Jay,
You know what the real irony is? One of Wisconsin's largest ethanol plants is located less than 5 miles SW of the EAA headquarters. Jim |
There are several issues here.
Ethanol is politically popular because it is a farm subsidy to an extent. Other sources of heat besides natural gas exist for firing alcohol plants. I would think that burning the corncobs and other unwanted biomass from the corn itself would be good, as would burning garbage. But what do I know. Natural gas is methane, which can be turned into methanol pretty cost-effectively. Ethanol, despite its poorer power density and seals compatibility issues, is far more benign and has more energy per gallon than does methanol. Be very glad you are being required to deal with ethanol and not methanol. Everyone knows that materials compatibility has been something doomed to bite aviation in the ass, hard, for decades. Certificated aircraft rubber materials have been manufactured since the postwar period with the same inferior grades of rubbers at great expense to avoid recertification while everyone else now uses better, more alcoholproof materials. Dave Blanton told me that in the mid-80s and he was right. Operation of aircraft on E10 or E15 auto fuel is a different issue than operating on E85 or E100 with entirely different problems especially in terms of water separation issues. The LyCon engines themselves, in terms of top end life especially, actually like ethanol a lot. Their fuel systems are a different issue. But I saw an AEIO-540 powered Pitts do an acro routine on straight ethanol (E100) in the late eighties. The pilot said that the cylinders lasted a lot longer than with gasoline and all competition acro pilots would use it if permitted by aerobatic rules. |
On 15 Aug 2006 08:15:58 -0700, "Bret Ludwig"
wrote in om: Natural gas is methane, which can be turned into methanol pretty cost-effectively. Ethanol, despite its poorer power density and seals compatibility issues, is far more benign and has more energy per gallon than does methanol. How does the energy density of LNG compare to ethanol? |
On Tue, 15 Aug 2006 16:40:11 GMT, Larry Dighera
wrote: How does the energy density of LNG compare to ethanol? It's less than gasoline, but I'm not sure how it compares to ethanol... Do you mean LNG or LPG though? Propane has an octane rating of 110 to 120... Sounds great, right? Unfortunately, the weight of the tanks is what would probably get us... Our tanks would have to be built quite a bit sturdier to handle the increased pressure... Although typical operating pressures are around 130 psi, tanks are typically rated to over 300 psi... With LNG, you need either higher pressure or a cooling system... Here's some info: http://www.wps.com/LPG/WVU-review.html |
![]() Grumman-581 wrote: On Tue, 15 Aug 2006 16:40:11 GMT, Larry Dighera wrote: How does the energy density of LNG compare to ethanol? It's less than gasoline, but I'm not sure how it compares to ethanol... Do you mean LNG or LPG though? Propane has an octane rating of 110 to 120... Sounds great, right? Unfortunately, the weight of the tanks is what would probably get us... Our tanks would have to be built quite a bit sturdier to handle the increased pressure... Although typical operating pressures are around 130 psi, tanks are typically rated to over 300 psi... With LNG, you need either higher pressure or a cooling system... LNG, as used in the Beech system (Beech Aircraft really did the pioneering work on LNG, of course it went nowhere....) was stored at very low temperature at approximately atmospheric pressure in a dewar type insulated tank. It's important to understand that methane-natural gas- is an incondensible gas for all intents and purposes, like oxygen and nitrogen but unlike propane, nitrous oxide, carbon dioxide, ammonia which can be stored at human-habitable ambient temperatures at pressures feasible for storage tanks. Methane and propane can be burned in an IC engine in similar fashion once they are a gas, but at very different fuel-air mixtures. Methane is approximately 108 octane and propane is in the 103-106 range depending on exactly what's in it (LP motor fuel is nothing like reagent grade and contains methane, butane, methanol, and lots of other junk). LNG would be practical but the cost of distribution would be high and the fuel system is fairly complex, at least in the Beech system. CNG has no range to speak of. LPG is very practical for all sort of ground vehicles and has been done successfully in helicopters, but large volume storage in fixed wing aircraft is problematic. A fixed wing aircraft designed around a fuselage LP tank as a stressed member might make some sense. |
