Jim Macklin wrote
The slaved compass is corrected so as many errors (deviation) are corrected and variation is also corrected as much as possible too, SAY WHAT!!!! How does one fly an ATC assigned heading if VAR has been 'corrected' out? Bob Moore |
"Bob Moore" wrote in message
. 122... Jim Macklin wrote The slaved compass is corrected so as many errors (deviation) are corrected and variation is also corrected as much as possible too, SAY WHAT!!!! How does one fly an ATC assigned heading if VAR has been 'corrected' out? Probably the same way you do it when there's a wind. ATC assigns you a heading. If that doesn't provide the track they want, they assign a new one, adjusting for the error in the track. They don't care what your heading indicator is telling you. They care that you follow it consistently. (Note: I don't actually know anything about how a slaved compass is corrected...seems to me that variation and local deviation (that is, not due to the aircraft installation itself) are not things one could usefully build into a slaved compass. But assuming the slaved compass IS correcting for all manner of things, there's no reason to believe it would cause a problem with ATC). Pete |
The flux valve is usually located well away from steel and
electrical components, so it avoids many deviation errors. It also is designed to be more accurate and reduce turning errors sent to the indicator. "Peter Duniho" wrote in message ... | "Bob Moore" wrote in message | . 122... | Jim Macklin wrote | The slaved compass is corrected so as many errors | (deviation) are corrected and variation is also corrected as | much as possible too, | | SAY WHAT!!!! How does one fly an ATC assigned heading if VAR | has been 'corrected' out? | | Probably the same way you do it when there's a wind. ATC assigns you a | heading. If that doesn't provide the track they want, they assign a new | one, adjusting for the error in the track. | | They don't care what your heading indicator is telling you. They care that | you follow it consistently. | | (Note: I don't actually know anything about how a slaved compass is | corrected...seems to me that variation and local deviation (that is, not due | to the aircraft installation itself) are not things one could usefully build | into a slaved compass. But assuming the slaved compass IS correcting for | all manner of things, there's no reason to believe it would cause a problem | with ATC). | | Pete | | |
"Jim Macklin" wrote in message
news:_lOIg.6238$SZ3.83@dukeread04... The flux valve is usually located well away from steel and electrical components, so it avoids many deviation errors. It also is designed to be more accurate and reduce turning errors sent to the indicator. But there's no way, absent some sort of absolute position information (eg GPS) and a detailed database, to ascertain deviation due to local geology or other external magnetic interference, nor due to magnetic variation (which was Bob's point). Of course, my point is that correcting those errors isn't relevant to ATC. They don't care if your compass is actually right or not. They just care that you can hold it to a specific heading. But I think it's fair to comment on the statement that "the slaved compass is corrected so as...variation is also corrected". That's clearly just not true, at least in most installations (I suppose there's at least one GPS-based slaved compass setup in which it is corrected...never say never...but generally, this isn't used) Pete |
Sorry didn't mean to say it like that, compass deviation
correction. I was thinking about the swinging process, flying a heading on a cardinal course (government surveyed roads on sections lines are true N-S-E and W. Variation is applied when setting the HI to get the local magnetic, then turns are made with the HI and the compass read to determine the deviation. Sorry for being tired when I misspoke. "Bob Moore" wrote in message . 122... | Jim Macklin wrote | The slaved compass is corrected so as many errors | (deviation) are corrected and variation is also corrected as | much as possible too, | | SAY WHAT!!!! How does one fly an ATC assigned heading if VAR | has been 'corrected' out? | | Bob Moore |
VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 6th 06 11:13 PM |
Pilot claims no blame in July crash | Mortimer Schnerd, RN | Piloting | 48 | March 15th 06 09:00 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Doubts raised in jet crash | Dave Butler | Piloting | 8 | July 26th 05 01:25 AM |
Yet another A36 crash | H.P. | Piloting | 10 | April 23rd 05 05:58 PM |
