The Comair crash reminds me...
Old August 30th 06, 02:38 AM posted to rec.aviation.piloting
Kyler Laird
Default The Comair crash reminds me...
"Steven P. McNicoll" writes:
If it was active...well, was the plane really cleared for takeoff onto the
wrong
runway?
No, it was cleared for takeoff on the right runway, the flight crew
attempted takeoff on the wrong runway.
So...how'd it go? Ground cleared the plane to taxi to the correct
runway, observed the plane go to the wrong runway, then tower cleared
the plane to depart the right runway, and observed it pull onto the
wrong runway. Anything like that?
I hope I'm missing something obvious. Was there dense fog involved?
Lots of other traffic?
--kyler
Old August 30th 06, 03:22 AM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
"Kyler Laird" wrote in message
Probably not. The runways are not far apart. You have to taxi past the
departure end of runway 26, the wrong runway, to reach the departure end of
runway 22, the right runway. I believe there was just one controller in the
tower.
The weather observation taken about 13 minutes prior showed six miles
visibility. I don't know if there was other traffic, but probably not a lot
on an early weekend morning.
Old August 30th 06, 03:39 AM posted to rec.aviation.piloting
Jim Macklin
Depending on the tower location, the angle might not allow
seeing the error, it is even possible the end of the runway
could be hidden behind a building. The controller has many
duties, watching an airplane taxi is not the highest
priority, getting the hand-off to Center, possible radio
contact with other airplanes, many things could be required.
Just looked at the airport diagram, the tower is located
with a clear view of runway 22 and 26 , if there are no
uncharted builds or trees. Still in the dark, lights alone
do not necessarily allow determination of enough details to
over come the expectation that they were on 22.
"Steven P. McNicoll" wrote
in message
k.net...
the correct
tower cleared
pull onto the
taxi past the
departure end of
controller in the
| tower.
fog involved?
showed six miles
probably not a lot
Old August 30th 06, 08:58 AM posted to rec.aviation.piloting
John Gaquin
"Jim Macklin" wrote in message
The tower, end of 22, and end of 26 are pretty much in line. I think a
misposition might not be immediately obvious to the tower without a second,
closer look. Also, my sense is that even when the takeoff roll had started,
the angles are such that the roll might have to progress a certain distance
before a discrepency would become obvious to the tower, if they were
looking.
Old August 30th 06, 12:24 PM posted to rec.aviation.piloting
Jim Macklin
Yep, that is what I said, just because you can see, doesn't
mean you know what it is.
"John Gaquin" wrote in message
| "Jim Macklin" wrote
in message
line. I think a
without a second,
roll had started,
certain distance
they were
| looking.
Old September 1st 06, 10:39 PM posted to rec.aviation.piloting
LWG
I may sound like an idiot, but I have often wondered why there isn't a
system of red and green lights at taxiway and runway intersections. Driving
around unfamiliar airports at night is one of the hardest things I've done
in an airplane. It's hard to see the signage, there are no lights to speak
of, and trying to read taxiway diagrams with that feeble red cockpit light
is useless. Progressive isn't a lot better, at bigger airports it's like
getting directions from a New York taxicab driver.
How simple it would be see a line of green lights until until to get to red
one at the runway, which is turned green when you're cleared on the runway.
I understand there will be some thinking to do at bigger airports will
multiple simultaneous taxi operations, but I can't believe with a little
thought those problems couldn't be solved. If we limited it to just
intersections of runways with taxiways, it would be downright simple.
second, closer look. Also, my sense is that even when the takeoff roll
had started, the angles are such that the roll might have to progress a
certain distance before a discrepency would become obvious to the tower,
if they were looking.
Old September 2nd 06, 12:38 AM posted to rec.aviation.piloting
Grumman-581[_1_]
On Fri, 1 Sep 2006 17:39:56 -0400, "LWG"
And you've never had a problem with traffic lights in the city where
you are located?
Old September 2nd 06, 07:09 AM posted to rec.aviation.piloting
John Gaquin
"LWG" wrote in message news:9-
.... It's hard to see the signage, there are no lights to speak of, and
trying to read taxiway diagrams with that feeble red cockpit light is
useless.
So turn up the lights so you can see the diagram.
Old September 2nd 06, 08:02 AM posted to rec.aviation.piloting
Jim Macklin
Modern aircraft don't have only red lights in the cockpit,
lots of lighting and pilots carry flashlights, pen lights
and can study the diagrams in the office too.
speak of, and
cockpit light is
| useless.
Old August 30th 06, 03:56 AM posted to rec.aviation.piloting
Newps
Nope. One guy in the tower. The FAA has already admitted that they
broke their own rules by having only one controller staffed when the
policy requires a minimum of two at all times, at all facilities. They
will probably hang the tower manager as a scapegoat.
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 6th 06 11:13 PM
Pilot claims no blame in July crash Mortimer Schnerd, RN Piloting 48 March 15th 06 09:00 PM
Doubts raised in jet crash Dave Butler Piloting 8 July 26th 05 01:25 AM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 05:58 PM
