Twin tachs
Old August 22nd 06, 06:04 PM posted to rec.aviation.owning
Jim Burns[_1_]
Default Twin tachs
One of the tachs in our Aztec has been acting kind of flakey, usually
reading too high when above 2100 rpms, (I've checked it several times with
an optical tach) so I've been contemplating our options of replacing both
tachs with a single dual needle tach. This would open up some panel space
allowing me to spend ludicrous AMU's on another toy.
One option is to simply get a mechanical dual tach and connect both tach
cables to the single tach but I don't know of a dual recording tach that has
dual hour meters. Anybody?
Another option is to get rid of the cables, buy tach generators, and an
electric dual needle tach. But I still don't know of a company that makes a
dual recording tach.
So far, I have not found a company that makes a dual electronic tach.
Neither E.I or Horizon seem to offer a dual tach. Also, due to panel
configuration, I want a 3 1/8" dia tach not the smaller 2 1/4" tachs that EI
or Horizon offer, I have no room for additional 2 1/4" gauges.
Is there anybody out there with any insight into this dilemma?
Thanks,
Old August 22nd 06, 09:13 PM posted to rec.aviation.owning
Allen[_1_]
Default Twin tachs
"Jim Burns" wrote in message
has
I don't believe you need a recording tach. Most twin engine retractable
aircraft only record "flight" time and have a squat switch installed that
powers the Hobbs meter when the aircraft is airborne. Just don't forget to
disconnect the power to it while you have it up on jacks doing MX with the
battery on.
Allen
Old August 22nd 06, 09:35 PM posted to rec.aviation.owning
Jim Burns[_1_]
Default Twin tachs
Yep. Got one of them also, but a previous owner wired it to the master
switch instead of the squat switch. Must have been used as a trainer or
rental at one point. That's little item has been on our "fix it" list for
a long time. I just think it's kind of nice to be able to look at the tachs
and see how many hours are on each engine.
Old August 22nd 06, 09:54 PM posted to rec.aviation.owning
Allen[_1_]
Default Twin tachs
for
tachs
If you find a dual recording tach it still will not tell you the hours on
"your" engines, you will still need to do the math. I would go with the less
mechanically complex tach and a Hobbs meter. Hobbs meters are cheap and you
could put in a "0" time one at the next engine overhaul so the times
matched.
Allen
Old August 22nd 06, 10:13 PM posted to rec.aviation.owning
Jim Burns[_1_]
Default Twin tachs
The tach shops will run a new or rebuilt tack up to any number you want....
for about the price of a hobbs meter. But I doubt if I'll find a dual
recording tach.
less
you
matched.
Allen
Old August 22nd 06, 10:43 PM posted to rec.aviation.owning
Jon Kraus
Default Twin tachs
Isn't engine TBO driven off the engine tach-time and not Hobbs meter
time? Since I don't have a hobbs meter in the Mooney does that mean my
engine is not recording any wear? ;-)
Jon Kraus
for
tachs
matched.
Allen
Old August 23rd 06, 03:29 AM posted to rec.aviation.owning
Allen[_1_]
Default Twin tachs
"Jon Kraus" wrote in message
Jon Kraus
Heh Heh, if it only worked that way. I have customers come in from Mexico
for overhauls at "TBO" with probably twice the actual hours on the engines.
Not very many twins have the recording tach like the Aztec.
Allen
Old August 23rd 06, 01:19 PM posted to rec.aviation.owning
Kyler Laird
Default Twin tachs
"Jim Burns" writes:
I probably have the one we pulled from our Aztec in my junk box.
I was told that Horizon would have a dual tach. "soon" when we were
looking in 2001.
Also, due to panel
The Horizon P-1000 is a larger tach.
Another option is (always) on the horizon...
http://diamondaire.com/aztec.htm
Rochester engine instrumentation.We are currently working with
Rochester Gauges of Texas to introduce new 2-1/4" dual-needle
STC'd backlit gauges. [...] A 3-1/8" dual electric STC'd
tachometer will also be available.
(They've been saying that for awhile now.)
It's worth pursuing. I hate mechanical tachs. I've replaced those
damn cables way too many times. It makes no sense to have all that
crap in the plane just to provide a really lousy estimate of engine
speed. In a single it's o.k. but in a twin it's ridiculous. (I recall
the joy of yanking those cable housings out of my plane!)
You will love an electronic tach. I especially like the mag. failure
lights and the mag. drop feature. Having a tach. that always works and
is accurate without constant maintenance is pretty sweet too.
--kyler
Old August 23rd 06, 01:23 PM posted to rec.aviation.owning
Kyler Laird
Default Twin tachs
"Jim Burns" writes:
You have a squat switch?
BTW, we changed our Hobbes meter to run off of the heater.
--kyler
Old August 23rd 06, 03:18 PM posted to rec.aviation.owning
FlyWithTwo
Default Twin tachs
Thanks,
Hi Jim,
I have a dual needle tach in the 310 with electric tach generators on
each engine - no tach hour recorder. The plane has a hobbs meter that
is activated by a switch. It's not exactly a weight on wheels switch.
It is a microswitch activated by a small stainless steel flap on the
belly that is sensitive to airflow, similar to a stall switch. DC
power goes to the Hobbs, and the ground goes through the switch. It's
supposed to activate at a certain airspeed, but I know it has some
bounce due to airflow from propeller wash when taxiing and running up
the engines.
I previously had a Cessna single with both a Hobbs and Tach hour meter.
When averaged, I found that multiplying 1.15 times the Tach meter was
close to the Hobbs time. I've heard of others with planes on leaseback
that only had tach meters charging something like 1.1 or 1.2 times the
tach time.
Brian
new twin concept from Cirrus Kingfish Piloting 25 May 11th 06 06:49 PM
Questions on twin operation Frode Berg Owning 9 May 5th 06 08:36 PM
aftermarket de-ice for Twin Comanche Dico Owning 1 February 5th 06 05:51 PM
twin tail questions Kevin Horton Home Built 12 January 2nd 04 03:21 PM
True costs of a light twin... Captain Wubba Owning 20 November 20th 03 02:32 AM
