Squelch is a "dumb" device on cheap radios. It just looks
at the total RF signal level, from any source. You said that the frequency was 122.7, which is a common frequency, at 200-300 feet AGL, you're getting your mags [which probably are not shielded on a NORDO aircraft], and all the hundreds of transmitters within 200 miles line of sight. Your hand held may also not be sensitive enough to reject the adjacent frequencies. "john smith" wrote in message ... | In article , | Mark Morissette wrote: | | *Only* when you hit a few hundred feet...or anytime the engine is running? | | Personally I'd venture to take a guess that it's picking up electrical | interference from an ignition component. | | I thought that too, but it doesn't make sense that it would start | 100-200 feet AGL. If it is ignition, it will be present any time the | engine is running. |
If you are using a handheld GPS, try moving the transceiver away from the
gps. My ICOM breaks squelch badly when it is near the Garmin 196 display (even on batteries). I move it a few feet and it goes away. |
On Sat, 19 Aug 2006 13:53:47 GMT, "Ron A." wrote:
If you are using a handheld GPS, try moving the transceiver away from the gps. My ICOM breaks squelch badly when it is near the Garmin 196 display (even on batteries). I move it a few feet and it goes away. Sounds like a Garmin family foible. I have the same problem (though only on trasmit) between my 296 and my Vertex Standard. Since I really have no option, and since the Cub is so obviously Nordo anyhow, I just don't use them at the same time. When I have my destination in sight, I turn off the Garmin. After I'm clear of the pattern on takeoff, I turn it on again and go to the waypoint for the home airport (whatever). Awkward, but I don't own the plane. -- all the best, Dan Ford email: usenet AT danford DOT net Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com In Search of Lost Time: www.readingproust.com |
Busted ground wire off the coax at the antenna end.
Jim wrote in message ups.com... Any ideas what's going on here? All help is appreciated. Tailwinds and blue skies, Mike |
While I've got you, (heh heh) what's your take on a car radio that buzzes (ignition noise) much louder than the radio station coming in, but intermittently? I'd guess the same thing, but we haven't been able to find it. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
On 18 Aug 2006 18:41:54 -0700, wrote:
The problem is the handheld transceiver I'm using to communicate. It works fine on the ground. But as soon as I get 100-200 feet off the ground it gets overwhelmed with static, like the squelch is wide open. Is it only when you transmit? (Sparkplugs likely, in that case.) -- all the best, Dan Ford email: usenet AT danford DOT net Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com In Search of Lost Time: www.readingproust.com |
Connecting handheld to intercom in NORDO plane | [email protected] | Owning | 2 | July 7th 06 02:57 PM |
aviation vhf handheld radio problem | pwm | Home Built | 3 | February 7th 06 02:03 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
