Snoop,
That's more like it: specific questions. It appears to me that you are making this way too difficult. Here we go: snoop wrote: Chris, Specifically, where does the clearance begin, and end. ATC is going to want a starting point and an exit point. What is your intended task? If you're going from A to B and landing at B, then file from A to B. Most glider cross-countries start and end at the same place, so file from A to A via B and C. You can amend your clearance at any time. If you don't think you can make B, just tell ATC and request clearance to C, or back to A or to a new destination D. In short, just tell them what you want to do! Going back to my earlier note, how do you get up and down? The cloud layer closes in below you while your going x country IFR in a pure glider, how do you legally get down. I'm not sure I understand your question. Your initial clearance is going to have an altitude block. Throughout your flight, you will amend this clearance both up and down. I've had clearances which had 8,000 foot deep altitude blocks! You are coming down somewhere, I don't have an argument there, but ATC has a big manual called the TERPS Manual that they have to operate by. It is their ball and chain that they operate by, and if they've issued us a clearance, they have some pretty tight parameters that they want us to fly by in their airspace. TERPS means Terminal Instrument Procedures. Do you seriously intend to fly an ILS in a glider? I didn't think so. Likewise, DP's STAR's and all other IAP's are irrelevant to IFR gliders. Gliders need to depart and arrive under VFR. TERPS doesn't apply. Let's say that your here at my club in Texas. My specific question here would be how would you file the route portion. Let's say you use a fix near TSA to start. Now, how do I file the altitude? A block is probably the best way, as you mentioned, but how do you guarantee your local controllers that your going to remain in that block, especially if the bottom fills in below you while your cruising. This is why I'm a bit suspect that there are some loose ends to flying gliders IFR, from a totally legal standpoint. As for filing your route, just file direct. For altitude, file for your estimated max altitude. In the remarks section, write: Glider flight. Will require course deviations and block altitudes from ATC. Yes, you must remain within the parameters of the clearance. So, you shouldn't accept a clearance that you can't comply with. If you're at 5,170 feet and scratching in weak lift, do not accept an altitude clearance that requires you to remain above 5,000 feet! Likewise, if you've encountered unexpected sink, advise ATC that you will need a new altitude clearance. It all comes down to COMMUNICATION! I beg to differ that it is nothing like flying an airplane IFR. 90% of flying an airplane IFR includes VMC departures and arrivals, with only a few moments in IMC conditions. Just like a glider. Thanks for the input You're welcome. Now let me add this: to safely fly a glider in IFR conditions, the pilot must be able to walk and chew gum at the same time. Flying a glider effectively on a cross-country is challenging. Flying single-pilot IFR is challenging. Flying a glider on a single-pilot IFR cross-country is extremely challenging. Prerequisites should include many recent hours in both glider cross-countries and IFR procedures. At the risk of speaking for others, glider pilots that fly IFR have huge personal weather minimums. They won't consider flying IFR unless they are certain that they will be able to cancel IFR and continue to their destination under VFR with a significant safety margin. Most pilots will file IFR with no intention of ever flying into a cloud. Instead, they want to be able to fly closer to the cloud than the minimum distances required for VFR. Most IFR cross-countries are in mountain waves, and the risk of going from clear and a million to suddenly being engulfed in a thick cloud is real. Being on an IFR flight plan is a safety measure. Finally, nothing can substitute for good judgment. IFR in gliders can be a valuable tool, but it can easily kill you. Don't even think of doing it unless you are certain that there is no risk from doing it. Actually, your criteria should be the opposite: do it only if you think it is the safer option. Chris Fleming, F2 ATP B-767, CFI-G |
Chris,
