Performance Glider for tall people
Old August 28th 06, 04:37 PM posted to rec.aviation.soaring
Doug Haluza
Default Performance Glider for tall people
Holger Weitzel is the tallest glider pilot I know (I'm 6'0" and he
makes me look short). He flies an ASH26E for the roomy cockpit.
You might also want to consider a two-place ship like a DuoDiscus. I
fly a Janus, and it is quite comfortable in front and back.
ginopagino wrote:
Hi,
which european medium/high performance glider would you reccommend for
tall people?
I am ~6.5 / 199cm and looking to buy something like a Discus but
apparently cockpit is supersmall
Any suggestions?
Many Tks
Caiuz
Old August 28th 06, 04:54 PM posted to rec.aviation.soaring
I'm just under 6ft but once had a Ventus B (same fuse as the Discus B
or CS) and had to pull the rudder pedals back and put cushions behind
me to fit well with a parachute on. You might find someone with one
and see you can fit. Also, the PIK20D78 has a longer/larger fuse than
the other PIK20 models. See if you can find one of those to try on for
size as well. Even try taking out the seatback to make more room if it
is possible to do so.
Good luck! At my size I feel too tall for many gliders when wearing a
chute. You are just going to try on gliders until you find one that
fits..... Then find one to buy!
Patman
"CQ"
ginopagino wrote:
Hi,
tall people?
Any suggestions?
Many Tks
Caiuz
Old August 28th 06, 05:40 PM posted to rec.aviation.soaring
Do a search on this newsgroup using groups.google.com for threads
relating to tall pilots--there have been quite a few over the years.
One caution is that the torso/leg length ratio is as important as
overall height. The original Ventus and Discus, for example, had good
leg room but were tight for pilots with long torsos, at least without
what I consider to be extreme measures such as parachutes stowed behind
the pilot's head (because of the danger in a crash of it breaking your
neck).
The parachute can also be a critical factor. Some parachutes have more
thickness in the lower back, others behind the shoulders (the former
works better for me, allowing me to recline more). Some have comfort
foam, which increases the thickness, some not. Sometimes even the way a
rigger packs the parachute will have an effect.
Removing the adjustable back rest may provide enough room to get a tall
pilot into the cockpit. If you're buying new, the factories will often
work with you. For my ASW 24, for example, Schleicher provided an
aftermarket instrument panel with higher cutouts for the knees, omitted
the rudder pedals (only the metal bars are there) and moved the
mounting forward a few cm, and replaced the adjustable seat back with
the covers for the baggage compartment used in the motorglider; they
form a nice backrest.
Chip Bearden
ASW 24 "JB"
Refinish a Glider in Europe Jim Culp Soaring 4 November 19th 05 08:21 PM
Aerodynamics of carrying water Gene Whitt Soaring 54 October 19th 05 07:24 PM
Newbie seeking glider purchase advice Ted Wagner Soaring 19 January 2nd 04 07:00 PM
Announce/USA: FAA Glider Flying Handbook / Bob Wander SoarBooks Soaring 0 August 11th 03 03:55 PM
