Rotax 582 Tach Problem
Old August 3rd 06, 08:19 AM posted to rec.aviation.homebuilt
karel
Default Rotax 582 Tach Problem
Luo, thank you for the reply. I have just installed a new battery
(before tach problem began). It is still a 12 volt battery but has
more cranking amps than the previous battery. I do see on the volt
meter that when the engine is running that the volts are at 15 volts.
this is not normal. 15 volts is really too much,
you will fry more things than tachometers.
check the alternator/regulator
and check your voltmeter
Transmittion Noise - High Power Settings Paul Smedshammer Owning 6 August 20th 05 06:17 PM
Wayward Tach O. Sami Saydjari Owning 7 February 6th 04 01:27 AM
Tach Vs. Hobbs Time John Roncallo Owning 33 January 7th 04 12:42 AM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 09:10 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 09:10 PM