I don't want to make it difficult. What I do want is for those of us, who want to protect our sport of soaring from, the intense scrutiny of the public eye, and the heavy hand of big brother, to think through this difficult subject. As seen in this thread there is a lot to this thing we call IFR flying. I fly IFR everyday at work, all around the world. Its wonderful, and like flying gliders, gives a lot of satisfaction to the pilot side of the brain. Your input has been very helpful, but to me there are still a lot of loose ends. When I flew cargo in twin cessnas, back in the late seventies, we filed our own flight plans with the FSS desk at DPA, under the watchful eye of Theo Moore, the king of the local FSDO. Theo would collect our flight plans and go over each box on that little flight plan card to see that we met the letter of the law. For instance if it was a day when it was lifr, he would check the validity of our alternate, our fuel. The guy was not bashful about doing this while standing behind the counter as we filled them in. All our pilots received a first hand lesson in what goes in each of those little boxes, and why. Lessons that still apply today whether filing into MKE, or VIDP. My point here is I'm still fuzzy on the official guys (FSS, ATC) accepting something as simple as the flight plan for our glider as you described. From an operational viewpoint, it's clear as a bell to me, it's simple. I've received untold numbers of pop up clearances in the past. There are still MEAs, MOCAs, MVAs, things, that the contollers have to govern who they turn loose in the clouds. How does the local guy work around these. Again it appears quite simple from the operational end, but....... Then, there is local knowledge, which I'm thinking goes a long way with glider IFR. That is what we need clarification of. And use conservative common sense. But that term is not in the FAAs handbook. As you well know most of these FAA regs have blood written on them. I would have to have the controller himself tell me the TERPs are out the window when it comes to my glider flying IFR. What I'm hoping Shawn will do before publishing anything about IFR glider flying is to take all of our points, sit down with his local FSS, ATC guys, the guys who give him his clearance, and hash it out. Maybe get Shawn, or anyone else who knows how to, no, wait, there are a lot of people who think they know how it's done, let's get those who do file, and fly their glider IFR, to get their local ATC/FSS people to present a paper, or talk to the local groups, about the procedures and responsibilities of flying our gliders IFR. With all due respect to Shawn and his paper, these things, he has probably done! Your exactly right about doing it as a "safe option". We might have to dance with the feds, after the help ATC gives us, to get us back to VFR conditions, but we sure don't want a 340 knot mustard colored suppositorie up the backside. snoop Fox Two wrote: Snoop, That's more like it: specific questions. It appears to me that you are making this way too difficult. Here we go: snoop wrote: Chris, Specifically, where does the clearance begin, and end. ATC is going to want a starting point and an exit point. What is your intended task? If you're going from A to B and landing at B, then file from A to B. Most glider cross-countries start and end at the same place, so file from A to A via B and C. You can amend your clearance at any time. If you don't think you can make B, just tell ATC and request clearance to C, or back to A or to a new destination D. In short, just tell them what you want to do! Going back to my earlier note, how do you get up and down? The cloud layer closes in below you while your going x country IFR in a pure glider, how do you legally get down. I'm not sure I understand your question. Your initial clearance is going to have an altitude block. Throughout your flight, you will amend this clearance both up and down. I've had clearances which had 8,000 foot deep altitude blocks! You are coming down somewhere, I don't have an argument there, but ATC has a big manual called the TERPS Manual that they have to operate by. It is their ball and chain that they operate by, and if they've issued us a clearance, they have some pretty tight parameters that they want us to fly by in their airspace. TERPS means Terminal Instrument Procedures. Do you seriously intend to fly an ILS in a glider? I didn't think so. Likewise, DP's STAR's and all other IAP's are irrelevant to IFR gliders. Gliders need to depart and arrive under VFR. TERPS doesn't apply. Let's say that your here at my club in Texas. My specific question here would be how would you file the route portion. Let's say you use a fix near TSA to start. Now, how do I file the altitude? A block is probably the best way, as you mentioned, but how do you guarantee your local controllers that your going to remain in that block, especially if the bottom fills in below you while your cruising. This is why I'm a bit suspect that there are some loose ends to flying gliders IFR, from a totally legal standpoint. As for filing your route, just file direct. For altitude, file for your estimated max altitude. In the remarks section, write: Glider flight. Will require course deviations and block altitudes from ATC. Yes, you must remain within the parameters of the clearance. So, you shouldn't accept a clearance that you can't comply with. If you're at 5,170 feet and scratching in weak lift, do not accept an altitude clearance that requires you to remain above 5,000 feet! Likewise, if you've encountered unexpected sink, advise ATC that you will