On Fri, 04 Aug 2006 16:01:36 GMT, Jose
wrote: Every flight, every day, by the military is on a flight plan. Even those flights on VFR MTRs? Yes. Does ATC track those flights in real time, at least with non-radar position reporting? If so, then ATC should be able to provide better information that a civilian pilot could use to determine whether or not to transition a route at a particular point at a particular time. See the post to LD regarding what a flight plan is. Departures are conducted under ATC. Recoveries are conducted under ATC. Training time along an MTR, within a MOA, in restricted airspace, or on a range is usually done without ATC involvement. If your hypothetical civilian pilot wants ATC to provide him safe separation from other IFR aircraft, he/she should file an IFR flight plan, obtain an IFR clearance, and operate in controlled airspace under ATC's control. They should also look out the window as best they can. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
UBL wants a truce - he's scared of the CIA UAV | John Doe | Aviation Marketplace | 1 | January 19th 06 08:58 PM |
The kids are scared, was Saddam evacuated | D. Strang | Military Aviation | 0 | April 7th 04 10:36 PM |
Scared and trigger-happy | John Galt | Military Aviation | 5 | January 31st 04 12:11 AM |
