Look at Van's Blather here.
Old August 16th 06, 10:20 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Matt Whiting
Default Look at Van's Blather here.
Bret Ludwig wrote:
Introduction - Powerplant Choices
RV aircraft are designed to use Lycoming aircraft engines.
Did you have a point here?
Matt
Old August 16th 06, 11:05 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Kyle Boatright
"Kingfish" wrote in message
Casey Wilson wrote:
Any chance there's a point to this drivel?
I found myself thinking the same thing
Herr Ludwig didn't make it clear that he is ranting AGAINST the choice
of the Lycoming for all RVs.
How hard would it be to mount a Continental to an RV? I'm no A&P but
how different could the mounts be for two engines of similar
architecture? Do Cont. engines use four-point mounts like Lycs?
Very different mounts. In addition, the 0-300 Continental is typically a
145 hp engine. Sure, it'll fly any of the 2 seat RV's, but *nobody* wants
less power than the other guy, who is probably flying behind a 160 or 180 hp
engine.
In talking with Van's, they really thought they would have quite a few
customers for the RV-9 who would use the 0-235 or 0-290. Sure, there are a
few, but there are far more guys bolting on the 0-360 @ 180 hp, which is 20
hp more than what Van had in mind when he designed the airplane.
KB
Old August 16th 06, 11:11 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Newps
Casey Wilson wrote:
"Newps" wrote in message
of the Lycoming for all RVs. Akshully, Herr Ludwig makes no cogent remarks
as he stepped on his..., well let it go at that.
So you could have answered my question with one word then.
Old August 16th 06, 11:14 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Newps
And now there's an O-340 out there that puts out 190 hp. Oh the choices.
Old August 17th 06, 12:18 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jim Carriere
That sounds a bit like the story of the RV-6. I thought it was
originally intended for the O-320, and as more and more builders were
apparently successful with O-360 installations, Van designed the RV-7
with that (among other changes) in mind.
There is an old Tony Bingelis article about the pros and cons (mostly
cons... weight, fuel flow) of bigger engines. Apparently a lot of RV
builders missed that memo... Or you could say it is a credit on the
basic design that it accepts increased power so well.
I think RVs are great airplanes although I don't want one for my own.
Apples and oranges thing I guess.
Old August 17th 06, 12:39 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Morgans[_3_]
a
20
I have a friend who was one of the few that chose the lower HP, then. He
built a fire breathing, race 4.3 liter Chevy RV-7, then got it done and
started almost immediately on a RV-9, which he put a 235 in.
He claims that he can go blasting around in the 235 HP Chevy when he wants
to go fast, and poke along in the O-235ci for trips, for next to nothing in
gas costs. The best of both worlds!
Jim in NC
Old August 17th 06, 02:29 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Kyle Boatright
a few, but there are far more guys bolting on the 0-360 @ 180 hp, which
is 20 hp more than what Van had in mind when he designed the airplane.
You're right, there are lots of choices. The O-340 as you mentioned, but
also the O-390 and O-400, which are enlarged O-360's. Presumably all three
of these engines will be relatively low volume. I'd be scared to death to
buy one because if the Lyclone manufacturer who produces the oddball engine
goes out of business, I don't think there will enough units in the field to
drive anyone to support the engines.
People with GO-300's, GO-470's, C-85's, O-290's and several other legacy
powerplants are having problems getting parts for their engines. Those
engines had much longer production runs than today's oddball lyclones are
likely to see.
KB
Old August 17th 06, 02:36 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
JJS
Default Look at Ludwig's Blather here.
"Steve Foley" wrote in message news:F4KEg.3078$df.1829@trndny06...
Are the comments in parentheses yours? It's kind of hard to tell who wrote
what.
In any case, I know of at one Lycoming engine designed for a boat. I think
it was used in the 1930s.
Lycomings are used in airboats all the time in Florida. And Van's aircraft built one of their RV-10s with a
Continental.
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old August 17th 06, 02:40 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jerry Springer
I built, own and still fly after 18 years the second customer built RV-6
and it has always been designed for an O-320 Or a O-360.
Jerry
Old August 17th 06, 02:54 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jim Carriere
Hmmm, OK, was the -6 designed for the O-360 (to improve on the -4)? Or
am I misinformed?
Zodiac XL vs Rans S-19 vs Van's RV-12 Jim Logajan Home Built 12 July 2nd 06 10:31 PM
Very Nice Van's RV-6A For Sale Don Aviation Marketplace 3 January 14th 06 12:13 AM
Very Nice Van's RV-6A For Sale Don General Aviation 1 December 21st 05 01:52 AM
Vans RV-11 Scott Correa Soaring 27 January 5th 04 07:56 AM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 07:20 PM