need a new altitude clearance. It all comes down to COMMUNICATION! I beg to differ that it is nothing like flying an airplane IFR. 90% of flying an airplane IFR includes VMC departures and arrivals, with only a few moments in IMC conditions. Just like a glider. Thanks for the input You're welcome. Now let me add this: to safely fly a glider in IFR conditions, the pilot must be able to walk and chew gum at the same time. Flying a glider effectively on a cross-country is challenging. Flying single-pilot IFR is challenging. Flying a glider on a single-pilot IFR cross-country is extremely challenging. Prerequisites should include many recent hours in both glider cross-countries and IFR procedures. At the risk of speaking for others, glider pilots that fly IFR have huge personal weather minimums. They won't consider flying IFR unless they are certain that they will be able to cancel IFR and continue to their destination under VFR with a significant safety margin. Most pilots will file IFR with no intention of ever flying into a cloud. Instead, they want to be able to fly closer to the cloud than the minimum distances required for VFR. Most IFR cross-countries are in mountain waves, and the risk of going from clear and a million to suddenly being engulfed in a thick cloud is real. Being on an IFR flight plan is a safety measure. Finally, nothing can substitute for good judgment. IFR in gliders can be a valuable tool, but it can easily kill you. Don't even think of doing it unless you are certain that there is no risk from doing it. Actually, your criteria should be the opposite: do it only if you think it is the safer option. Chris Fleming, F2 ATP B-767, CFI-G |
![]() snoop wrote: Chris, I don't want to make it difficult. Then don't. I was a freight dog, too. I always had to watch everything with a magnifying glass to make sure I was legal to the letter. I understand your mindset. But this isn't that. My point here is I'm still fuzzy on the official guys (FSS, ATC) accepting something as simple as the flight plan for our glider as you described. From an operational viewpoint, it's clear as a bell to me, it's simple. I've received untold numbers of pop up clearances in the past. You're right. FSS/ATC may not have ever received an IFR request from a glider before. But they will likely be excited to do something different. Once I'm on the frequency, I quickly become a celebrity. The controllers are asking me questions purely out of curiosity, and I get funny one liners like: ATC: American 325 climb and maintain 17,000, expect further climb in 20 miles, you have traffic at 11 o'clock 15 miles at FL190, a glider. AMR325: What the h*&% is a glider doing up there?! Me: Descending! My point is that controllers will work with you if you work with them. Fitting a glider into their traffic flow can be a burden to them, so make it less so. Stay away from busy airways. If you need to transit a busy airway, you may need to wait for a few minutes for ATC to make room. Then when you're cleared to proceed, cross the airway quickly so they can use it again. If they need an altitude that you've currently got blocked, if you can, release it back to them to get the transient through. Let's all just get along. There are still MEAs, MOCAs, MVAs, things, that the contollers have to govern who they turn loose in the clouds. How does the local guy work around these. Again it appears quite simple from the operational end, but....... You're scaring me, snoop! Gliders aren't operating anywhere near the MEA! Use some judgment here. As you well know most of these FAA regs have blood written on them. I would have to have the controller himself tell me the TERPs are out the window when it comes to my glider flying IFR. Snoop, TERPS apply to terrain & obstruction clearance during departure and arrival. We're not doing that. We are thousands of feet off the ground with cloudbase being thousands of feet above the ground. We're not flying low IFR; we're flying into an isolated cloud, or flying along the edge of a lenticular. let's get those who do file, and fly their glider IFR, to get their local ATC/FSS people to present a paper, or talk to the local groups, about the procedures and responsibilities of flying our gliders IFR. What do you think we're doing? Perhaps you should take a break from typing, and reread the entire thread. Your questions have been answered. IFR in gliders in legal, and people do it every day. Here's my recommendation to you, snoop. You already know that you learned more on your first night flying freight out of Chicago than you did in all of your previous training. So, take an IFR-equipped glider and fly it IFR in VMC conditions. Take your normal tow, release, and climb several thousand feet. Then call up ATC, pick up an IFR clearance to maneuver in the vicinity. Explore the cloudbase, but don't go into the cloud (for safety). Then cancel IFR, and go home. Viola! IFR in gliders. Small steps. Chris Fleming, F2 |
