barrel roll in 172
Old August 3rd 06, 06:46 PM posted to rec.aviation.piloting
Stefan
Default PED barrel roll in 172
Jim Macklin wrote:
But if an airplane
can roll to 60 degree bank it can be held in the roll and it
will become inverted and then because of the inertia
continue back to upright.
Not necessarily, and certainly not because of the inertia.
If you stop inverted you will
have problems because most engines will quit after a short
while, you might have some reduced aileron control and you
probably didn't hold forward elevator so you split S'd out
and roll control was returned.
Or more likely, if done accidentally ("didn't hold forward elevator"),
the airplane broke because of overload.
You should cease to spread dangerous wisdom about things you don't
understand. (As well as cease to top post.)
Stefan
(Removed PED, because this isn't.)
Old August 3rd 06, 08:00 PM posted to rec.aviation.piloting
Jim Macklin
I think Bill Gates like top posting, why should I change to
satisfy you?
Perhaps you don't know what you're talking about either?
James H. Macklin
ATP,CFI,A&P
"Stefan" wrote in message
| Jim Macklin wrote:
| But if an airplane
and it
short
you
out
elevator"),
you don't
| Stefan
Old August 5th 06, 07:23 AM posted to rec.aviation.piloting
Dave Doe
In article l4sAg.84945$ZW3.9567@dukeread04, p51mustang[threeX12]
@xxxhotmail.calm says...
satisfy you?
follow
to
hard
very
thread
makes
It
Duncan
Old August 5th 06, 09:23 AM posted to rec.aviation.piloting
Anno v. Heimburg
satisfy you?
A. Because it makes the thread hard to follow.
Q. Why is top posting frowned upon?
And what does Bill Gates have to do with that?
Old August 5th 06, 02:17 PM posted to rec.aviation.piloting
Matt Whiting
Anno v. Heimburg wrote:
satisfy you?
He's dyslexic.
Matt
Old August 8th 06, 01:08 PM posted to rec.aviation.piloting
Dylan Smith
On 2006-08-05, Anno v. Heimburg wrote:
satisfy you?
Also, interleaved quoting (AND trimming quotes) is called netiquette -
the manners of Usenet. Transplanted to real life, "I think Bill Gates
like top posting, why should I change to satisfy you?" could become:
"I think the airlines like straight in approaches. Why should I enter
the pattern on a 45 to downwind just to satisfy you?"
"It's too much effort to wait three seconds to hold the door open for
the person following. Why should I wait three seconds just to satisfy
them?"
"Why should I say please and thank you? Some _insert rich person here_
gets by quite OK being extremely rude, so why should I change to satisfy
you?"
"Why should I move over to the right lane? Why should I leave my
comfortable rolling roadblock position just to satisfy you?"
Additionally, top posting costs people money. Top posters usually don't
trim their quoted material which can get quite long after a while. Those
reading Usenet when they are passing time in the airport, using their
cell phone, have to pay per kilobyte.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old August 8th 06, 03:10 PM posted to rec.aviation.piloting
Jose[_1_]
That's one place where I disagree - top posting saves money.
Although there may be a correlation between top posters and post
trimming, it is the post non-trimming that costs money (to others), not
the top posting. Actually, top posting saves money for those who, after
reading your comments, don't need to read what you were referring to
(because they remember it), and therefore don't need to download it KB
by KB. It's available however for those who need a reminder. For a
bottom posted message, one must download (often repeatededly) a message
one has already read (or at least parts of it) before getting to =any=
new stuff; that is wasteful of costly KB.
Sometimes top posting is good, sometimes bottom posting is good.
Usually interleaving is best. But there are never any absolutes.
Jose
Old August 18th 06, 10:26 AM posted to rec.aviation.piloting
Dylan Smith
by KB.
News readers don't work like that unfortunately. When you select an
article, the reader downloads the *whole* article, not just the bits of
it you are reading. Therefore, a top post with an untrimmed set of
quotes (usually, when top posters reply to top posters, you get an
enormously long history of quoted material at the bottom). Unless the
top poster trims the quoted material (which almost none of them do), you
end up downloading their 5 line comment along with 300+ lines of quotes.
The only occasion where someone reading Usenet would only download a bit
of the article they are reading is if they are reading Usenet over an
ssh connection to a remote server. However, the latency over GPRS is so
bad, this is quite painful - so anyone reading Usenet using a mobile
device will almost certainly use a news reader on their mobile device
rather than an ssh connection to a remote system.
Old August 18th 06, 03:46 PM posted to rec.aviation.piloting
Jose[_1_]
it you are reading.
This is not true for all software that accesses Usenet. My palm VIIx
(rest in peace) did it a K at a time. My cell phone does the same, but
even slower. (it's a perfectly awful way to read Usenet, so I don't do
it, but that's irrelevant).
Then your objection is =not= to top posting, but to non-trimming.
Non-trimming is more painful in a bottom posted article - at least with
a top posted article, once I come to the end of the original material, I
can move on.
While your association of top posters with non-trimmers may be valid, it
is irrelevant. I've seen many bottom posters who add five lines to a
300+ line quote (and far too many nested quoting that ends up being 300
lines repeated for the most part post after post - supposedly good
netiquette taken to the extreme - feh!)
Jose
Old August 18th 06, 09:24 PM posted to rec.aviation.piloting
Roger[_4_]
On Fri, 18 Aug 2006 09:26:27 -0000, Dylan Smith
by KB.
Bottom posters do the same thing:-))
www.rogerhalstead.com
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 04 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 July 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 June 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 08:27 AM
