Instrument Approaches in High Winds
Old August 4th 06, 04:05 AM posted to rec.aviation.ifr
Andrew Sarangan[_1_]
Default Instrument Approaches in High Winds
I guess what I was trying to say was those who live in less windy areas
tend to think of the "demonstrated crosswind" are a real limitation.
Matt Whiting wrote:
Andrew Sarangan wrote:
Jim Macklin wrote:
Come to Kansas for a few days, any time of the year. We
often have winds that are 25G40, most of our runways are
pretty well laid out, but some airports do require a
crosswind landing. Of course, we routinely solo students as
long as the wind is less than 25 knots and the gusts are
minimal. But since this is Kansas, where the wind comes
sweeping down the plains, we often can have a solid day or
two of steady 25 to 40 knot winds. Our bad weather starts
at 60 knots with 2 inch hail (a golf ball is 1-3/4 inch).
One day I remember watching the airliners land. It was calm
and they all were landing very long, those calm winds are a
real problem.
James H. Macklin
ATP,CFI,A&P
That was exactly my observation too when I lived in Albuquerque. I used
to solo students at 25 knots. When I moved east, I got all kind of
weird looks and comments like "test pilot" and "against the aircraft
certificaton" etc.. when I tried to send students in more than 10
knots.
If the 25 knots was orthogonal to the runway, then I understand the
weird looks. If it was a headwind aligned with the runway, then not a
big deal. Taxiing might be a little interesting if the trainer is a
C152, but landing should be easy ... and very short!
Matt
Old August 4th 06, 07:08 AM posted to rec.aviation.ifr
Jim Macklin
Yes, they do think that. It is a fact that was just as much
wind as was blowing the day they did the proving test for
certification. The FAR 23 sets a minimum wind as a function
of stall speed, but with proper technique the actual limit
is much higher. Just to make the point, if the runway is
3,500 x 150 feet and the crosswind is 40 knots, you can land
at an angle on the runway, reducing the crosswind component.
James H. Macklin
ATP,CFI,A&P
"Andrew Sarangan" wrote in message
windy areas
limitation.
We
are
students as
are
comes
day or
starts
inch).
was calm
are a
| real problem.
| James H. Macklin
| ATP,CFI,A&P
Albuquerque. I used
all kind of
more than 10
| knots.
understand the
runway, then not a
trainer is a
| Matt
Old August 5th 06, 08:22 PM posted to rec.aviation.ifr
Roger (K8RI)
On Fri, 4 Aug 2006 01:08:10 -0500, "Jim Macklin"
The maximum demonstrated cross wind component for the Debonair I fly
is 12 knots. It is quite capable of handeling a direct (90 degree)
cross wind of 25 knots. That BTW is both its limit and my limit (when
I've been practicing and am proficient).
The 150s I've flown could handle at least that much, but it took far
more skill to handle them in strong cross winds than it does the Deb.
They are much ligher with far less inertia and react much more quickly
to the wind changes.
My first cross long cross country was in winds that at times reached
30 knots and I had at least a 15 knot, 90 degree cross wind at the
first landing. I took the approach (no pun intended) that I would give
it a try but I didn't have to land and would only do so if every thing
went well. It did.
Flying in high winds is not at all uncommon in the Mid West and
particularly the Great Planes states. If you really want winds use
the airports just off the "Front Range". OTOH They consider less than
75 miles poor visibility while the Great Lakes states consider 1500
and three great VFR.
Any one remember how the story goes about the pilot from the Great
Lakes and the one from out West feeling their way around a hangar in
fog and 10 knot winds or something like that?
www.rogerhalstead.com
Old August 6th 06, 04:14 AM posted to rec.aviation.ifr
Mark Hansen
They both agreed that what they were feeling was an elephant, right?
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old August 4th 06, 11:20 AM posted to rec.aviation.ifr
Matt Whiting
Yes, that is true. I learned at a mountaintop airport in PA with an
east/west runway, but with a large valley (called the PA Grand Canyon)
that runs north/south just southwest of the airport that channels the
prevailing west wind into a north of south wind right across the runway.
The only crosswind limitation I was taught was running out of rudder.
and even then, you could land on the grass strip as it would take a
little bit of lateral misalignment at touchdown.
I don't know what the limit for a Skylane is, but I've landed in 18K
crosswinds before. Since I never crashed it, I don't really know the
limit. :-)
Matt
Definition of simulated instrument conditions bsalai Instrument Flight Rules 14 February 4th 06 11:33 PM
Cleared for an approach, then given a different altitude assignment Peter R. Instrument Flight Rules 42 December 11th 04 04:44 PM
Tips on Getting Your Instrument Rating Sooner and at Lower Cost Fred Instrument Flight Rules 21 October 19th 04 07:31 AM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
Logging instrument approaches Slav Inger Instrument Flight Rules 33 July 27th 03 11:00 PM