![]() Fox Two wrote: You're right. FSS/ATC may not have ever received an IFR request from a glider before. But they will likely be excited to do something different. Once I'm on the frequency, I quickly become a celebrity. The controllers are asking me questions purely out of curiosity, and I get funny one liners like: ATC: American 325 climb and maintain 17,000, expect further climb in 20 miles, you have traffic at 11 o'clock 15 miles at FL190, a glider. AMR325: What the h*&% is a glider doing up there?! Me: Descending! Chris, this is the exact reason I'm still looking for the technical answers. You just made about every working pilot reading your celebrity dialouge, pass out. "11o'clock 15 miles", your descending out of who knows what exact altitude, and the big boy is climbing toward you, this would wake everyone up. I would venture that the captain on that AA flights' first thought would be, "we're turning now", then he would ask the center about the accuracy of the gliders' altimeter. You're scaring me, snoop! Gliders aren't operating anywhere near the MEA! Use some judgment here. Chris, I'll give you the benefit of the doubt here and assume you mean that your not doing this near an airway. MEA is an altitude, and although you may be flying in the Flight Levels, MEA's do run from down in the thousands to the flight levels. Snoop, TERPS apply to terrain & obstruction clearance during departure and arrival. We're not doing that. We are thousands of feet off the ground with cloudbase being thousands of feet above the ground. We're not flying low IFR; we're flying into an isolated cloud, or flying along the edge of a lenticular. Chris, I will concur that we're not flying low IFR, and we won't be doing ILS approaches, although I have a glider accident in mind, where the pilot did try to penetrate some LIFR weather and lost. He lived, but there was a lot of serious head scratching on his part. The answers I'm looking for, the fundamental, basic answers we need are, how do I explain my right to be at 19,000ft with an airliner bearing down on me, (your scenario), to the fed that meets me on the ramp after the part 121 captain calls this in. Your a professional pilot, what are your words to all the basic, specific, fundamental, IFR pilot/equipment questions that your going to face? What do you think we're doing? Perhaps you should take a break from typing, and reread the entire thread. Your questions have been answered. IFR in gliders in legal, and people do it every day. Chris, I'm not convinced, and saying people do it everyday, well let's just say I think all USA clubs need to get the donuts out and talk this one up. I know there are people in clubs who can get this discussion going. Here's my recommendation to you, snoop. You already know that you learned more on your first night flying freight out of Chicago than you did in all of your previous training. So, take an IFR-equipped glider and fly it IFR in VMC conditions. Take your normal tow, release, and climb several thousand feet. Then call up ATC, pick up an IFR clearance to maneuver in the vicinity. Explore the cloudbase, but don't go into the cloud (for safety). Then cancel IFR, and go home. Viola! IFR in gliders. Small steps. Chris I would love to turn on a t&b and climb into the cloud, but I want to know that my bases are covered! I want the blessing of the people who would otherwise fry me, and you! It would be fun just to be the celebrity kind of pilot, and forge ahead, but I've found in my world it's been more enjoyable, to find out the facts, do it right, and let the feds go after the uninformed. Later, I'm off to the soaring club! |
![]() snoop wrote: Chris, this is the exact reason I'm still looking for the technical answers. You just made about every working pilot reading your celebrity dialouge, pass out. "11o'clock 15 miles", your descending out of who knows what exact altitude, and the big boy is climbing toward you, this would wake everyone up. I would venture that the captain on that AA flights' first thought would be, "we're turning now", then he would ask the center about the accuracy of the gliders' altimeter. Oh, for God's sake, snoop. You're really beginning to annoy me. If you fly IFR as much as you say you do, you hear that every day. Aircraft A receives a hold down clearance until he is clear of traffic B above. American was thousands of feet below me, climbing to an altitude two thousand feet below me. He saw me on his TCAS. There was no conflict. ATC was providing separation. Everybody was happy. Geez. Chris, I'll give you the benefit of the doubt here and assume you mean that your not doing this near an airway. MEA is an altitude, and although you may be flying in the Flight Levels, MEA's do run from down in the thousands to the flight levels. Snoop, we aren't navigating airways! In fact, no navigation equipment of any kind is required to fly IFR! You need to stop thinking like a 135/121 airplane pilot. You're in a GLIDER. The world of aviation is a big place, and most