Missing flight plans
Old August 5th 06, 01:27 AM posted to rec.aviation.piloting,rec.aviation.owning
Jim Logajan
Default Missing flight plans
Bob Noel wrote:
"Michelle" wrote:
As to your question, it just seems so "unprofessional" and I think
unprofessional conduct by pilots is a big part of the reason GA has
such a higher accident rate than cars, and private pilots have the
highest rates among their pilot brethren.
A flight plan on file will reduce accidents? Please explain.
Perhaps it's an issue colloquially known as "mindset?" Not saying that's
the argument being attempted, but I could see the idea being somewhat
plausible.
  #52
Old August 5th 06, 03:09 AM posted to rec.aviation.piloting,rec.aviation.owning
Wizard of Draws[_1_]
On 8/4/06 10:14 AM, in article ,
"Michelle" wrote:
Yes I was, although I'll admit I file IFR for every flight nowadays.
Why do you ask?
Let me answer your question with another question: why do you file all the
time (why only IFR) now and not then?
unprofessional conduct by pilots is a big part of the reason GA has such a
higher accident rate than cars, and private pilots have the highest rates
Michelle
That day was CAVU and I wanted the option of going where I pleased.
Additionally, I wasn't instrument rated at the time. But now, since I spent
all that money on the rating, I want to get my money's worth. I'm looking
for clouds now. In fact, I want to fly through them as much as possible and
get annoyed when it's CAVU and I'm flying. Plus, I need as much practice
working within the system as possible to stay safe.
I'm not sure how a flight plan would have prevented an accident. Can you
explain your reasoning behind that conclusion?
How does filing a flight plan equate to professionalism?
Jeff 'The Wizard of Draws' Bucchino
Cartoons with a Touch of Magic
http://www.wizardofdraws.com
More Cartoons with a Touch of Magic
http://www.cartoonclipart.com
  #53
Old August 5th 06, 03:36 AM posted to rec.aviation.piloting,rec.aviation.owning
Emily[_1_]
Wizard of Draws wrote:
snip
I'm not sure about preventing an accident, but since I rarely have
anyone that knows or cares where I am, I like to let flight service know
what my plans are.
Of course, now I just file IFR...but before that, I usually did file
VFR. I didn't want to crash/land somewhere and have no one miss me
until I starved or froze to death.
  #54
Old August 5th 06, 04:31 PM posted to rec.aviation.piloting,rec.aviation.owning
Mark Hansen
On 08/04/06 16:33, Newps wrote:
Mark Hansen wrote:
Just to clarify, what I mean is can you show the regulation which states
that ATC is required to begin search and rescue operations if they lose
radio contact with an airplane that was on flight following.
Absolutely. Knock yourself out.
http://www.faa.gov/ATPubs/ATC/index.htm
So, you're answer is "no". Got it. Thanks,
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
  #55
Old August 5th 06, 04:45 PM posted to rec.aviation.piloting,rec.aviation.owning
Anno v. Heimburg
Actually, had you invested 5 minutes, you would have found:
"10-2-5. EMERGENCY SITUATIONS
Consider that an aircraft emergency exists and inform the RCC or ARTCC and
alert the appropriate DF facility when:
b. There is unexpected loss of radar contact and radio communications with
any IFR or VFR aircraft.
http://www.faa.gov/ATPubs/ATC/Chp10/atc1002.html#10-2-5
Anno.
  #56
Old August 5th 06, 08:05 PM posted to rec.aviation.piloting,rec.aviation.owning
Newps
Exactly.
  #57
Old August 6th 06, 04:23 AM posted to rec.aviation.piloting
Mark Hansen
That says "loss of radar *AND* radio". My question was with a loss of
radio contact only.
Anno.
Sacramento, CA
  #58
Old August 6th 06, 04:13 PM posted to rec.aviation.piloting,rec.aviation.owning
Michelle
"Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message
"Michelle" wrote in message
a higher accident rate than cars, and private pilots have the highest
How exactly Michelle will filing a VFR flight plan reduce the accident
rate in aircraft? As since you mentioned it, do you file a drive plane
when you drive a car?
Do you always put not only words but entire paragraphs in peoples mouths?
In any case, let's hear it from the real pros (the people that get paid to
fly): How often do you conduct a flight without a flight plan?
How many of you take off without a pretty through pre-flight of the
aircraft.
Here's the point: I never said, or even intimated that not filing a flight
plan caused a crash; the point is the attitude and approach that proc take
that the amateurs do not.
Michelle S.
  #59
Old August 6th 06, 04:15 PM posted to rec.aviation.piloting,rec.aviation.owning
Michelle
"B A R R Y" wrote in message
On Fri, 4 Aug 2006 11:50:54 -0500, "Gig 601XL Builder"
rate
in aircraft?
Not only will it not prevent a single accident,
Please point out where I said it would prevent an accident.
I don't see the value
of a VFR flight plan for other reasons in many cases.
Such as? Please!
Michelle
  #60
Old August 6th 06, 04:18 PM posted to rec.aviation.piloting,rec.aviation.owning
Michelle
"Peter R." wrote in message
a
Just to clarify, in your opinion, not filing a VFR flight plan is
"unprofessional?"
"Yes", I think so...amongst other behavioral patterns.
Michelle
DUATS & Canadian Flight Plans Andrew Sarangan Piloting 2 November 7th 05 08:51 PM
Third Military-Civil MAC Jan. 18, 2005 Larry Dighera Piloting 37 February 14th 05 03:21 PM
Aerial PHotography Flights 'Required' to File Flight Plans C J Campbell Piloting 15 December 6th 04 02:17 PM
