Grumman-581 wrote:
On Fri, 25 Aug 2006 10:19:24 -0500, (Jay Masino) wrote: I've used 100LL when my plane was 150hp, as well as 160. Never had a problem. I switched to REM37BY spark plugs a long time ago... that may have helped. I often wish I was still 150hp, though, so I could use autogas. I can use autogas in my O-320 after I converted it from 150 hp to 160 hp... Have to use a minimum of 91 octane though... Which STC? Petersen's version is now something like $2500, plus installation, because it requires a bunch of fuel system changes including dual fuel pumps. At this point, I can still buy a lot of avgas for that $2500. --- Jay -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Grumman-581 wrote:
On Fri, 25 Aug 2006 13:09:55 -0500, (Jay Masino) wrote: Which STC? Petersen's version is now something like $2500, plus installation, because it requires a bunch of fuel system changes including dual fuel pumps. At this point, I can still buy a lot of avgas for that $2500. Yeah, mine was the Petersen's version and it was nowhere close to that price... No modifications to the aircraft other than to put a sticker near the each gas cap on each wing and a metal tag on the engine... It was something like a buck or so per HP, if I remember correctly... Did you get the autogas STC before you went to 160hp? Anyway, I exchanged e-mail with them last year, and all the "high compression" (ha, ha) PA28s (-160, -180, -161, -181, etc) require the "special" fuel system mods. I'm actually in an even more uncertain situation, because of my Powerflow exhaust. Since I don't have the rear mounted muffler of a typical 140, they were uncertain of how/if the STC would apply. Apparently, the exhaust heat being close to the fuel system (near the firewall) was one of the factors that required the high compression aircraft to need the upgraded fuel system. --- Jay -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
A Piper Cherokee 140... good first plane? | Cecil Chapman | Owning | 20 | September 4th 05 02:50 PM |
Cherokee Pilots Association Fly-In Just Gets Better and Better | Jay Honeck | Piloting | 7 | August 8th 05 07:18 PM |
Cherokee National Fly-In & Convention - THIS MONTH | Don | General Aviation | 0 | June 3rd 04 05:01 AM |
Cherokee National Fly-In & Convention | Don | General Aviation | 0 | May 5th 04 08:12 PM |
Cherokee National Fly-In & Convention | Don | Piloting | 1 | March 20th 04 05:27 AM |
