I am trying to build the Jim Weir/Kitplanes June-06 "Quick and Dirty 12 - 24
Up-Converter." 1. Can D101 and Q101share the same heat sink electrically or must they be isolated? 2. I can not locate a "resistor form." Can R101 be wound around a dowel or other object and installed like a coil with an air core? Thanks, Charlie Willwerth |
![]() "ccwillwerth" wrote in message ... I am trying to build the Jim Weir/Kitplanes June-06 "Quick and Dirty 12 - 24 Up-Converter." Um, that would be the JULY 06 issue. 1. Can D101 and Q101share the same heat sink electrically or must they be isolated? Q101 has its collector tied to the case but D101 has its cathode tied to the case. Sorry, you have to have two heat sinks. 2. I can not locate a "resistor form." Can R101 be wound around a dowel or other object and installed like a coil with an air core? Oh, golly, just get yourself a relatively high value 1/4 or 1/2 watt carbon resistor (say, anything greater than 100 ohms or so) and wind the wire on it. #30 wire will NOT stay put with air core. Sorry, I just assume (bad, bad word) folks know the trick of winding wire on resistors just for the form factor. Solder the wire to the resistor leads right where they come out of the resistor body and then solder the resistor leads into the circuit. Jim |
Thanks Jim, Neat trick about the "resistor form" i learned something new!
Charlie "RST Engineering" wrote in message ... "ccwillwerth" wrote in message ... I am trying to build the Jim Weir/Kitplanes June-06 "Quick and Dirty 12 - 24 Up-Converter." Um, that would be the JULY 06 issue. 1. Can D101 and Q101share the same heat sink electrically or must they be isolated? Q101 has its collector tied to the case but D101 has its cathode tied to the case. Sorry, you have to have two heat sinks. 2. I can not locate a "resistor form." Can R101 be wound around a dowel or other object and installed like a coil with an air core? Oh, golly, just get yourself a relatively high value 1/4 or 1/2 watt carbon resistor (say, anything greater than 100 ohms or so) and wind the wire on it. #30 wire will NOT stay put with air core. Sorry, I just assume (bad, bad word) folks know the trick of winding wire on resistors just for the form factor. Solder the wire to the resistor leads right where they come out of the resistor body and then solder the resistor leads into the circuit. Jim |
KLN to Garmin 396 Converter | Mike Granby | Owning | 7 | February 5th 06 01:48 PM |
FA: 12V to 24V DC voltage converter | Karl Geng, N1DL | Home Built | 2 | April 21st 05 08:48 PM |
AC to DC Converter for APU | Newps | Owning | 8 | November 30th 04 03:41 PM |
24/12 volt DC converter | Victor J. Osborne, Jr. | Products | 1 | February 18th 04 02:11 PM |
Radio Shack 140W DC-to-AC Power Converter - Simple Plug-in | MKB | Owning | 4 | August 4th 03 04:08 PM |
