snoop wrote:
Chris, I'm getting annoyed with this thread too. I've got a note into Shawn, will give a report after he briefs us. Let's put someone else in charge of stirring this pot. Todd your in charge. F2 if your in the Big D look us up at TSA. And the 135/121 comment really cut deep! Later, snoop Snoop, I don't know where the Region 10 competition is going to be next year, but maybe I'll see you there. I can understand your frustration with all of this stuff, but the point of this forum is to be able to exchange ideas. Don't take any of it as gospel. You're putting a lot of faith into what Shawn has to say, but he's not perfect, either. He has repeatedly said that § 61.57 doesn't apply to single-pilot operations, but it absolutely does. CFAR § 61.57(c)(2)(i) clearly specifies that in order to act as PIC in a glider under IFR while solo, you need to log at least 3 hours of instrument time in the last 6 months, of which 1 1/2 must be in gliders (the other 1 1/2 may be in either airplanes or gliders): § 61.57 Recent flight experience: Pilot in command. (c) Instrument experience. Except as provided in paragraph (e) of this section, no person may act as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR, unless within the preceding 6 calendar months, that person has: (2) For the purpose of obtaining instrument experience in a glider, performed and logged under actual or simulated instrument conditions- (i) At least 3 hours of instrument time in flight, of which 1 1/2 hours may be acquired in an airplane or a glider if no passengers are to be carried. Also, don't take everything you read in Soaring Magazine to be gospel either. In last month's thread on this topic, we discussed Tom Reesor's letter in the August SOARING magazine. He confidently claimed that to fly a glider IFR one requires: 1. "The pilot to be instrument rated in single-engine airplanes and also have a glider rating ... to fly a glider in clouds," and 2. "Gliders flying on instruments are required to have a full gyro panel." Neither of which is true. CFAR § 61.3(e)(3) states that a glider pilot must have an airplane instrument rating to fly a glider IFR, but it doesn't specify that it needs to be a single-engine class rating: § 61.3 Requirement for certificates, ratings, and authorizations. (e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds: 3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating. And there is no FAR whatsoever that requires a glider to have a "full gyro panel." The only gyroscopic instrument that most glider manufacturers require for cloud flying is a "Turn & Bank Indicator with Slip Ball." So what do you do? Read the regs for yourself. I've referenced the exact FARs to back up everything that I have said. Read your glider's manual. Is your glider approved for cloud flying? If your glider has an experimental certificate, read your operating limitations. Did the FAA approve your glider for cloud flying? And, has your glider received all of its required inspections? If, after all of this you have determined that you meet all of the requirements to fly your glider IFR, you're legal to do so. So how do you do it? Personally, I don't file a flight plan. I only use IFR as a tool to climb into the Class A airspace, and I never know if the mountain wave above El Paso is good enough until I'm airborne. My climb to 17,000 feet is VFR with El Paso Approach Control, and if I'm still climbing strong, I'll request a handoff to Albuquerque Center and request an IFR climb with them. They first verify my transponder code, position and altitude, then ask for my intentions. I request altitude blocks in 4,000 foot increments, so the first clearance that I receive is from 16,000 to FL 200. As I climb and descend, ABQ shifts the block up and down. My mountain wave flights have all been local in nature, so my lateral clearance is defined by radials and distances from El Paso VOR, which I have programmed into my GPS. When I descend through 17,000 after my wave flight, I cancel IFR. I have never had any difficulties. In fact, the controllers have always been more than helpful. As a side note, I have never, nor do I ever intend, to fly a pure glider in a cloud. I'll wait for my Nimbus-4DM to arrive before I do that. Now where's that lottery ticket? Chris Fleming, F2 |
Kid day at the airport... | Jay Honeck | Piloting | 92 | September 20th 05 04:42 AM |
Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 01:54 AM |
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 08:48 PM |
Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 10:36 AM |
ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 04:30 AM |
