![]() Richard Riley wrote: On Wed, 27 Aug 2003 13:36:11 GMT, Jerry Wass wrote: :Ah'm a gonna use a buncha 1/8" SS toobin on my fuel injection system on my : :314 cid Cont. GPU. ---I'se gotta buncha ole surplus 3/16" preformed pipes :with lotsa flares on 'em--Whack 'em off at a 45% angle bout an inch long & :silver solder em on to the 1/8"--Makes a stouter joint & moves the :vibration away from the flare :fitting back into the 1/8" line--Dat werk 4 U ?? : Ooooo, dat clever. Ifn I get outta dem serplus 3/16 ss, I ken make dem. I does has a good lathe I mite get to werkin, but I don't have no way ta hold da 1/8 line ifn I don't by dat ting from Spruce.. WELL, i TELL YA HOW TO DO DAT--You takes a short peece of 3/16" line( 1/8" i.d.) & you grab your trusty moto tool with the fine thin grinder blades & you cuts a slit in it length wise, slip this little bugger on the 1/8" line & clamp the whole ferschluggin mess in the 3/16" hole in your flare clamp doohickey.---ON SECOND THOUGHT, MEBBY YOU BETTER MAKE 2 SLITS IN IT, if you wants to take it off.. Then you all knows bout the merger tween Honeywell & Fairchild?? they is gonna call it--- Farewell Honeychild!! I was gonna use dem aluminum fittins, but I was gonna use some a dem soft copper 37 degree gaskets, do de werk? :Richard Riley wrote: : : I need to make a dozen 37 degree flares in 1/8 stanless line for a : brake system. My flaring tool only goes to 3/16. Spruce has the : "Rolo-flare" tool that goes to 1/8" for $80 or so, but they say it's : not for use with stainless. OTOH, the other vendors that carry the : Rolo-flare don't say anything about stainless. Has anyone used it for : this? : : Spruce also has a 1/8" flaring kit for $19, that comes with a flaring : "punch" http://www.aircraftspruce.com/catalo...aringblock.php : is it used with a hammer? : : Spruce also has Weatherhead flaring tools that go to 1/8 for SS, but : they're $400. I hate to buy one for so few jobs. Anyone got a used : one for sale, rent or borrowing? |
On Wed, 27 Aug 2003 18:29:10 GMT, Jerry Wass
wrote: : :Then you all knows bout the merger tween Honeywell & Fairchild?? they is gonna : :call it--- : : :Farewell Honeychild!! I's been hear 'bout a nutha o dem mergers, a tween Carter Hawley Hale, Mary Kay Cosmetics, Fuller Brush Company and WR Grace. Dey's gonna call it Hale Mary Fuller Grace. |