![]() "Bret Ludwig" wrote in message ups.com... LNG, as used in the Beech system (Beech Aircraft really did the pioneering work on LNG, of course it went nowhere....) was stored at very low temperature at approximately atmospheric pressure in a dewar type insulated tank. It's important to understand that methane-natural gas- is an incondensible gas for all intents and purposes, like oxygen and nitrogen but unlike propane, nitrous oxide, carbon dioxide, ammonia which can be stored at human-habitable ambient temperatures at pressures feasible for storage tanks. Methane and propane can be burned in an IC engine in similar fashion once they are a gas, but at very different fuel-air mixtures. Methane is approximately 108 octane and propane is in the 103-106 range depending on exactly what's in it (LP motor fuel is nothing like reagent grade and contains methane, butane, methanol, and lots of other junk). LNG would be practical but the cost of distribution would be high and the fuel system is fairly complex, at least in the Beech system. CNG has no range to speak of. LPG is very practical for all sort of ground vehicles and has been done successfully in helicopters, but large volume storage in fixed wing aircraft is problematic. A fixed wing aircraft designed around a fuselage LP tank as a stressed member might make some sense. For those of you who have not yet decided that this guy Ludwig is a dufus and / or a troll.... natural gas is not methane. Although methane makes up approximately 96% of the local natural gas here, there are many other constituents. Several of the products that he says are stored at human habitable temperatures... well lets just say that he is wrong at least on the ones that I am most familiar with. For instance, ammonia is stored at temperatures around -28 degrees f. As a matter of fact, nitrogen, carbon dioxide, and ammonia are all cryogenically stored. BTW, we condense methane at -282 degrees f. at my work place 24 hours a day as a step in recovery hydrogen for reuse. Joe Schneider N8437R ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
![]() For those of you who have not yet decided that this guy Ludwig is a dufus and / or a troll.... natural gas is not methane. Although methane makes up approximately 96% of the local natural gas here, there are many other constituents. 96% is "most", most of the time. Where I'm from. Several of the products that he says are stored at human habitable temperatures... well lets just say that he is wrong at least on the ones that I am most familiar with. For instance, ammonia is stored at temperatures around -28 degrees f. As a matter of fact, nitrogen, carbon dioxide, and ammonia are all cryogenically stored. Nitrogen must be cryogenic to be in liquid form. CO2 and NH3 are stored in regular steel tanks and when both gas and liquid are in the tank, and the tank is allowed to sit with no flow, the tank assumes ambient temperature (or higher in the sun) and the pressure inside is a direct function of the product's temperature. Same with Freon (most kinds), propane, etc. Nitrogen, oxygen, hydrogen, helium, are a liquid at earth temperatures only under freakish pressures. There is said to be solid methane at the bottom of the ocean in certain places but what is the absolute pressure at those depths? About ten thousand psi is the practical limit for pressure vessels. That's why these gases are transported cryogenically or as _gases_ in the 2-3000 psi welding type cylinders. |
On 15 Aug 2006 08:15:58 -0700, "Bret Ludwig" wrote in om: Natural gas is methane, which can be turned into methanol pretty cost-effectively. Ethanol, despite its poorer power density and seals compatibility issues, is far more benign and has more energy per gallon than does methanol. How does the energy density of LNG compare to ethanol? LNG has about 73,000 BTU/US Gal., while ethanol has about 80,000. Gasoline ranges between 110,000 and 125,000. Keep in mind that the LNG is also accompanied by a very heavy tank, which has payload implications. |
On Tue, 15 Aug 2006 13:56:11 -0500, James Robinson
wrote: LNG has about 73,000 BTU/US Gal., while ethanol has about 80,000. Gasoline ranges between 110,000 and 125,000. Of course you also get to factor in the difference in weight per gallon... Keep in mind that the LNG is also accompanied by a very heavy tank, which has payload implications. LPG has lighter tanks, but still heavy compared to the ones we have now for gasoline... Now, on the other hand, I can see the Grumman AA1 series aircraft fuel tanks possibly being converted to LPG in that they use the tubular spar for a fuel tank... One could perhaps argue that under pressure the spar might even be stronger... Still, that's a 20g fuel tank... Range will be decreased, but cargo capacity will go up a few pounds from the reduced weight of the fuel... I suspect that most aircraft would not be able to have their fuel tanks so easily modified... |
