I have not seen any claim other than yours that Ninja was knocking down 450 knots within that critical interval. And you are clearly selecting your data to put your argument in the best possible light. Similarly, the fact that closure rate was 480 knots of course has meaning in terms of how much time was available to both pilots to see and avoid. But to imply or suggest that this is in any way the same as saying that Ninja was making almost 500 knots at impact is a blatant lie. Jeff |
On Thu, 3 Aug 2006 06:54:23 -0600, "Jeff Crowell"
wrote: As for KCAS versus KIAS in displays, I have no time in F-16s, so I can't answer that categorically. But since KCAS corrects for system error, it is more accurate than KIAS, so why not? It would not surprise me if what's displayed on the HUD, for example, and therefore recorded by the tapes, is KCAS, since data displayed there has been massaged by the aircraft's air data computer (or some analogous system)... Just a refresher for those who have been out of pilot training for a long time: ICE-T is the mnemonic for remembering the calculations involving going from airspeed on the pitot-static gauge (Where's Tarver these days?) to real, honest-to-God speed through the air. Indicated airspeed is the uncorrected number of the pitot instrument. Calibrated AS is corrected for "position error"--in the early days pitot tubes often were placed conveniently for designers but that resulted in either boundary layer distortions or plumbing errors along the tubing to the diaphragm of the gauge. Modern aircraft (since the '50s) minimize this error and for all practical considerations Indicated is equal to Calibrated. As Jeff states, data processing through the air data computer makes this computation. Equivalent airspeed correct calibrated for "compressibility error"--the fact that air is an elastic substance and at transonic speeds creates molecule buildup at the pitot tube that distorts the reading of the gauge. Typically Equivalent will be slightly lower than Calibrated. At trans-sonic speeds the error spikes in a narrow regime but then returns to small error less than Calibrated. True airspeed is Equivalent airspeed corrected for air density. Temperature and pressure reduce air density meaning fewer molecules per cubic unit of atmosphere to register on the pneumatic instrument. So, an indication is always lower than actual speed through the air. Rule of thumb for standard day is 2% per thousand feet of altitude. So, true airspeed is always higher than indicated and at high altitudes is considerably higher. This technical data should leave Larry calculating and seeking further charts and documentation for weeks. When he returns I am sure the speed of convergence will not be translated into TAS so that the differentials are the maximum. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
wrote in : [...] Speed of the F-16 at impact was 356 KCAS. Limiting the discussion to your 356 KCAS speed at the time of impact figure disregards this fact: Final NTSB Report MIA01FA028A: http://www.ntsb.gov/NTSB/brief2.asp?...A028A &akey=1 "Speeds of up to 450 knots were noted during the descent." Why would you overlook that 450 knot speed? Does the F-16 Dash 1 only pertain to the speed at time of impact? :-) Somewhere during the entire flight, Ninja 2's speed might easily have been supersonic; Perhaps. But any speed in excess of the minimum safe speed is a violation of regulations below 10,000'. would that have had any influence on the collision? (other than the cosmic scheduling of it all-- obviously, anything which might have occurred to either F-16 or Cessna to speed or delay their movements throughout their respective flights that day would have prevented this tragedy). Seen that way, if Ninja had gone even a little faster then this would have been nothing more than a close miss. That analysis disregards the fact that there were other aircraft present in the congested Class B and C terminal airspace that could have been impacted just as easily by the Ninja flight. I never debated that Ninja flight recorded a speed of 450 knots during the flight. I'm simply saying that the speed that really matters is the speed immediately prior to the collision. That conclusion is debatable. If we're discussing time to deconflict, we'd need to know at what point the Ninja flight achieved 450 knots. I have not seen any claim other than yours that Ninja was knocking down 450 knots within that critical interval. And you are clearly selecting your data to put your argument in the best possible light. Perhaps. At any rate, I commend you for taking the time to analyze all the data available. That has to be an enlightening experience. And I'm reassured that by the limited discrepancies you have provided, the vast majority of what I have said is correct. Similarly, the fact that closure rate was 480 knots of course has meaning in terms of how much time was available to both pilots to see and avoid. But to imply or suggest that this is in any way the same as saying that Ninja was making almost 500 knots at impact is a blatant lie. That conclusion is dependent on malice of intent, which I feel is unwarranted, and unsupported by the facts. We just choose to interpret the facts differently. |
Jeff Crowell wrote:
Speed of the F-16 at impact was 356 KCAS. Larry Dighera wrote: Limiting the discussion to your 356 KCAS speed at the time of impact figure disregards this fact: http://www.ntsb.gov/NTSB/brief2.asp?...A028A &akey=1 "Speeds of up to 450 knots were noted during the descent." Why would you overlook that 450 knot speed? Does the F-16 Dash 1 only pertain to the speed at time of impact? :-) Jeff Crowell: Somewhere during the entire flight, Ninja 2's speed might easily have been supersonic; Larry Dighera: Perhaps. But any speed in excess of the minimum safe speed is a violation of regulations below 10,000'. Of course. But hardly a smoking gun. would that have had any influence on the collision? (other than the cosmic scheduling of it all-- obviously, anything which might have occurred to either F-16 or Cessna to speed or delay their movements throughout their respective flights that day would have prevented this tragedy). Seen that way, if Ninja had gone even a little faster then this would have been nothing more than a close miss. That analysis disregards the fact that there were other aircraft present in the congested Class B and C terminal airspace that could have been impacted just as easily by the Ninja flight. But they were not, were they? I never debated that Ninja flight recorded a speed of 450 knots during the flight. I'm simply saying that the speed that really matters is the speed immediately prior to the collision. That conclusion is debatable. If we're discussing time to deconflict, we'd need to know at what point the Ninja flight achieved 450 knots. For starters, if the accident investigation report does not specifically say that the 450 knot speed phases of the flight were not a proximate cause of the mishap, we can be sure it was not. I have not seen any claim other than yours that Ninja was knocking down 450 knots within that critical interval. And you are clearly selecting your data to put your argument in the best possible light. Perhaps. At any rate, I commend you for taking the time to analyze all the data available. That has to be an enlightening experience. Excuse me? Care to say what you mean here? And I'm reassured that by the limited discrepancies you have provided, the vast majority of what I have said is correct. That would be just one more example of you making a conclusion that is not supported by facts. I have been attempting to limit our discussion to a limited set of data so that it is easier to keep up. Similarly, the fact that closure rate was 480 knots of course has meaning in terms of how much time was available to both pilots to see and avoid. But to imply or suggest that this is in any way the same as saying that Ninja was making almost 500 knots at impact is a blatant lie. That conclusion is dependent on malice of intent, which I feel is unwarranted, and unsupported by the facts. We just choose to interpret the facts differently. "Malice of intent"? You are convinced, in the face of data to the contrary (and with no data in support), that the mishap pilot got up with the specific intention of killing a civil air pilot that day. You cast away entire chunks of data from the mishap investigation report just because they do not fit with your preconceived notion. Jeff |
UBL wants a truce - he's scared of the CIA UAV | John Doe | Aviation Marketplace | 1 | January 19th 06 08:58 PM |
The kids are scared, was Saddam evacuated | D. Strang | Military Aviation | 0 | April 7th 04 10:36 PM |
Scared and trigger-happy | John Galt | Military Aviation | 5 | January 31st 04 12:11 AM |
