![]() Bret Ludwig wrote: ... Direct drive VW made sense in 1965. Not today. Use a liquid cooled car engine and a redrive, perhaps a Honda since they are attractively priced as JDM pulls. Have you seen many airplanes flying with liquid cooled car engines and a redrives? How many with Honda engines? Is the CVCC engine better (or worse) for flying than other auto engines? -- FF |
![]() Bret Ludwig wrote: wrote: Bret Ludwig wrote: ... Direct drive VW made sense in 1965. Not today. Use a liquid cooled car engine and a redrive, perhaps a Honda since they are attractively priced as JDM pulls. Have you seen many airplanes flying with liquid cooled car engines and a redrives? A few. How many with Honda engines? Fewer. Is the CVCC engine better (or worse) for flying than other auto engines? The CVCC is rarer than a Lycoming now since the Honda cars made with it are almost all crushed out. I think they discontinued CVCC in the _very_ early eighties. Most Honda mechanics working today have never seen one. You must be a fossil to even remember CVCC. I remember getting 50 mpg while cruising at 60 mph in my 1300cc Civic with the CVCC engine turning about 500 rpm slower than my brother's Toyota Corolla. So I think it was a damn fine fuel efficient high torque at low rpm engine. The point is not what is most common today but what would offer the best prospects for inexpensive, safe flying. Based on that, you recommend that a homebuilder choose an engine for which there is no history of use or support in the aviation communtiy. Compared to sticking with what has proven successful, while avoiding what has not, that sounds expensive and unsafe to me. If safety is the ONLY criterion there is only one way to turn a propeller worthy of consideration, a real aircraft engine: namely, the P&WC PT-6A. Of course, with the caveat that you keep your toes clear when you installit. After all, once the airframe has been crushed by the weight of the engine the plane will never fly. I think your definition of 'real' airplane comes close to excluding every homebuilt airplane that has flown successfully. ... I only suggested Hondas as a possible solution because of reliability and the availability of "midtime" factory assembled engines as JDM pulls, cheap. There may actually be a problem with them but because no one has put much effort into flying them (save, a decade or two ago, the BD-5 guys) we don't know. Most turn "wrong way", but that's not a major issue unless you want to turn a surplus factory prop. Even then a gear drive could fix that. Here I follow you as far what could be a fruitful developement effort. But not a choice for someone who wants to build and fly, without having to re-invent the aircraft engine, eh? -- FF P.S. What's a 'JDM pull'? |
![]() wrote: wrote: wrote: I remember getting 50 mpg while cruising at 60 mph in my 1300cc Civic with the CVCC engine turning about 500 rpm slower than my brother's Toyota Corolla. So I think it was a damn fine fuel efficient high torque at low rpm engine. ------------------------------------------------------------------------ You're comparing apples to oranges. Respectfully, I was comparing the Honda engine with the Toyota engine. ... But it has nothing to do with airplanes. ... That depends on whether or not either one is any good for airplanes. Which as you point out, is probably not the case. He has NO IDEA whether or not Honda car engines would be good or bad for airplanes. The hardcore DIY converters seem to be much more interested in the Suzuki/Geo engines, but that doesn't mean the Hondas would be bad. I have no idea what Honda engines weigh, which since they have a superior reliability record even in markets like Germany where people run them WOT for a long time (and since they are used as outboard powerheads at power settings equal or higher than in the cars, again with apparently superb reliability) would probably be the main factor. Of course, most any car engine is going to outperform a Lycoming today in terms of engine life at WOT. The Lycoming is a 1930s farm tractor engine built using WWI split crankcase, bolt on cylinder technology and belongs, really, in a museum. If it were really so great it would find many other uses besides aircraft. The military used them in generators and lifeboats and found they were cantankerous and troublesome and sensibly got rid of them. If only they had reefaged them instead of selling them surplus they would have done Experimental aviation a great favor. But I still wonder if the CVCC combustion system would be good for an airplane engine. The CVCC was a low intensity (vis-a-vis Ford PROCO, for example) stratified charge system designed primarily for emissions compliance without using catalytic converters, which were very expensive to maufacture and required unleaded gas which sold at a premium back then. (I'm old enough to remember the days of "punching" catalysts and filler restrictors to burn leaded gas at considerable savings-and satisfaction of F'ing the EPA, which we hated.) Since aircraft engines are not emissions controlled and unleaded gas is a lot cheaper than avgas, the advantage is nonexistent. CVCC was pretty troublesome, to be honest, and there were a fair number of people who converted their CVCC Hondas to the Canadian non-CVCC head and carb at some point in the car's lifecycle, particularly in areas where the cars didn't rust but which were outside emissions inspection areas-of course, most garages couldn't tell the difference anyway. |
