The fully loaded CRJ takes `5500 feet...
The airport diagram says no aircraft over 12,000 are to use 26 for landing or taxiing either. "WRE" (remove nospam) wrote in message ... :I can't imagine a fully loaded CRJ could make it off a 3500' runway...or : even intentionally try. : I fly a Hawker 700...full gross is 25,000 lbs...and we would never make : that...or even try it. : : JMHO : : : : "Mike Isaksen" wrote in message : news:34KIg.718$wI5.407@trndny04... : I keep hearing the media state the CRJ fully loaded needs 5000+ feet for : takeoff. But the devil is always in the details: Does anyone have the : approx expected ground roll TO numbers? The expected roll distance to V1? : And does anyone know if runway 26 has runway remaining signage? : I'm asking because I would have expected rotation by 2500 feet and wheels : off by 3000. Contrast this with the media stating that the NTSB found : scrape marks on the departure end of runway 26 possibly from the CRJ : overrotating. : : : |
They apparently got it in the air but hit the trees...
".Blueskies." wrote in message et... : The fully loaded CRJ takes `5500 feet... : : The airport diagram says no aircraft over 12,000 are to use 26 for landing or taxiing either. : : : : "WRE" (remove nospam) wrote in message ... ::I can't imagine a fully loaded CRJ could make it off a 3500' runway...or :: even intentionally try. :: I fly a Hawker 700...full gross is 25,000 lbs...and we would never make :: that...or even try it. :: :: JMHO :: :: :: :: "Mike Isaksen" wrote in message :: news:34KIg.718$wI5.407@trndny04... :: I keep hearing the media state the CRJ fully loaded needs 5000+ feet for :: takeoff. But the devil is always in the details: Does anyone have the :: approx expected ground roll TO numbers? The expected roll distance to V1? :: And does anyone know if runway 26 has runway remaining signage? :: I'm asking because I would have expected rotation by 2500 feet and wheels :: off by 3000. Contrast this with the media stating that the NTSB found :: scrape marks on the departure end of runway 26 possibly from the CRJ :: overrotating. :: :: :: : : |
![]() ".Blueskies." wrote in message om... They apparently got it in the air but hit the trees... I saw a report that indicated it became airborne by hitting a berm after leaving the runway. |
![]() ".Blueskies." wrote in message om... They apparently got it in the air but hit the trees... They got in the air because they launched off a ramp/berm much like a British Aircraft Carrier. There were three sets of wheel marks on the ground between the end of the runway and the beam. |
On Fri, 1 Sep 2006 08:36:26 -0500, "Gig 601XL Builder"
wrDOTgiaconaATcox.net wrote: They got in the air because they launched off a ramp/berm much like a British Aircraft Carrier. There were three sets of wheel marks on the ground between the end of the runway and the beam. Apparently, the CRJ does not work very well with a Jump Jet type of takeoff... sick-grin Speaking of which, I've become airborne more than once at the intersection of 35 and 04 at HOU... Seems that when they put in the 04-22 runway, it's a bit higher than 35... Enough so that if you haven't slowed down enough, it'll put you back in the air... When I look at the figures quoted on Airnav for HOU, it actually appears that 35 is higher than 04, but the way that I remember it though is that there was a noticeable bump in 04 as you crossed it... I don't fly into HOU much these days and rarely is the wind such that we get to land on 35, so perhaps I'm just having an Alzheimer's Moment... grin |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Declaring a free distance fight | Basil Fairston | Soaring | 0 | September 1st 03 08:27 AM |
15 M Time Management Nationals | Kilo Charlie | Soaring | 12 | August 15th 03 03:09 AM |
Best Software and Hardware for Turn Area Task? | Snead1 | Soaring | 29 | August 13th 03 04:12 PM |
