Just a question for a fighter pilot, what amount of fuel in
minutes is normally on board when you begin a terminal penetration? If you have good position and radio contact, how long does it take to get a tanker hook-up? Since 9/11, how much fighter cover traffic is in civil airspace that wasn't there before?[general terms, nothing classified] If ATC is slow with a clearance, are you expected to punch out? "Larry Dighera" wrote in message ... | On Mon, 31 Jul 2006 07:59:18 -0600, "Jeff Crowell" | wrote in :: | | Larry Dighera wrote: | I would have to see examples of hyperbole to be able to find facts | that support those statements. | | also Larry Dighera: | You've got to agree, that rocketing through congested | terminal airspace at 500 knots without the required ATC clearance, | | If you speak here of the Florida mishap, there's your example-- | the CLOSURE rate was near 500 knots, but not the speed of | the USAF aircraft. | | Just to assure that we are all both aware, the definition of | 'hyperbole' is: extravagant exaggeration. | | | The USAF Accident Investigation Board's report: | | 1. "Based on their closure rate of approximately 480 knots," ... | | 2. "Speeds of up to 450 knots were noted during the | descent." | | Based on 1 above, you are the one who has exaggerated the closing | speed by 20 knots, but we are both human after all. | | Based on 2 above, I am guilty of exaggerating the top speed the Ninja | flight reached by 50 knots. I don't classify ~11% as _extravagant_ | exaggeration; rather it is my poor recollection of an event that | occurred nearly six years ago. In any event, I apologize for my | error, but I do not see how it may have affected the conclusions I | reached. | | And since he was not aware that he was in terminal airspace | (per a cite you named), there's a deliberate misstatement | to boot. | | The USAF Accident Investigation Board's report: | | "Ninja flight's mistake was in transitioning to the tactical | portion of their flight too early, unaware that they were in | controlled airspace." | | That was President, Accident Investigation Board Robin E. Scott's | opinion. It is not fact. | | Despite the fact that Parker failed to brief terminal airspace prior | to the flight as regulations require, I personally find it difficult, | if not impossible, to believe Parker was unaware, that the 60 mile | diameter Tampa Class B terminal airspace lay below him at the time he | chose to descend below 10,000' into it. | | Immediately prior to that descent, he was attempting to contact ATC | for clearance to enter Tampa Class B airspace, but failed to make | contact, so he continued his descent into Tampa Class B airspace. If | he were unaware he was over the 60 mile diameter terminal airspace, | what reason would he have had to contact Tampa Approach? Surely | Parker could see the busy international airport below him. So, while | my statement is at odds with the AIB report, I believe it is more | accurate. | | If you disagree, I welcome your explanation of how a competent pilot | can possibly be unaware of a 60 mile wide swath of congested terminal | airspace (and that doesn't even include the Class C to the south of | the Class B) that is located immediately north of the MTR start point. | | | I am unable to find any reasonable excuse for what Parker did. It was | a clear day. He was descending into Class B airspace, canceled IFR, | and dove his flight of two into the terminal airspace at twice the | speed limit imposed on all other aircraft in that airspace without ATC | clearance. He may have lost situational awareness, but I find it | impossible to believe he didn't know that continuing his descent would | put him within Class B airspace without a clearance and without | communications with ATC. That's against regulations. | | His nav system position error was sufficient that he was not | aware he was entering terminal airspace. | | The USAF Accident Investigation Board's report: | | "The error was such that following INS steering to a selected | point would place the aircraft 9-11 NM south of the desired | location" | | In other words, Parker's INS steering erroneously lead him to believe | he was located 9-11 miles north of his true position, because his | flight was southbound at the time. That means, that Parker could not | have thought he had past terminal airspace, and the AIB report | indicates that he believed he was approaching the MTR start point | prior to his descent below 10,000'. The error works against the | theory that it excuses Parker's decisions. | | What about that do you not understand? | | You need to re-read that portion of the AIB report dealing with the | INS error that miraculously occurred immediately before his descent. | There was no error earlier in his flight. Read the report, and cite | the portion that contradicts my analysis, if you don't concur. | | Or do you simply refuse to believe it because it isn't convenient? | | I refuse to believe your analysis of the effect Parker's INS error | had, because it isn't logical. You need to take the time to | OBJECTIVELY re-analyze that portion of the AIB report. | | Per the F-16 Dash 1 he was allowed to be at 350 knots at | that altitude, and was traveling only slightly faster at the time | of the collision. What about that statement (from the | accident investigation) do you not understand? | | Jeff, I understand that 450 knots within congested terminal airspace | is about one third faster than the 350 knot speed limit you state | above. One third is not 'slightly faster'. It is _significantly_ | faster. (The 450 knot figure is quoted from the AIB report at the | beginning of this follow up article.) Perhaps you can provide the | reasoning you used in arriving at your conclusion. | | Incidentally, what is the 'F-16 Dash 1'? Is it the aircraft operation | manual, that provides information regarding minimum speeds for various | flight regimes? | |
