On 17 Aug 2006 16:38:23 -0700, "
wrote: I'm looking to tow my plane to the airport. I've seen aircraft towed on their own wheels. I called the local police department and they said I had to use a trailer. Does anyone know the "road rules" for towing aircraft to the airport? I tried googling for federal or state (Maine) regulations and basically came up empty. Anyone know the answer or can help? -Bruce I'm getting ready to tow my Glasair 3, and I'm using one of those cheap, $200 trailers that Harbor frieght and Northern tools sell. It's rated at 1100lbs, has a 4X8 bed, and since I carry the wing, fuselage and engine in separate trips, I'll never get close to the weight rating. I had to modify it by using a longer tongue for the length of the wing. . On a plane like that, where the wing contains the main gear, and the wing and fuselage are carried separetly, there's no way to road trailer the plane. Only the Glasair taildragger could be carried that way, since it's gear is mounted to the fuselage. But then a trailer would be needed for the wing. The guys mentioning towing their planes backwards on it's gear, how are you carrying the wing? Rooftop? Must be using trailers for those, unless you build something like a T-18, or Mustang II with folding wings. Which I wouldn't mind doing next! I'm tired of paying hanger rent, and having your plane towed home would be like living in an airpark. |
![]() I'm looking to tow my plane to the airport. I've seen aircraft towed on their own wheels. I called the local police department and they said I had to use a trailer. Does anyone know the "road rules" for towing aircraft to the airport? Does your state issue temporary permits for unlicensed vehicles? If so then that's your answer. I've towed airplanes over the roads several times in Washington State. Cheers: Paul N1431A |
Palo Alto airport, potential long-term problems... | [email protected] | Piloting | 7 | June 6th 05 11:32 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
