On Fri, 4 Aug 2006 16:29:56 -0700, "Peter Duniho"
wrote: ".Blueskies." wrote in message m... Excellent, thanks! In addition to Jon's nice explanation of DME, I'd like to point out that because DME is an active receive-and-reply system, it can get saturated when too many aircraft are using the same DME site. A pilot using DME in busy airspace should keep this in mind, in case some funny numbers start getting spit out, or the DME just stops giving any indications. I admit, I've never actually seen this happen, but it is theoretically possible. Pete I can't remember the numbers but a VOR/DME will accept a large number of aircraft before it saturates. Some Terminal DME's are only capable of supporting about 5 or 10 aircraft (only needed for an instrument approach anyway). Since they are short range it's not usually a problem. I have more, than once, lost DME but not usually for long (less than a minute). Mostly at longer range where other aircraft are probably nearer the DME and a stronger signal than me. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Night bombers interception in Western Europe in 1944 | Bernardz | Military Aviation | 205 | July 22nd 04 05:31 PM |
