"Peter Duniho" wrote: In addition to Jon's nice explanation of DME, I'd like to point out that because DME is an active receive-and-reply system, it can get saturated when too many aircraft are using the same DME site. A pilot using DME in busy airspace should keep this in mind, in case some funny numbers start getting spit out, or the DME just stops giving any indications. I admit, I've never actually seen this happen, but it is theoretically possible. Interesting. I hadn't thought about the interrogator before. But It's more likely that the ground station will reduce the sensitivity to the point that it doesn't transmit that many replies - thereby reducing the probability the DME will be listening to a reply intended for someone else. For a DME interrogator that already acquired the ground station and is tracking, it's extremely unlikely that its tracking algorithm will drift off. Remember that the interrogations are psuedorandom, there are only 30 interrogations per second (IIRC), and they are short. -- Bob Noel Looking for a sig the lawyers will hate |
"Bob Noel" wrote in message
... Interesting. I hadn't thought about the interrogator before. But It's more likely that the ground station will reduce the sensitivity to the point that it doesn't transmit that many replies - thereby reducing the probability the DME will be listening to a reply intended for someone else. That would cause the DME in the airplane to stop providing DME information, which is one of the consequences I mentioned. I admit, I wasn't precise about which "DME" would stop giving nay indications...it's the one in the airplane I was talking about. For a DME interrogator that already acquired the ground station and is tracking, it's extremely unlikely that its tracking algorithm will drift off. Remember that the interrogations are psuedorandom, there are only 30 interrogations per second (IIRC), and they are short. I agree it's less likely you'll get erroneous data from the DME. It'd be a pretty rare situation in which that happens, assuming it has ever happened at all anywhere. My main point is just that pilots should be aware of the limitations of DME (I guess we could mention slant-range here too, but I think we were just talking about the radio signal itself? I've lost track ![]() Pete |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Night bombers interception in Western Europe in 1944 | Bernardz | Military Aviation | 205 | July 22nd 04 05:31 PM |
