Newps wrote:
wrote: What, exactly, is a "legal briefing"? AFSS or DUATS. It's a standard weather briefing. That's no less or more legal than anything else. You're screwed if you don't get all the appropriate information. The fact that a government or government-contracted provider was contacted and they failed to provide the information will not save your hide in an enforcement action. If we're talking weather DUAT/FSS isn't more enlightened than many other outlets. Where do you think the FSS gets it's weather from? (I'll give you a hint, it's not another government agency). |
![]() Ron Natalie wrote: Newps wrote: wrote: What, exactly, is a "legal briefing"? AFSS or DUATS. It's a standard weather briefing. That's no less or more legal than anything else. I remember the FAA saying some other outlets were now legal, don't recall what they are. You're screwed if you don't get all the appropriate information. The fact that a government or government-contracted provider was contacted and they failed to provide the information will not save your hide in an enforcement action. What they give you is proof. Having said that I only get a provable briefing when I'm on the road and away from home. 95% of my flying I simply look out the window. I will look at the TAF's on NOAA.gov the night before but that's about it. We don't have TFR's here except for fires and if the Prez is going to show up I'll know it several days before the press does. If a runway is closed I hope they put X's on the runway like they're required to. If we're talking weather DUAT/FSS isn't more enlightened than many other outlets. Where do you think the FSS gets it's weather from? (I'll give you a hint, it's not another government agency). I use NOAA because I like how it's presented. I occasionally use ADDS for a cross country because I like the JAVA app. I use the Intellicast surface analysis chart and radar loops. I use a Unisys VFR/MVFR chart. |
Newps wrote:
I remember the FAA saying some other outlets were now legal, don't recall what they are. To my knowledge no such assertion has ever been made by the FAA. Noncommercial operators have always been free to do what they thought was prudent. Commercial operators must follow their manual/opspec. What they give you is proof. Having said that I only get a provable briefing when I'm on the road and away from home. 95% of my flying I simply look out the window. I will look at the TAF's on NOAA.gov the night before but that's about it. We don't have TFR's here except for fires and if the Prez is going to show up I'll know it several days before the press does. If a runway is closed I hope they put X's on the runway like they're required to. What proof does this give you? I'll reiterate what I said. Even if you call the FSS and they DO NOT give you the TFR info, that will not save your ass in an enforcement action. |
![]() Ron Natalie wrote: Newps wrote: I remember the FAA saying some other outlets were now legal, don't recall what they are. To my knowledge no such assertion has ever been made by the FAA. There are websites that the FAA said are legal. The problem is you'd have to print them out to prove you were there. Nobody's going to do that. What proof does this give you? I'll reiterate what I said. Even if you call the FSS and they DO NOT give you the TFR info, that will not save your ass in an enforcement action. It does if you ask and they fail to give you the info. That is fairly common here with fires. These TFR's pop up, expand and move with some regularity. There's always someone flying thru where they shouldn't. But if the pilot asked AFSS about TFR's and they were not given the proper info they are off the hook. Same goes for if I tell a pilot the wrong info. That's on me, not on the pilot. That has also happened. |
![]() It does if you ask and they fail to give you the info. That is fairly common here with fires. These TFR's pop up, expand and move with some regularity. There's always someone flying thru where they shouldn't. But if the pilot asked AFSS about TFR's and they were not given the proper info they are off the hook. Same goes for if I tell a pilot the wrong info. That's on me, not on the pilot. That has also happened. Not the way things work on this side of the country. |
![]() Ron Natalie wrote: It does if you ask and they fail to give you the info. That is fairly common here with fires. These TFR's pop up, expand and move with some regularity. There's always someone flying thru where they shouldn't. But if the pilot asked AFSS about TFR's and they were not given the proper info they are off the hook. Same goes for if I tell a pilot the wrong info. That's on me, not on the pilot. That has also happened. Not the way things work on this side of the country. So you have these problems AND you're a blue state? My condolences. |
Newps wrote:
Ron Natalie wrote: It does if you ask and they fail to give you the info. That is fairly common here with fires. These TFR's pop up, expand and move with some regularity. There's always someone flying thru where they shouldn't. But if the pilot asked AFSS about TFR's and they were not given the proper info they are off the hook. Same goes for if I tell a pilot the wrong info. That's on me, not on the pilot. That has also happened. Not the way things work on this side of the country. So you have these problems AND you're a blue state? My condolences. Nope, I'm in a RED state. And it's the facist policies of the RED administration that's causing the problems. |
m... It does if you ask and they fail to give you the info. That is fairly common here with fires. These TFR's pop up, expand and move with some regularity. There's always someone flying thru where they shouldn't. But if the pilot asked AFSS about TFR's and they were not given the proper info they are off the hook. Same goes for if I tell a pilot the wrong info. That's on me, not on the pilot. That has also happened. Not the way things work on this side of the country. Really? Is there any documented case of a successful enforcement action against a pilot who violated a TFR because a briefer failed to mention the TFR when asked? Thanks, Gary |
![]() "Ron Natalie" wrote in message m... ....snip... Where do you think the FSS gets it's weather from? (I'll give you a hint, it's not another government agency). Okay, I'll bite. I would have said http://aviationweather.gov/ Is that not a government agency??? |
Icebound wrote:
Okay, I'll bite. I would have said http://aviationweather.gov/ Is that not a government agency??? Kavouras was the provider, but I think they switched to someone else. |
Part 135 Question - Weather Reporting requirement | G Farris | Instrument Flight Rules | 5 | October 21st 04 11:05 PM |
Cockpit weather display question | Chip Jones | Instrument Flight Rules | 6 | July 21st 04 01:07 PM |
Looks like the first day of sun 'n fun is out for bad weather | Tedstriker | Home Built | 2 | April 14th 04 08:36 PM |
Weather for wireless PDA | Viperdoc | Instrument Flight Rules | 7 | September 24th 03 01:02 AM |
Uplink weather advice | Richard Kaplan | Instrument Flight Rules | 15 | August 31st 03 11:39 PM |
