Missing flight plans
Old August 4th 06, 01:12 AM posted to rec.aviation.piloting,rec.aviation.owning
Wizard of Draws[_1_]
Default Missing flight plans
On 8/3/06 3:57 AM, in article ,
"Michelle" wrote:
"Wizard of Draws" wrote in
message news:C0F6CE43.89355%jeffbREMOVETHIS@REMOVEALSOwiza rdofdraws.com...
Some time ago on a cross-country that took me near, not into,
Chattanooga's
airspace, I notified them where I was as a courtesy. They gave me a code
to
squawk. After I was well clear of their airspace, they told me to resume
own
navigation. Fat, dumb and happy, I squawked 1200 and went on to land at my
home base. After I hanging out a bit, the airport manager came up to me
and
chewed me out for not closing my flight plan. I guess Chattanooga opened
one
for me.
You were on a cross-country without a flight plan?
Michelle S.
Yes I was, although I'll admit I file IFR for every flight nowadays.
Why do you ask?
Jeff 'The Wizard of Draws' Bucchino
Cartoons with a Touch of Magic
http://www.wizardofdraws.com
More Cartoons with a Touch of Magic
http://www.cartoonclipart.com
Old August 4th 06, 03:14 PM posted to rec.aviation.piloting,rec.aviation.owning
Michelle
message news:C0F80936.89C12%jeffbREMOVETHIS@REMOVEALSOwiza rdofdraws.com...
message
Chattanooga's
to
own
my
and
one
for me.
Michelle S.
Why do you ask?
Let me answer your question with another question: why do you file all the
time (why only IFR) now and not then?
As to your question, it just seems so "unprofessional" and I think
unprofessional conduct by pilots is a big part of the reason GA has such a
higher accident rate than cars, and private pilots have the highest rates
among their pilot brethren.
Michelle
Old August 4th 06, 03:37 PM posted to rec.aviation.piloting,rec.aviation.owning
Peter R.
Just to clarify, in your opinion, not filing a VFR flight plan is
"unprofessional?"
Peter
Old August 6th 06, 04:18 PM posted to rec.aviation.piloting,rec.aviation.owning
Michelle
"Peter R." wrote in message
a
"unprofessional?"
"Yes", I think so...amongst other behavioral patterns.
Michelle
Old August 15th 06, 03:12 PM posted to rec.aviation.piloting,rec.aviation.owning
Gig 601XL Builder
"Michelle" wrote in message
a
rates
"unprofessional?"
Michelle
I was about to answer your question that you asked above Michelle but you
did it yourself.
Your statement was.. No VFR Flight Plan=Unprofessional=Higher accident rate
Please explain now how the failure to file a VFR flight plan causes
accidents.
Old August 15th 06, 08:11 PM posted to rec.aviation.piloting,rec.aviation.owning
Michelle Settle
"Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message
such a
rates
"unprofessional?"
Michelle
did it yourself.
rate
accidents.
Please explain where I made the statement you attribute to me.
Do you have the slightest grasp of what "professionalism" connotes?
Michelle
Old August 15th 06, 10:30 PM posted to rec.aviation.piloting,rec.aviation.owning
Gig 601XL Builder
"Michelle Settle" wrote in message
such a
rates
"unprofessional?"
Michelle
did it yourself.
rate
accidents.
Michelle
I doubt the underlining will work but here you go.
such a
rates
"unprofessional?"
Old August 15th 06, 03:39 PM posted to rec.aviation.piloting,rec.aviation.owning
The Visitor
"unprofessional?"
Me too. But I wouldn't have been gutsy enough to say so.It's usually one
area person slacks of in after he has started to slack of on other
areas, but can justify it somehow. The pilot often thinks a spouse or
other person will know exactly what to do if they are overdue. And
somehow magically know when they are overdue.
Old August 15th 06, 03:55 PM posted to rec.aviation.piloting,rec.aviation.owning
Gig 601XL Builder
"The Visitor" wrote in message
"Peter R." wrote in message Just to clarify, in your
"unprofessional?"
area person slacks of in after he has started to slack of on other areas,
but can justify it somehow. The pilot often thinks a spouse or other
person will know exactly what to do if they are overdue. And somehow
And do you have some data to back this up?
Old August 15th 06, 08:19 PM posted to rec.aviation.piloting,rec.aviation.owning
The Visitor
As much as you do to refute it.
It is based on my personal observations. And the people I refer to
really don't know much of what they are screwing up.
I see people worried because someone is thought to be over-due and they
know he doesn't have a flight plan. (grow up, don't leave that kind of
burden hanging around for your wife or friends, leaving them wondering
and unsure.)
You wanted to lure Michelle into the argument that, no flight plan
causes accidents, but that is a joke.
What is in-escapable is the correlation between the two.
And the correlation between flight planning and fewer accidents.
Why?
Complete flight planning is one of the earmarks of a conscientious
pilot. And conscientious pilots are generally going to be safer in their
flying and more likely to keep honing or truly maintaining their skills,
rather than thinking idle flying makes them a good pilot. That's just
how it is.
I have met many an ego, err I mean "eagle" who is very weak at flight
planning. Could barely even file a flight plan as it has been 10 plus
years. Weather, nope. So they use the weather channel or phone the
destination. I see some of them land hot, porpoise and smoke the brakes.
They know how to get flight following and talking to atc makes them
think they are good pilots. I see them cut others off, and it is okay to
them because they have been doing it for years. But they really do enjoy
the ride.
They mean well and in their mind they are working hard at it, so feel
they must be good at it. It is easy to give yourself good marks.
Especially when you are in an environment where there is no real
yardstick beside you.
Sure it is possible to be an excellent pilot and choose to not to file a
flight plan or itinerary. But that is pretty irresponsible, so I
withdraw the use of the word excellent.
There is never 'one' cockroach.
DUATS & Canadian Flight Plans Andrew Sarangan Piloting 2 November 7th 05 08:51 PM
Third Military-Civil MAC Jan. 18, 2005 Larry Dighera Piloting 37 February 14th 05 03:21 PM
Aerial PHotography Flights 'Required' to File Flight Plans C J Campbell Piloting 15 December 6th 04 02:17 PM
