Ethanol Powered Aircraft
Old August 21st 06, 01:52 AM posted to rec.aviation.piloting
Don Tuite
Default Ethanol Powered Aircraft
On Sun, 20 Aug 2006 19:52:40 -0400, Roger
Cold? I noted some liquid running off one of the fittings and figured
it was way too cold for water, but it sure looked like it. The tank
farm operator remarked; "Water? No, it's way too cold for that. That
stuff running off is liquid Oxygen".
Jesus. What was it dripping onto?
However I would add that there is a way to keep a lot of H2 in a
relatively small space at room temperature that is "physically
practical". Unfortunately it takes a lot of some very expensive
material that is also toxic. They can use metal Hydrides as "metal
sponges" and the things do hold a tremendous amount of H2. Also a
ruptured tank is not a fire safety issue as you normally have to use a
small heater to get the H2 out.
FWIW, the H2 in GM's little hydrogen-fueled electric cars is gaseous,
pressureized to 10K psi.
Don
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
