It may take me bit to remember where the actual authorization for a
airplane instrument rating to qualify for a glider rating is. As a start though FAR 61.57c2 tells you how to remain or get instrument current for gliders. Brian snoop wrote: Brian, I have my FAR/AIM book open. In part 91, give me the glider specific regs that tell me how to fly a glider, on an IFR clearance in the US. I just reread the requirements for an instrument rating, and nowhere does the word glider show up in FAR 61.65. Shawn, help us out here. F2, thanks for your input, but were shaking down the US regs here. |
![]() Brian wrote: It may take me bit to remember where the actual authorization for a airplane instrument rating to qualify for a glider rating is. As a start though FAR 61.57c2 tells you how to remain or get instrument current for gliders. Brian Brian, CFAR § 61.3(e)(3) states that to fly a glider under IFR, the PIC needs to hold an airplane instrument rating and a glider rating: § 61.3 Requirement for certificates, ratings, and authorizations. (e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds: (3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating. Chris Fleming, F2 |
![]() It didn't take me as long to find at as I thought it might: FAR 61.3e3 (e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds: (1) The appropriate aircraft category, class, type (if required), and instrument rating on that person's pilot certificate for any airplane, helicopter, or powered-lift being flown; (2) An airline transport pilot certificate with the appropriate aircraft category, class, and type rating (if required) for the aircraft being flown; (3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating; or Brian |
Good find. That's what I saw, in the same vein, with 61.57, how to stay
current, but the requirements for an instrument rating still leave us hanging out there, as mentioned earlier. Now we need the operational or part 91 end of it. How to do it. Hang in there guys, Shawn, c'mon buddy we need you to help here. Brian wrote: It didn't take me as long to find at as I thought it might: FAR 61.3e3 (e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds: (1) The appropriate aircraft category, class, type (if required), and instrument rating on that person's pilot certificate for any airplane, helicopter, or powered-lift being flown; (2) An airline transport pilot certificate with the appropriate aircraft category, class, and type rating (if required) for the aircraft being flown; (3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating; or Brian |
![]() snoop wrote: Good find. That's what I saw, in the same vein, with 61.57, how to stay current, but the requirements for an instrument rating still leave us hanging out there, as mentioned earlier. Now we need the operational or part 91 end of it. How to do it. Hang in there guys, Shawn, c'mon buddy we need you to help here. Snoop- What are you talking about?! Ask a specific question! Flying a glider under IFR is EXACTLY THE SAME as flying an airplane under IFR. That is why an instrument rating in airplanes is required to fly a glider under IFR. Here's how you do it: 1. File the flight plan. 2. Receive the ATC clearance. 3. Fly the glider! If your flight is intended to be local in nature, you request a block clearance both laterally and vertically, and remain within your clearance limits. If you are flying cross country, you receive a route clearance with authorization to deviate up to x miles left and right of course within a block altitude limit. If you already have your instument-airplane rating, and a few hundered hours of instrument experinece, you should already know all of this. If you don't, then you shouldn't consider flying a glider IFR. Chris Fleming, F2 |
Chris,
Specifically, where does the clearance begin, and end. ATC is going to want a starting point and an exit point. Going back to my earlier note, how do you get up and down? The cloud layer closes in below you while your going x country IFR in a pure glider, how do you legally get down. You are coming down somewhere, I don't have an argument there, but ATC has a big manual called the TERPS Manual that they have to operate by. It is their ball and chain that they operate by, and if they've issued us a clearance, they have some pretty tight parameters that they want us to fly by in their airspace. Let's say that your here at my club in Texas. My specific question here would be how would you file the route portion. Let's say you use a fix near TSA to start. Now, how do I file the altitude? A block is probably the best way, as you mentioned, but how do you guarantee your local controllers that your going to remain in that block, especially if the bottom fills in below you while your cruising. This is why I'm a bit suspect that there are some loose ends to flying gliders IFR, from a totally legal standpoint. I beg to differ that it is nothing like flying an airplane IFR. Thanks for the input Fox Two wrote: snoop wrote: Good find. That's what I saw, in the same vein, with 61.57, how to stay current, but the requirements for an instrument rating still leave us hanging out there, as mentioned earlier. Now we need the operational or part 91 end of it. How to do it. Hang in there guys, Shawn, c'mon buddy we need you to help here. Snoop- What are you talking about?! Ask a specific question! Flying a glider under IFR is EXACTLY THE SAME as flying an airplane under IFR. That is why an instrument rating in airplanes is required to fly a glider under IFR. Here's how you do it: 1. File the flight plan. 2. Receive the ATC clearance. 3. Fly the glider! If your flight is intended to be local in nature, you request a block clearance both laterally and vertically, and remain within your clearance limits. If you are flying cross country, you receive a route clearance with authorization to deviate up to x miles left and right of course within a block altitude limit. If you already have your instument-airplane rating, and a few hundered hours of instrument experinece, you should already know all of this. If you don't, then you shouldn't consider flying a glider IFR. Chris Fleming, F2 |
