On Tue, 29 Aug 2006 10:45:03 -0400, Peter R. wrote:
Yep, a lot of my flying is in that big blue blob over the northeast US so TIS serves my well. But the question facing me (and my fellow partners): would you buy TIS *today* given the FAA's emphasis on ADS-B and TIS-B? Note that they just brought online more of PA: http://www.flttechonline.com/Current...o%20Expand.htm http://www.aopa.org/whatsnew/newsite...0817ads-b.html - Andrew http://flyingclub.org/ |
Andrew Gideon wrote:
On Tue, 29 Aug 2006 10:45:03 -0400, Peter R. wrote: Yep, a lot of my flying is in that big blue blob over the northeast US so TIS serves my well. But the question facing me (and my fellow partners): would you buy TIS *today* given the FAA's emphasis on ADS-B and TIS-B? snip The question isn't whether you should buy TIS. It's whether you should buy a Mode-S transponder, because that's the primary difference between the 327 and 330. TIS is just a perk of moving to Mode-S, and it was specifically designed that way to encourage pilots to move to Mode-S when it became clear they would not otherwise willingly adopt the new, more costly, technology. The FAA is continuing to invest in Mode-S radars (the ASR-11 is replacing the ASR 7, 8, and 9 units that currently support TIS), so an investment in the airborne component is still a wise move and will be for MANY years. Oh, and don't believe the hype out of Blakley's mouth for a second. ADS-B is not being deployed so they can "decommission radar". That will not happen in our lifetime due to security concerns. I fear that the *real* reason the FAA is pushing ADS-B is for billing purposes. With the kind of reliable and accurate position data facilitiated by ADS-B, they could charge us by the mile. -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
On Tue, 29 Aug 2006 23:34:27 -0400, Doug Vetter
wrote in : Oh, and don't believe the hype out of Blakley's mouth for a second. ADS-B is not being deployed so they can "decommission radar". That will not happen in our lifetime due to security concerns. I'm happy to hear, that someone thought about that. It would be a simple matter to spoof the positional data I would think. I fear that the *real* reason the FAA is pushing ADS-B is for billing purposes. I would guess the reason has as much to do with compatibility with the ATC system products of Boeing and LockMart. With the kind of reliable and accurate position data facilitiated by ADS-B, they could charge us by the mile. Not if we don't let Congress out of oversight responsibilities for FAA funding. |
On Tue, 29 Aug 2006 23:34:27 -0400, Doug Vetter wrote:
The FAA is continuing to invest in Mode-S radars (the ASR-11 is replacing the ASR 7, 8, and 9 units that currently support TIS), so an investment in the airborne component is still a wise move and will be for MANY years. Aside from TIS, what is the benefit (either to the pilot or ATC) of mode S? - Andrew |
![]() The FAA is continuing to invest in Mode-S radars (the ASR-11 is replacing the ASR 7, 8, and 9 units that currently support TIS), 11's are not replacing 9's. They are a stripped down 9. so an investment in the airborne component is still a wise move and will be for MANY years. The FAA is installing new radars but they leave out the software that supports TIS. That's what happened to us. We had a 7 with mode S and TIS was operastional. We upgraded the radar to an 11 but they do not install TIS stuff in the radar. |
Newps wrote: 11's are not replacing 9's. They are a stripped down 9. I don't recall the ARS-11 being a derivative of the -9. -- Bob Noel Looking for a sig the lawyers will hate |
![]() Bob Noel wrote: In article , Newps wrote: 11's are not replacing 9's. They are a stripped down 9. I don't recall the ARS-11 being a derivative of the -9. It's the K Mart version of the 9. |
![]() Andrew Gideon wrote: Aside from TIS, what is the benefit (either to the pilot or ATC) of mode S? To ATC? Nuthin' I wouldn't know if you had one. |
Newps,
To ATC? Nuthin' I wouldn't know if you had one. Ah, the broad view of the American ;-) In Europe, Mode S equipment is becoming mandatory solely for ATC reasons. There is no TIS here. ATC stations with the proper equipment can do "selective" calls (hence mode S) interrogating only specific aircraft. This leads to less congestion on the secondary radar frequency, which, Eurocontrol tells us, is a serious problem with Mode A/C. They claim to be running out of transponder codes, for example. More info via google... -- Thomas Borchert (EDDH) |
Mode S has several advantages. ATC interrogation pulses can be directed to
a specific aircraft or all Mode S aircraft. Replies to the interrogation can contain specific information (altitude, aircraft ID and airframe type). Interrogation to all Mode S aircraft could illicit a reply from my Garmin GTX 330 that contians my tail # and type and altitude. I don't know if all of this is currently functional in any or all of the Mode S facilities or not but this was the original intent. http://rfdesign.com/military_defense...e_technology/I think that it's a great thought that will give way to ADS-B. TIS is agreat tool also that will probably pass by the wayside. But my 2 or 3 tripsper month into the Dallas Class B are made easier with TIS. FSM where I'mbased had TIS for the first year after I installed the Garmin but theyupgraded the radar (to ASR 11, I believe) and are not going to turn TIS onfor whatever reason.MarkN28409WC5I"Andrew Gideon" wrote in messagenews ![]() |
18 Oct 2005 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | October 19th 05 02:19 AM |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