pilots are only familiar with their little slice of it. You need to think outside of your box. Scroll up to my first message; I've referenced the exact regs that legalize IFR gliders. It is legal. Period. My final case-in point: The Goodyear Blimp flies IFR over football games all of the time. There are tens of thousands of people who are first-person eye witnesses to this fact as they watch the blimp fly in and out of the clouds on a snowy day. Millions more see this on TV. I'm sure that one or two of those fans is a fed. The pilot of the blimp is getting paid. It's a commercial operation with passengers on board. But there is no requirement for that pilot to have an instrument rating of any kind. He might be 1,000 feet AGL, definitely below the lowest minimum IFR altitude for airplanes. He's IFR without a rating, and he's perfectly legal. It's a big world out there, snoop. The rules that apply to airplane 135/121 don't apply to all other types of flying. Going out to the glider club? That's sounds good. I'll join you. Chris Fleming, F2 |
![]() Oh, for God's sake, snoop. You're really beginning to annoy me. If you fly IFR as much as you say you do, you hear that every day. Aircraft A receives a hold down clearance until he is clear of traffic B above. American was thousands of feet below me, climbing to an altitude two thousand feet below me. He saw me on his TCAS. There was no conflict. ATC was providing separation. Everybody was happy. Geez. Chris, I'm getting annoyed with this thread too. I've got a note into Shawn, will give a report after he briefs us. Let's put someone else in charge of stirring this pot. Todd your in charge. F2 if your in the Big D look us up at TSA. And the 135/121 comment really cut deep! Later, snoop Going out to the glider club? That's sounds good. I'll join you. Chris Fleming, F2 |
snoop wrote:
Chris, I'm getting annoyed with this thread too. I've got a note into Shawn, will give a report after he briefs us. Let's put someone else in charge of stirring this pot. Todd your in charge. F2 if your in the Big D look us up at TSA. And the 135/121 comment really cut deep! Later, snoop Snoop, I don't know where the Region 10 competition is going to be next year, but maybe I'll see you there. I can understand your frustration with all of this stuff, but the point of this forum is to be able to exchange ideas. Don't take any of it as gospel. You're putting a lot of faith into what Shawn has to say, but he's not perfect, either. He has repeatedly said that § 61.57 doesn't apply to single-pilot operations, but it absolutely does. CFAR § 61.57(c)(2)(i) clearly specifies that in order to act as PIC in a glider under IFR while solo, you need to log at least 3 hours of instrument time in the last 6 months, of which 1 1/2 must be in gliders (the other 1 1/2 may be in either airplanes or gliders): § 61.57 Recent flight experience: Pilot in command. (c) Instrument experience. Except as provided in paragraph (e) of this section, no person may act as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR, unless within the preceding 6 calendar months, that person has: (2) For the purpose of obtaining instrument experience in a glider, performed and logged under actual or simulated instrument conditions- (i) At least 3 hours of instrument time in flight, of which 1 1/2 hours may be acquired in an airplane or a glider if no passengers are to be carried. Also, don't take everything you read in Soaring Magazine to be gospel either. In last month's thread on this topic, we discussed Tom Reesor's letter in the August SOARING magazine. He confidently claimed that to fly a glider IFR one requires: 1. "The pilot to be instrument rated in single-engine airplanes and also have a glider rating ... to fly a glider in clouds," and 2. "Gliders flying on instruments are required to have a full gyro panel." Neither of which is true. CFAR § 61.3(e)(3) states that a glider pilot must have an airplane instrument rating to fly a glider IFR, but it doesn't specify that it needs to be a single-engine class rating: § 61.3 Requirement for certificates, ratings, and authorizations. (e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds: 3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating. And there is no FAR whatsoever that requires a glider to have a "full gyro panel." The only gyroscopic instrument that most glider manufacturers require for cloud flying is a "Turn & Bank Indicator with Slip Ball." So what do you do? Read the regs for yourself. I've referenced the exact FARs to back up everything that I have said. Read your glider's manual. Is your glider approved for cloud flying? If your glider has an experimental certificate, read your operating limitations. Did the FAA approve your glider for cloud flying? And, has your glider received all of its required inspections? If, after all of this you have determined that you meet all of the requirements to fly your glider IFR, you're legal to do so. So how do you do it? Personally, I