Snoop,
That's more like it: specific questions. It appears to me that you are making this way too difficult. Here we go: snoop wrote: Chris, Specifically, where does the clearance begin, and end. ATC is going to want a starting point and an exit point. What is your intended task? If you're going from A to B and landing at B, then file from A to B. Most glider cross-countries start and end at the same place, so file from A to A via B and C. You can amend your clearance at any time. If you don't think you can make B, just tell ATC and request clearance to C, or back to A or to a new destination D. In short, just tell them what you want to do! Going back to my earlier note, how do you get up and down? The cloud layer closes in below you while your going x country IFR in a pure glider, how do you legally get down. I'm not sure I understand your question. Your initial clearance is going to have an altitude block. Throughout your flight, you will amend this clearance both up and down. I've had clearances which had 8,000 foot deep altitude blocks! You are coming down somewhere, I don't have an argument there, but ATC has a big manual called the TERPS Manual that they have to operate by. It is their ball and chain that they operate by, and if they've issued us a clearance, they have some pretty tight parameters that they want us to fly by in their airspace. TERPS means Terminal Instrument Procedures. Do you seriously intend to fly an ILS in a glider? I didn't think so. Likewise, DP's STAR's and all other IAP's are irrelevant to IFR gliders. Gliders need to depart and arrive under VFR. TERPS doesn't apply. Let's say that your here at my club in Texas. My specific question here would be how would you file the route portion. Let's say you use a fix near TSA to start. Now, how do I file the altitude? A block is probably the best way, as you mentioned, but how do you guarantee your local controllers that your going to remain in that block, especially if the bottom fills in below you while your cruising. This is why I'm a bit suspect that there are some loose ends to flying gliders IFR, from a totally legal standpoint. As for filing your route, just file direct. For altitude, file for your estimated max altitude. In the remarks section, write: Glider flight. Will require course deviations and block altitudes from ATC. Yes, you must remain within the parameters of the clearance. So, you shouldn't accept a clearance that you can't comply with. If you're at 5,170 feet and scratching in weak lift, do not accept an altitude clearance that requires you to remain above 5,000 feet! Likewise, if you've encountered unexpected sink, advise ATC that you will need a new altitude clearance. It all comes down to COMMUNICATION! I beg to differ that it is nothing like flying an airplane IFR. 90% of flying an airplane IFR includes VMC departures and arrivals, with only a few moments in IMC conditions. Just like a glider. Thanks for the input You're welcome. Now let me add this: to safely fly a glider in IFR conditions, the pilot must be able to walk and chew gum at the same time. Flying a glider effectively on a cross-country is challenging. Flying single-pilot IFR is challenging. Flying a glider on a single-pilot IFR cross-country is extremely challenging. Prerequisites should include many recent hours in both glider cross-countries and IFR procedures. At the risk of speaking for others, glider pilots that fly IFR have huge personal weather minimums. They won't consider flying IFR unless they are certain that they will be able to cancel IFR and continue to their destination under VFR with a significant safety margin. Most pilots will file IFR with no intention of ever flying into a cloud. Instead, they want to be able to fly closer to the cloud than the minimum distances required for VFR. Most IFR cross-countries are in mountain waves, and the risk of going from clear and a million to suddenly being engulfed in a thick cloud is real. Being on an IFR flight plan is a safety measure. Finally, nothing can substitute for good judgment. IFR in gliders can be a valuable tool, but it can easily kill you. Don't even think of doing it unless you are certain that there is no risk from doing it. Actually, your criteria should be the opposite: do it only if you think it is the safer option. Chris Fleming, F2 ATP B-767, CFI-G |
Kid day at the airport... | Jay Honeck | Piloting | 92 | September 20th 05 04:42 AM |
Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 01:54 AM |
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 08:48 PM |
Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 10:36 AM |
ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 04:30 AM |
