On Tue, 08 Aug 2006 00:00:46 -0400, Ray Andraka
wrote: Jay Honeck wrote: I don't know why...I've never had a lick of trouble out of any of it. Atlas has two Narco coms, a Narco DME, and two Narco GS/VORs. All work perfectly, all the time. I've not quite figured out where the anti-Narco sentiment come from, but it's almost as insidious as the anti-Microsoft attitudes out there. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Jay, It came from avionics shops that got pretty ****ed at Narco when Narco decided to pull all service into the factory. Narco's reasons for doing it are understandable, and I think make sense, but the avionics shops have never forgiven them for taking away a good chunk of their repair business. Jay, I can give you an indication why they have their reputation! An aircraft owner had Narco in his aircraft and said they were 'now' ok so we took his advice, but... Purchased 2x MK12D+, CPM136, IDME891 approx 3 years ago. The IDME891 (ILS/DME) does not work properly at very low frequencies (around 108.1MHz) the ILS is ok but the DME doesn't always work. The first flight showed a problem but since it was subsequently not used at these frequencies for some time the fault was not discovered for a considerable time. Both MK12D+ NAV/COM had Transmitter audio failures. Apparently it is a known diode failure problem. Now I know what happens when you have a COM failure when overflying a military airfield :-( The latest is a severe dimming of the NAV display and the first digit has failed completely. The CPM136 AF panel produced smoke when COM 2 button pressed. The IDME891 saved us panel space and should be ideal but the intermittent DME reading problem has still to be solved. David |
An aircraft owner had Narco in his aircraft and said they were 'now' ok so we took his advice, but... Awful tale of woe snipped Okay, I'd be plenty ****ed, if that were my plane. I just haven't had any of those problems, thankfully! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Night bombers interception in Western Europe in 1944 | Bernardz | Military Aviation | 205 | July 22nd 04 05:31 PM |
