Thanks, Bob. I'll give the connections a good going-over and see what
happens.... Cheers, Tim Bob Kuykendall wrote: The last time I had this problem (with a homemade Les Sebald-designed clip-on mic), I search high and low in the mic circuit and didn't find the problem. It turned out that it was caused by a bad connection in the antenna cable. The problem went away when I cleaned all the BNC connections and the antenna ground terminal attachment. Just a thought. Good luck! Bob K. |