On Mon, 31 Jul 2006 20:33:06 -0500, "Jim Macklin"
wrote: Just a question for a fighter pilot, what amount of fuel in minutes is normally on board when you begin a terminal penetration? If you have good position and radio contact, how long does it take to get a tanker hook-up? By regulation you need 20 minutes remaing at the initial approach fix. If weather conditions require an alternate, you need time to go from IAF to the alternate IAF plus 20 minutes. In typical, daily, local airfield operations with a VFR recovery planned, you will have about 20 minutes left when you begin your descent along the recovery route. Tankers are not normally an option. Tankers are not usually co-located with tactical bases. Schedules for tankers and coordination of required airspace blocks takes considerable time--days usually. Unlike carrier operations where tankers often sit deck alert to pass a few thousand pounds of gas to an emergency aircraft, for USAF tactical aircraft, tankers are not routinely available. Since 9/11, how much fighter cover traffic is in civil airspace that wasn't there before?[general terms, nothing classified] "fighter cover traffic"?? Dunno what that means. If you mean CAP related to homeland security, I would say not more than 50-100 sorties per day. The majority of US military air traffic is routine training operations around the country. Pilot training, operational qualification training, currency training, etc. It virtually all takes place in joint use airspace and is always done with an ATC flight plan. It is almost always done under IFR. It is 99.9% in "controlled airspace" since there is very little uncontrolled airspace in the country. If ATC is slow with a clearance, are you expected to punch out? No, you are expected to operate as you indicated on your flight plan using common sense and whatever is available to you. There are detailed procedures, for example, regarding how to deal with radio failure in flight both VFR and IFR in both VMC and IMC. Let's get over Larry's fixation that military pilots simply gad about the country ejecting when it suits them or their day is turning unpleasant. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
On Tue, 01 Aug 2006 13:04:10 GMT, Ed Rasimus
wrote in :: there is very little uncontrolled airspace in the country. Actually, there is quite a bit of Class G airspace in the US. It's ceiling is just 700' or 1,200' AGL. |
![]() "Larry Dighera" wrote in message news ![]() Actually, there is quite a bit of Class G airspace in the US. It's ceiling is just 700' or 1,200' AGL. Or higher. Over parts of lakes Michigan and Superior and the upper peninsula of Michigan there is an area of Class G airspace up to 2600 MSL and several areas up to 14,500 MSL. |
On Tue, 01 Aug 2006 14:41:11 GMT, Larry Dighera
wrote: On Tue, 01 Aug 2006 13:04:10 GMT, Ed Rasimus wrote in :: there is very little uncontrolled airspace in the country. Actually, there is quite a bit of Class G airspace in the US. It's ceiling is just 700' or 1,200' AGL. That's very true, but try to go from one town to another without transiting controlled airspace. Uncontrolled airspace allows farmer Brown to fly around the property and count his cows, but not much more. Consider also that in most areas flying below 1500' is prohibited. 500' in "other than congested areas" is allowable, but you'd be surprised how few buildings it takes for the FAA to consider it congested. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
Actually, there is quite a bit of Class G airspace in the US. It's ceiling is just 700' or 1,200' AGL. Excellent! Just right for low level nav training routes. ; Jack |
![]() Larry Dighera wrote: Actually, there is quite a bit of Class G airspace in the US. It's ceiling is just 700' or 1,200' AGL. Come on out West, we have lots of class G and you are not limited to a measly 1200 AGL. |
On Wed, 02 Aug 2006 15:40:54 -0600, Newps wrote
in : Larry Dighera wrote: Actually, there is quite a bit of Class G airspace in the US. It's ceiling is just 700' or 1,200' AGL. Come on out West, we have lots of class G and you are not limited to a measly 1200 AGL. I am out west, southern California. Not much Class G above 1,200' around here. |
UBL wants a truce - he's scared of the CIA UAV | John Doe | Aviation Marketplace | 1 | January 19th 06 08:58 PM |
The kids are scared, was Saddam evacuated | D. Strang | Military Aviation | 0 | April 7th 04 10:36 PM |
Scared and trigger-happy | John Galt | Military Aviation | 5 | January 31st 04 12:11 AM |
