Shawn,
Thanks for all the info. In regard to your questions about certificates, let's do the resume over the phone. Suffice it to say, I'm very current. Should I use the email address in your profile, minus the remove to reply? When do you hit US soil? Take care over there. snoop Shawn Knickerbocker wrote: Snoop.... Thank you for this information. I've been wondering about this very subject. I'm just curious if you have discussed this with your local FSDO, and or any local air traffic controllers. Yes.....the FSDO has no idea..I have been cloud flying IMC for over 15 yrs. It's legal if you are trained properly & certify as well. I'm still looking for the reg that says gliders don't have to have the required 24 month checks on their xponder, static system, etc. Where do I find that? Gliders do not need it! FAR 91.411 I believe...I do not have my FAR's in front of me...I am in Quatar. Also, xponder not required under FAR 91.205 & 411. Xpoder is required only in specified airspace, and that is wavierable. Again check FAR 91. It's all in there. Also, your efis equipment, is it approved equipment? I'm sure it's not, say, some of that efis equipment that homebuilders are putting in their ships. The EFIS I have selected is by Dyno Avionics. It does not have to be approved. Each sailplane manufacture states in their POH/Flt Manual what is required for IMC flight..Usually it is just a T&B. The equipment in your panel has to be approved for IFR flight doesn't it? Not necessary, unless you installed a xponder, it must be tested IAW FAR 91 & 43. I know it looks and works great, but a lot, most of its' not approved for IFR flight. You are receiving bad information,. Experimental aircraft can fly IFR/IMC, its address in their "Operational Limitations". Also, when you receive your ATC clearance, how does the controller give you an altitude? In what format? Usually a clearance is like this: JAX approach sailplane 253SK with a request over. JAX approach responds, go ahead. Requesting IFR clearance or recovery, present position to 15, 15,000. JAx approach response is usually, hey is that you Shawn, then I am golden!!! LOL, squawk 4611, cleared to the HEG airport via radar vectors climb & maintain 1-5, 15,000, approved as requested. Then, I amend or change as required, when I get to 14,000 and climbing I will ask for a higher altitude. There are a lot of questions that I need to answer about IFR flight in gliders. I know my local Flight Standard District Office would have questions for me if I didn't do it right. Questions for you: Are you instrument rated? ASE or AME or hold an ATP ASE or ME rating? How current are you? I recommend not flying IMC in a sailplane unless you have more than a T&B. I have done it with a T&B and it is difficult, especially turns. Straight decent are easy or climbs. Unfortunately, SSA will not print my complete article. If you send me a tele # I can call.... you.. Thanks Shawn |
Kid day at the airport... | Jay Honeck | Piloting | 92 | September 20th 05 04:42 AM |
Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 01:54 AM |
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 08:48 PM |
Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 10:36 AM |
ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 04:30 AM |
