Transponder requirement confusion
Old August 16th 06, 01:40 AM posted to rec.aviation.owning
Bob Noel
Default Transponder requirement confusion
In article
john smith wrote:
The really dumb part of that requirement is that terminal radar doesn't
see below a given altitude at a given distance.
but a TCAS II equipped aircraft can see you.
Bob Noel
Looking for a sig the
lawyers will hate
Old August 16th 06, 01:49 AM posted to rec.aviation.owning
Vaughn Simon
"Bob Noel" wrote in message
...which gives you plenty of reason to leave the thing on. In fact, it is
reason enough that significant numbers of glider people are installing some of
the new low-drain units, even though there is no FAA requirement.
Vaughn
Old August 16th 06, 02:31 AM posted to rec.aviation.owning
: ...which gives you plenty of reason to leave the thing on. In fact, it is
: reason enough that significant numbers of glider people are installing some of
: the new low-drain units, even though there is no FAA requirement.
My big beef was just the finite lifespan of the old cavity tube units. As long as it's solid
state like my new unit, there's really no reason NOT to turn it on. Maybe I was just ultra-sensitive
to the cavity thing since I had to replace two of them with low power.
The other beef is how vague the FAR is.
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
Old August 16th 06, 03:13 AM posted to rec.aviation.owning
Ron Natalie
What's vague. If you're in controlled airspace and you've got
a transponder, it's supposed to be on.
Old August 16th 06, 09:40 PM posted to rec.aviation.owning
john smith
Bob Noel wrote:
In article
Only if you have a Mode-S transponder.
Old August 16th 06, 09:56 PM posted to rec.aviation.owning
Nope, all they need is mode C.
Old August 16th 06, 10:00 PM posted to rec.aviation.owning
Actually, they don't even need mode C, now that I think about it.
You get different levels of service depending on what the target has.
If they've got Mode A you'll get an callout.
If they've got Mode C then you'll get an RA (climb / descend)
If they've got Mode S and they've also got TCAS, the two TCAS's
will boogie with each other to coordinate the RA.
So really mode S by itself does nothing for TCAS II unless you've
also got a TCAS as well.
Old August 17th 06, 03:17 AM posted to rec.aviation.owning
Newps
john smith wrote:
My understanding is that the Mode-S provides the communication
information. Mode C may contain altitude, but there is no distance or
direction information.
Mode S doesn't provide any distance or direction info to another TCAS.
Each TCAS figures that stuff out on its own.
Old August 17th 06, 03:24 AM posted to rec.aviation.owning
Ray Andraka
john smith wrote:
In article . com,
That's correct. Mode C only transmits either the squawk code or the
encoded altitude, depending on the specific interrogation. However,
TCAS is an active system that sends an interrogation and listens for the
reply. It uses the time delay between the interrogation it sends and
the reply it recieves back to accurately measure range. Many use an
antenna array and beamforming techniques to determine azimuth as well.
Therefore, it can determine both distance and direction, and of course
it gets the altitude directly from the reply.
The passive TCAD boxes do not transmit interrogations. Instead they
listen for replies to other interrogations and use some signal
processing to glean rough range information from the dispersion and
amplitude of the received pulse. Considering the lack of a hard
measurement, they do a pretty decent job at estimating range. Strike
finders work under a similar principle. In the case of a transponder
reply, the job is easier because the transmit pulse shape and amplitude
are pretty narrowly defined for an in-spec transponder. Most of the
TCAD boxes do not provide azimuth info. The ones that do also use a
phase array of antennas and signal processing to do beamforming to
resolve the azimuth.
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
Operation without a transponder flyer Piloting 11 September 14th 04 09:48 AM
Transponder petition Ian Cant Soaring 11 February 28th 04 07:38 AM
More on transponder petition Ian Cant Soaring 1 February 27th 04 07:37 PM