![]() Here is what a Honda engine can do in an airplane: http://www.firewall.ca/cam100.htm Hope this helps J.P. He has NO IDEA whether or not Honda car engines would be good or bad for airplanes. The hardcore DIY converters seem to be much more interested in the Suzuki/Geo engines, but that doesn't mean the Hondas would be bad. I have no idea what Honda engines weigh, which since they have a superior reliability record even in markets like Germany where people run them WOT for a long time (and since they are used as outboard powerheads at power settings equal or higher than in the cars, again with apparently superb reliability) would probably be the main factor. Of course, most any car engine is going to outperform a Lycoming today in terms of engine life at WOT. The Lycoming is a 1930s farm tractor engine built using WWI split crankcase, bolt on cylinder technology and belongs, really, in a museum. If it were really so great it would find many other uses besides aircraft. The military used them in generators and lifeboats and found they were cantankerous and troublesome and sensibly got rid of them. If only they had reefaged them instead of selling them surplus they would have done Experimental aviation a great favor. But I still wonder if the CVCC combustion system would be good for an airplane engine. The CVCC was a low intensity (vis-a-vis Ford PROCO, for example) stratified charge system designed primarily for emissions compliance without using catalytic converters, which were very expensive to maufacture and required unleaded gas which sold at a premium back then. (I'm old enough to remember the days of "punching" catalysts and filler restrictors to burn leaded gas at considerable savings-and satisfaction of F'ing the EPA, which we hated.) Since aircraft engines are not emissions controlled and unleaded gas is a lot cheaper than avgas, the advantage is nonexistent. CVCC was pretty troublesome, to be honest, and there were a fair number of people who converted their CVCC Hondas to the Canadian non-CVCC head and carb at some point in the car's lifecycle, particularly in areas where the cars didn't rust but which were outside emissions inspection areas-of course, most garages couldn't tell the difference anyway. |
On 12 Aug 2006 17:30:49 -0700, "Bret Ludwig"
wrote: wrote: Based on that, you recommend that a homebuilder choose an engine for which there is no history of use or support in the aviation communtiy. Compared to sticking with what has proven successful, while avoiding what has not, that sounds expensive and unsafe to me. The Curtiss OX-5 was the "proven" aircraft engine at one time. if everyone thought like you it still would be. Designing an airframe around a Lyc today is more chronologically retarded than if Burt Rutan had used an OX-5 or OXX-6 in the first VariEze. (Do the math: I'm right. The OX-5 was a 1915 engine and the VariEze flew in 1975 or so. The OXX-6 came along in 1921 or so and the Milwaukee Tank aircooled conversion around then. This is 2006, although that probably has escaped the attention of the Lycophiles.) If safety is the ONLY criterion there is only one way to turn a propeller worthy of consideration, a real aircraft engine: namely, the P&WC PT-6A. You ever see now much fuel these things burn? Admittedly, slowly shoving the torque to 100% in a Glas air III or Aircomp is a real rush, but they make the 300 HP Lycosarus positively look like an economy engine. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Of course, with the caveat that you keep your toes clear when you installit. After all, once the airframe has been crushed by the weight of the engine the plane will never fly. Two beefy guys can easily lift a PT-6, at least the small series. A PT-6A-27 weighs 149 kg according to one Web site on Google. I think your definition of 'real' airplane comes close to excluding every homebuilt airplane that has flown successfully. What does that tell you? MANY homebuilts are marginal airplanes? That much is true. ... I only suggested Hondas as a possible solution because of reliability and the availability of "midtime" factory assembled engines as JDM pulls, cheap. There may actually be a problem with them but because no one has put much effort into flying them (save, a decade or two ago, the BD-5 guys) we don't know. Most turn "wrong way", but that's not a major issue unless you want to turn a surplus factory prop. Even then a gear drive could fix that. Here I follow you as far what could be a fruitful developement effort. But not a choice for someone who wants to build and fly, without having to re-invent the aircraft engine, eh? You have time to build, you have time to solve problems. Don't want to experiment? Buy a Cessna. -- FF P.S. What's a 'JDM pull'? Japanese Domestic Market. They scrap cars prematurely to artificially fluff their new car markets. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Wanted: VFR Safety Pilot near Milwaukee, WI - Cheap flying for you | Paul Folbrecht | Instrument Flight Rules | 9 | September 16th 04 03:25 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
the thrill of flying interview is here! | Dudley Henriques | Piloting | 0 | October 21st 03 07:41 PM |
