I always thought that putting the punctuation marks inside the
quotation marks was strange... I was taught that printers, back in Colonial days, thought that periods and commas looked "lonely" if outside the quotation marks, so they began putting them inside for aesthetic reasons. I don't agree with that rule, so I'm quite likely to intentionally break it in my writing... If you move to Canada or any part of the former British Empire, you won't be breaking the rule. Or, you can just break the rule. There is no penalty, unless you happen to writing to a prospective employer. vince norris |
periods and commas looked "lonely" if outside the quotation marks, so they began putting them inside for aesthetic reasons. My information is that in the old days, the thin periods and commas were more delicate, and lasted longer if they were protected by the larger quotes and parens. This is no longer an issue, and I stick with logic. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
periods and commas looked "lonely" if outside the quotation marks, so they began putting them inside for aesthetic reasons. My information is that in the old days, the thin periods and commas were more delicate, and lasted longer if they were protected by the larger quotes and parens. That sounds reasonable, Jose, until you consider that whatever piece of type comes last in the sentence, it is "protected" by the space (is it called an M Quad?) that comes next. Each piece of type in the line is "protected" by the pieces on each side of it. I'm not defending my explanation, btw; I don't know whether or not it's true. vince norris |
whatever piece
of type comes last in the sentence, it is "protected" by the space (is it called an M Quad?) that comes next. Perhaps words got moved around whole? Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
"vincent p. norris" wrote in message
... My information is that in the old days, the thin periods and commas were more delicate, and lasted longer if they were protected by the larger quotes and parens. That sounds reasonable, Jose, until you consider that whatever piece of type comes last in the sentence, it is "protected" by the space (is it called an M Quad?) that comes next. Each piece of type in the line is "protected" by the pieces on each side of it. A space cannot protect a printing character. The component being stressed is the printing portion of the character, the part raised above (and substantially smaller than) the main body of the type element. The point is that during the printing process, each character of type experiences a force against the printed surface, and for the more delicate characters (such as periods and commas), this force would be unevenly distributed, putting a slight lateral component to the force, when there is just a space on one side. Taken singly, this force is slight and seemingly inconsequential. But keep whacking the plate over and over again, and eventually it's going to cause the character portion of the type element to fail prematurely. According to the theory that Jose is describing, by placing the more delicate characters between two printing characters, the lateral force is reduced or even eliminated, "protecting" the more delicate character. One possible flaw in the reasoning is that type elements are not just simple extrusions of the character itself. Most of the time, the character surface is at the top of a sloped raised area on the type element. So a period, even if it's just 1mm across where it prints, may actually have a 5mm (for example, or even larger) base. One would think that would provide extra strength, helping protect against damage. However, I don't think that's necessarily an actual flaw in the reasoning, as all of the type elements have such sloped sides, and the smaller printing characters will still have less material than the larger ones, and may still benefit from protection. In any case, whether or not the theory that Jose related is correct, the theory isn't talking about the main rectangular body of the type element, and so just because there's a spacing type element next to a trailing period, comma, whatever doesn't in any way serve to offer the protection that the theory describes. If anything, the empty space is precisely what causes the problem the theory describes. Pete |
Jose I suppose that's a possibility, but probably happened too rarely to explain changing the "rules" of punctuation. A space cannot protect a printing character. The component being stressed is the printing portion of the character, the part raised above (and substantially smaller than) the main body of the type element. A good point. Your argument is pretty persuasive, Peter. vince norris |
On Sat, 26 Aug 2006 20:52:46 -0400, vincent p. norris
wrote: There is no penalty, unless you happen to writing to a prospective employer. I feel rather certain that my resume contains no quotation marks whatsoever in it, so the likelihood of being presented with that delemma is rather remote... As a software developer, the punctuation marks go outside the quotation marks... That's good enough for me... |
Folding wing for Ercoupes? | Montblack | Home Built | 41 | October 12th 05 09:38 PM |
Folding wing for Ercoupes? | Montblack | Owning | 22 | October 12th 05 09:38 PM |
