A fan marker lights the white light. An OM lights the blue light.
Andrew Sarangan wrote: A few questions came up in ground school that had me stumped. Any insight is appreciated. Why do some approaches say Radar required when all the fixes can be identified using other equipment required for the approach? For example, VOR-DME-A at 3G3. When a holding pattern is published in lieu of a PT, my understanding of the AIM (5-4-9 (4)) is that you only have to perform the entry, and are not required to do any laps around the pattern. What if the hold requires a direct entry? In that case it seems that you can effectively skip the holdind pattern, which does not make sense to me because a PT (or hold in lieu of PT) is a required maneuver. Take a look at SDF10 @ DWU. Why does the hold in lieu of a PT always say "1 min". Isn't a hold always 1 min? Why is this mentioned only for this type of hold, and not mentioned for all other holds? What exactly is a Fan Marker? See SDF10 @ DWU. How is this different from an OM? The fan marker seems to have its own identifier code. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Inside marker? I think you mean the inner marker. If you want an
authoritative source try the new FAA instrument flying handbook. Andrew Sarangan wrote: So, you are saying that the FM activate the same light as the Inside Marker. Is this written down anywhere? I could not find anything in the AIM. Before I explain this to my ground school I want to be certain I have the correct answer. wrote in : A fan marker lights the white light. An OM lights the blue light. Andrew Sarangan wrote: A few questions came up in ground school that had me stumped. Any insight is appreciated. Why do some approaches say Radar required when all the fixes can be identified using other equipment required for the approach? For example, VOR-DME-A at 3G3. When a holding pattern is published in lieu of a PT, my understanding of the AIM (5-4-9 (4)) is that you only have to perform the entry, and are not required to do any laps around the pattern. What if the hold requires a direct entry? In that case it seems that you can effectively skip the holdind pattern, which does not make sense to me because a PT (or hold in lieu of PT) is a required maneuver. Take a look at SDF10 @ DWU. Why does the hold in lieu of a PT always say "1 min". Isn't a hold always 1 min? Why is this mentioned only for this type of hold, and not mentioned for all other holds? What exactly is a Fan Marker? See SDF10 @ DWU. How is this different from an OM? The fan marker seems to have its own identifier code. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
More dumb CNX-80 questions -- unloading an approach? | Roy Smith | Instrument Flight Rules | 2 | September 17th 04 11:30 AM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