wrote in : Larry Dighera wrote: On 15 Aug 2006 08:15:58 -0700, "Bret Ludwig" wrote in om: Natural gas is methane, which can be turned into methanol pretty cost-effectively. Ethanol, despite its poorer power density and seals compatibility issues, is far more benign and has more energy per gallon than does methanol. How does the energy density of LNG compare to ethanol? LNG has about 73,000 BTU/US Gal., while ethanol has about 80,000. Gasoline ranges between 110,000 and 125,000. Keep in mind that the LNG is also accompanied by a very heavy tank, which has payload implications. If Kevlar reinforced aluminum is used in the construction of the tank (as is used for aviation O2), tank weight shouldn't be such a large factor: http://www.mhoxygen.com/index.phtml?...product_id=372 1,800 psig service pressure The KF series cylinders are the perfect solution for cylinder installations far aft in the aircraft previously not possible before. A thin-wall, seamless aluminum (6061-T6) alloy 'liner-cylinder' is reinforced by a full over-wrapping of Kevlar fibers sealed in epoxy. This yields about a 50% to 60% weight savings over conventional cylinder technology without any compromise in safety. KF-050, Item #CYL1050 For built-in applications MAX DIAMETER: 17.27 cm. (6.8 in) MAX LENGTH: 64.00cm. (25.2 in) AVG WEIGHT: 3.58kg. (7.9 lbs) SERVICE VOLUME: 1416 liters (50 cu. ft.) Below are the results of my research on BTU content of various fuels: http://bioenergy.ornl.gov/papers/misc/energy_conv.html Natural gas: LHV = 930 Btu/ft3 = 34.6 MJ/m3 Therm (used for natural gas, methane) = 100,000 Btu (= 105.5 MJ) Ethanol energy content (LHV) = 11,500 Btu/lb = 75,700 Btu/gallon = 26.7 GJ/t = 21.1 MJ/liter. Barrel of oil equivalent (boe) = approx. 6.1 GJ (5.8 million Btu), equivalent to 1,700 kWh. "Petroleum barrel" is a liquid measure equal to 42 U.S. gallons (35 Imperial gallons or 159 liters); about 7.2 barrels oil are equivalent to one tonne of oil (metric) = 42-45 GJ. Gasoline: US gallon = 115,000 Btu = 121 MJ = 32 MJ/liter (LHV). There are 19.5 gallons of gasoline in a barrel of oil, 4.1 gallons of kerosene-type jet fuel in a barrel of oil Petro-diesel = 130,500 Btu/gallon (36.4 MJ/liter or 42.8 GJ/t) Efficiency of an internal combustion engine is about 22% and electric motor...about 96%(plus or minus a few points...depending on who built it). Electricity at 3412 Btu input per kWh. http://www.ethanol-gec.org/netenergy/NEYShapouri.htm http://www.ethanol.org/EthanolNewsSpecial1.28.05.htm This report estimates the net energy balance of corn ethanol utilizing the latest survey of U.S. corn producers and the 2001 U.S. survey of ethanol plants. On the average, dry mill ethanol plants used 1.09 Kwh of electricity and about 34,700 Btu of thermal energy (LHV) per gallon of ethanol. When energy losses to produce electricity and natural gas were taken into account, the average dry mill ethanol plant consumed about 47,116 Btu of primary energy per gallon of ethanol produced. Wet mill ethanol plants that participated in the survey used 49,208. Btu per gallon of natural gas and coal, on average, to produce steam and electricity in the plants. After adjustments for energy losses to produce natural gas and coal, on the average, a wet mill ethanol plant used 52,349 Btu of energy to make a gallon of ethanol. All energy inputs used in the production of ethanol is adjusted for energy efficiencies developed by GREET model. The estimated energy efficiencies are for gasoline (80.5 percent), diesel fuel (84.3 percent), LPG (98.9 percent), natural gas (94 percent), coal (98 percent), electricity (39.6 percent), and transmission loss (1.087 percent). After adjusting the energy inputs by these energy efficiencies, the total estimated energy required to produce a bushel of corn in 2001 was 49,753 Btu. http://www.herecomesmongo.com/ae/comptab.html 1 gallon non-reformulated gasoline = approximately 113,500 BTU (depending on seasonality and other factors... Oil Industry Literature reportedly indicates that real-world gasoline sold at US pumps can go to 108,500 BTU or lower). 1 gallon of #2 diesel = approximately 131,295 BTU (LHV) 1 gallon of biodiesel = approximately 117,093 BTU (LHV) (10/08/02: BTU per gallon for diesel and biodiesel updated using best-available info from US DOE website). 1 cubic foot of natural gas = approximately 1000 BTU 1 lb of H2 = approximately 61,000 BTU 1 gallon = approximately 3.785 liters (1 quart = 1 quarter of a gallon = .946 Liters) Definitions: 1 kWh = 3412 BTU = 3,599,660 Joules 1 barrel (of Petroleum) = 42 gallons 1.0 US bushel = 0.0352 m3 = 0.97 UK bushel = 56 lb, 25 kg (corn or sorghum) = 60 lb http://www.eere.energy.gov/cleanciti...ri_webcast.pdf Btu content (LHV):- Diesel fuel 128,450 per gallon - Gasoline 116, 090 per gallon - LPG 84,950 per gallon - Natural gas 983 per cubic ft. - Electricity 3,412 per kwh - Coal 9,773 per pound - Ethanol 76,330 per gallon http://www.ers.usda.gov/Data/CostsAn...s/testpick.htm Commodity Costs and Returns: U.S. and Regional Cost and Return Data http://energy.cas.psu.edu/costcomparator.html Energy Cost Calculator is an EXCEL spreadsheet. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
