"Greg Copeland" wrote in message
news ![]() My memory was telling me that Farnsworth Lantern test was preferred to get a waiver. Since that no longer seems possible, I'm looking for options here. I read today that a Dvorine or AOC test is preferred. Can anyone confirm that? Recommend another? Are these tests hard to find? What's available in the Dallas? Obviously, I'd like to try to shop around some of these tests without involving the FAA, before I have to use the light gun test as a last resort. I do suffer from a mild form of deuteranopia. Is there any statistics on the number of pilots with this type of color blindness which have successfully obtained their waiver/exemption? I remember reading, over a year ago, some document from the FAA which gave some statistics, but I no longer remember the break out. Greg I am not a doctor, nor do I play one on TV :-) Actually, my local EAA chapter has had an AME speak a couple of times over the years, and I recall that this subject has been addresses locally be others as well. Some years ago, a friend had the same problem and had to obtain a Statement of Demonstrated Ability (SODA). To the best of my knowledge, the FAA's interest in this matter is limited to your ability to distinguish between the Red, Green, and White of the control tower light gun signals--no other shades or combinations of those or any other colors are of interest for this purpose. Good sources of reliable information should include AOPA, EAA, your friendly local AME and the Safety Program Managers from your local FSDO--who can be reached informally at any of the semenars which they host. Of course, the easiest of all might be to have a local tower controlled shine his light gun your way. If you are in Southeast Florida, I can refer you to a source. Otherwise, start with AOPA or EAA (depending on your membership) or look for the next nearby seminar on http://www.faasafety.gov/SPANS/events.aspx I hope this helps. Peter |
Peter Dohm wrote:
Actually, my local EAA chapter has had an AME speak a couple of times over the years, and I recall that this subject has been addresses locally be others as well. Some years ago, a friend had the same problem and had to obtain a Statement of Demonstrated Ability (SODA). two things: the test that is no longer recognized is the Farnsworth D15, and not the Farnsworth lantern test -- which as far as I know was not in the list of tests approved by the FAA (it was however the prefered test for the British CAA); that said, I would be curious to know why they no longer use the D15; it is actually a pretty good test to identify color vision deficiencies, i.e., much tougher to pass than the light gun test... it seems that the FAA nowdays provides a waiver which is not a SODA; or may be waiver is not the correct term either; what I got is a letter from the FAA that says I did pass one of the approved tests; i.e., if you pass one of the approved alternative tests the FAA considers that you are as good to go as the folks who passed the standard Ishihara one; i.e., there is a difference between a SODA and a waiver (I hold both a SODA and a waiver for two different things :-) -- the SODA I carry with me along with my medical; the waiver I keep at home and only show it to the AME when renewing the medical. of the semenars which they host. Of course, the easiest of all might be to have a local tower controlled shine his light gun your way. ....but when you do so, bring along a friend who: a) you know for sure has no color vision deficiency (you'd be surprised), the safer bet is a female friend (females are far less likely to have color vision problems); b) someone that you actually do trust not to pull your leg...; most folks out there can't help themselves from playing tricks on you if they find out your are color blind and won't call the colors as they see them (it's dumb, but not unusual...); what I found surprising (I have a protanomalous vision) is that I have no problem identifying the red signal, but do confuse the white and green ones... what helped me a lot was to be able to see what the 'white' signal was supposed to look like and then what the 'green' one was supposed to look like; I needed qualibration so to speak :-) then I was able to pass the test. Ideally, find a way to borrow a light gun... talk nicely to the folks of your local tower or FSDO, I found they were more than happy to help. --Sylvain |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
TEST PILOTS ACCOUNT OF INFLITE BREAK UP (SR 71) (LONG) | caleb | Owning | 1 | January 30th 06 05:01 AM |
Post Test Web to Usenet | Guest | Naval Aviation | 0 | April 22nd 05 03:43 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
FAA Knowledge Test Results | Richard Moore | Simulators | 3 | October 12th 03 04:48 AM |
