![]() Ernest Christley wrote: wrote: But of course! I already have a homebuilt trailer license for the homebuilt trailer I made for the glider... Hmmm, funny how it up and changed shape and color. BTW, this is 1 mile on small roads, Sunday morning, I dont have any gyros, 20 mph the whole way, no pot-wholes. -Bruce The Dyke Delta is designed to be towed on it's own wheels. One of the builders, lives in Conneticut, had problems getting it registered as a trailer. Seems they don't allow trailers to have their own propulsion system. YMMV. Well it doesn't have it's own propulsion system for propelling it down the highway. I'm sure the reason for th erestriction is so people can't buy trailer plates for vehicles that are supposed to have different (and probably more expensive) plates. -- FF |
oups.com... Ernest Christley wrote: wrote: But of course! I already have a homebuilt trailer license for the homebuilt trailer I made for the glider... Hmmm, funny how it up and changed shape and color. BTW, this is 1 mile on small roads, Sunday morning, I dont have any gyros, 20 mph the whole way, no pot-wholes. -Bruce The Dyke Delta is designed to be towed on it's own wheels. One of the builders, lives in Conneticut, had problems getting it registered as a trailer. Seems they don't allow trailers to have their own propulsion system. YMMV. Well it doesn't have it's own propulsion system for propelling it down the highway. I'm sure the reason for th erestriction is so people can't buy trailer plates for vehicles that are supposed to have different (and probably more expensive) plates. -- FF To expand a little on Jim Carriere's earlier point, many (probably most) towing compainies have a more favorable rate for a non-emergency tow than for on-demand. Life is best for them when they can reduce their amount of dead-heading. So, you might watch for a carefull driver with a roll-back in your area and talk to him. BTW, if your a/c is wider than the truck, I would still seriously consider an escort--especially after dark, and I would avoid friday and saturday nights. Peter |
![]() Ernest Christley wrote: wrote: Ernest Christley wrote: wrote: But of course! I already have a homebuilt trailer license for the homebuilt trailer I made for the glider... Hmmm, funny how it up and changed shape and color. BTW, this is 1 mile on small roads, Sunday morning, I dont have any gyros, 20 mph the whole way, no pot-wholes. -Bruce The Dyke Delta is designed to be towed on it's own wheels. One of the builders, lives in Conneticut, had problems getting it registered as a trailer. Seems they don't allow trailers to have their own propulsion system. YMMV. Well it doesn't have it's own propulsion system for propelling it down the highway. I'm sure the reason for th erestriction is so people can't buy trailer plates for vehicles that are supposed to have different (and probably more expensive) plates. Doesn't matter. Jim had to go home and build a trailer after the DOT guy said he couldn't get a trailer license for his airplane. That was Conneticut, I believe. A portable trailer-mounted generator has an engine, a propulsion system for electrons. Would he have to put it on a second trailer to tow it in Connecticut? Or would the fact that the engine doesn't drive the wheels be what matters? I think maybe he should have talked to more than one DOT guy, maybe politely asked to talk to a supervisor. -- FF |
![]() wrote A portable trailer-mounted generator has an engine, a propulsion system for electrons. Would he have to put it on a second trailer to tow it in Connecticut? Or would the fact that the engine doesn't drive the wheels be what matters? I think maybe he should have talked to more than one DOT guy, maybe politely asked to talk to a supervisor. Asking to see the applicable portion of the code would not be too much to ask, and also would help in deciding exactly what other rules might need to be followed. -- Jim in NC |
![]() Ernest Christley wrote: wrote: A portable trailer-mounted generator has an engine, a propulsion system for electrons. Would he have to put it on a second trailer to tow it in Connecticut? Or would the fact that the engine doesn't drive the wheels be what matters? I think maybe he should have talked to more than one DOT guy, maybe politely asked to talk to a supervisor. I wasn't there, and they didn't call to ask for my input 8*) Nor mine... but... I just looked up the old newsletter article. Here it is, straight from the builders's mouth. Make of it what you will. Thanks for checking. "... It seems that in order to qualify, as a trailer, the vehicle cannot have its own motive power, and since he considered the engine and propeller motive power he could not allow it. Secondly the statutes specifically prohibit the DMV from registering aircraft as motor vehicles. So that was it. He said that if I wanted to tow it on the road I would have to put it on a trailer. I was, to say the least, very DISSAPOINTED. Assuming that the Ct DMV defines a trailer as a motor vehicle, then yes, he was clearly SOL as there was a rule that expressly prohibitted licensing an airplane as a trailer. The first rule had some wiggle room, the second did not. The authorities had considered exactly that situation and decided to prohibit it. -- FF |
I just towed my plane on it's wheels when it was time to move it to
the airport. I figured if I was stopped I would argue that it is a federally registreed vehicle so no other registration is needed. Now that it's on floats I didn't get it licensed as a boat for when it's on the water. Crop dusters around here sometimes use roads for landing strips too. wrote: A portable trailer-mounted generator has an engine, a propulsion system for electrons. Would he have to put it on a second trailer to tow it in Connecticut? Or would the fact that the engine doesn't drive the wheels be what matters? I think maybe he should have talked to more than one DOT guy, maybe politely asked to talk to a supervisor. I wasn't there, and they didn't call to ask for my input 8*) but... I just looked up the old newsletter article. Here it is, straight from the builders's mouth. Make of it what you will. "He went back into the building and returned with another inspector. This one had a big smile on his face and explained that this was the part of his job that eh loved. He said, "I love to see all these unusual things that people try to register." (Behind me by a couple of vehicles was a Hotdog vendor's wagon). He thought that he would need to take a Polaroid photo of the Delta and fax it to the DOT to get approval. Obviously he was trying to cover his ass so that he would not get into trouble. He went to get the camera and when he returned he explained that he was not going to be able to register it for me. He checked that statutes and found two that apply. It seems that in order to qualify, as a trailer, the vehicle cannot have its own motive power, and since he considered the engine and propeller motive power he could not allow it. Secondly the statutes specifically prohibit the DMV from registering aircraft as motor vehicles. So that was it. He said that if I wanted to tow it on the road I would have to put it on a trailer. I was, to say the least, very DISSAPOINTED. |
Ernest Christley writes:
Doesn't matter. Jim had to go home and build a trailer after the DOT guy said he couldn't get a trailer license for his airplane. So...if you built a trailer that happened to use the gear from the plane you'd be o.k.? What if it used the gear and the fuselage? Is the issue just the engine? --kyler |
Palo Alto airport, potential long-term problems... | [email protected] | Piloting | 7 | June 6th 05 11:32 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