don't file a flight plan. I only use IFR as a tool to climb into the Class A airspace, and I never know if the mountain wave above El Paso is good enough until I'm airborne. My climb to 17,000 feet is VFR with El Paso Approach Control, and if I'm still climbing strong, I'll request a handoff to Albuquerque Center and request an IFR climb with them. They first verify my transponder code, position and altitude, then ask for my intentions. I request altitude blocks in 4,000 foot increments, so the first clearance that I receive is from 16,000 to FL 200. As I climb and descend, ABQ shifts the block up and down. My mountain wave flights have all been local in nature, so my lateral clearance is defined by radials and distances from El Paso VOR, which I have programmed into my GPS. When I descend through 17,000 after my wave flight, I cancel IFR. I have never had any difficulties. In fact, the controllers have always been more than helpful. As a side note, I have never, nor do I ever intend, to fly a pure glider in a cloud. I'll wait for my Nimbus-4DM to arrive before I do that. Now where's that lottery ticket? Chris Fleming, F2 |
snoop wrote:
...Let's put someone else in charge of stirring this pot. Todd your in charge. Nobody's in charge here!!! Geez! I thought I'd left management pilots behind years ago! GC |
snoop wrote:
Chris I would love to turn on a t&b and climb into the cloud, but I want to know that my bases are covered! I want the blessing of the people who would otherwise fry me, and you! It would be fun just to be the celebrity kind of pilot, and forge ahead, but I've found in my world it's been more enjoyable, to find out the facts, do it right, and let the feds go after the uninformed. Chris sounds pretty informed to me and you sound like you're a natural bureaucrat with a check pilot background. Thank God you weren't on my seniority list. You're not looking for information - you want to stop HIM doing it! If you don't want to do it - DON'T DO IT! Now let it go. GC |
![]() snoop wrote: Chris, this is the exact reason I'm still looking for the technical answers. You just made about every working pilot reading your celebrity dialouge, pass out. "11o'clock 15 miles", your descending out of who knows what exact altitude, and the big boy is climbing toward you, this would wake everyone up. I would venture that the captain on that AA flights' first thought would be, "we're turning now", then he would ask the center about the accuracy of the gliders' altimeter. So Snoop, just by replacing the word "glider" in the above exchange with "your favorite trustworthy aircraft", your whole attitude would change? Explain exactly why hearing the work "Lear" for example would make you feel better? I'm sure there's a few rotting away at airports that are marginally airworthy, and might even have an owner who flew IFR 20 years ago, and is just itchin' to go fly...... Bottom line - if the glider is on a clearance we MUST assume the glider will behave just as any other aircraft. Because if we don't, then how on earth can we assume any one of the other aircraft will behave as well? This whole discussion is about SOARING in clouds. Except in the mountains, this means there WILL be a decent clearance between ground, VMC, and cloudbase. The glider pilot is not concerned with terrain, because in this situation it IS NOT AN ISSUE. If it were, the glider pilot likely would not fly. You are clouding the issue by insisting the glider operation take place at 500' AGL in fog directly over the tower at DFW. What we are talking about is operation at say, 6,000' AGL and above in the middle of Kansas. The only issues are about what is required to be legal to continue circling up into that nice towering cu. And once topped out at FL200, the glider pops out the side, then continues on to the next nice cloud in VMC. The glider pilot has, at all times, the option to change course and descend if asked by ATC. The controller and glider pilot COMMUNICATE, and establish an understanding that it may be possible that the glider will hit sink, but in that case, there is always the option to change course to stay clear of any traffic below the glider. As others have posted, flight in IMC without an autopilot can be difficult and tiring. The glider is only using the cloud to thermal up, then glide out the side in order to spend as little time in cloud as possible. This XC flight has no need of any fancy navigational equipment beyond a compass, as the pilot is planning to be VMC 95% of the time. -Tom CFIG, PVT ASEL with about 150 hours in airplanes, no instrument experience, and not planning to fly into clouds anytime soon. |
Kid day at the airport... | Jay Honeck | Piloting | 92 | September 20th 05 04:42 AM |
Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 01:54 AM |
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 08:48 PM |
Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 10:36 AM |
ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 04:30 AM |
