Midair near Minden
Old August 30th 06, 04:50 PM posted to rec.aviation.soaring
Robert Backer
Default Midair near Minden
I just don't buy this power argument. My panel includes 302, Ipaq,
becker transponder (with encoder)and becker radio all of which run for
at least 6 hours on a single 8.5 ah powersonic battery (exactly the same
dimensions as the typical 7 ah battery). I also carry a backup 8.5 ah
battery which I have never had to switch to.
Bob
Marc Ramsey wrote:
Mike Schumann wrote:
Why in the world would you leave a transponder off if you have the
luxury of having one????
Lack of sufficient battery capacity to run it for extended periods. Not
everyone has the luxury of having two 12 ah batteries...
  #32
Old August 30th 06, 05:09 PM posted to rec.aviation.soaring
Al[_1_]
"jb92563" wrote in message
Here are links with pictures.
http://news.rgj.com/apps/pbcs.dll/ar...0365/1144/NEWS
http://www.aero-news.net/index.cfm?C...-acbbb7a5f04e&
Its interesting to note that the perception is that the glider crashed
into the jet.
Sure, just like my cat hit that car doing seventy...
Al G
  #33
Old August 30th 06, 05:10 PM posted to rec.aviation.soaring
Marc Ramsey
You don't have to buy it, but there are a lot of variables involved,
including the precise mix of equipment (in particular, the current draw
of the encoder at altitude), frequency of interrogation, sensitivity of
the radio to marginal voltage, whether the PDA is charging, age and
temperature of the battery, etc.
I have a transponder and a single 12 ah battery (and currently no room
for another, or for two 7/8.5 ah batteries), usually I can count on
around 5 hours before I start losing the radio. Yes, things would be
better with a backup battery, and before Kinsell comes out of the
woodwork, yes I could go longer with a 14V system. But, I fly with the
electrical system I have, not the one I might want, so the transponder
usually goes off in the boonies...
Marc
  #34
Old August 30th 06, 05:44 PM posted to rec.aviation.soaring
Gerhard Wesp[_4_]
I think one there are two important questions to be answered in
the NTSB investigation:
1. Did ATC inform the Hawker about glider traffic?
2. Did the Hawker pilots look out the window?
Regards
-Gerhard
Gerhard Wesp / Holderenweg 2 / CH-8134 Adliswil
+41 (0)76 505 1149 (mobile) / +41 (0)44 668 1878 (office)
+41 (0)44 668 1818 (fax)
http://gwesp.tx0.org/
  #35
Old August 30th 06, 07:11 PM posted to rec.aviation.soaring
Ramy
While you may be detected by ATC on primary without a transponder, you
wouldn't be detected by airliners and other aircrafts carrying TCAS and
will not give traffic resolution.
Another (secondary) reason to carry a transponder and leave it on, is
that if, god forbidden, you go down in a remote area, replaying ATC
tapes may help finding you.
Ramy
Ray Lovinggood wrote:
Doug,
You don't have to have a transponder to get the controllers
to know you are there. True, I'm not talking 'Flight
Following' but more like 'Flight Awareness.'
On occassions, I have called the local controllers
for the Class C airport (RDU) and let them know I was
there and was monitoring their frequency. They would
first reply to 'Squak' such and such and I would tell
them I didn't have a transponder. They would then
find me on radar. Ok, maybe they aren't as busy as
some other locations, but at least I make them aware
that I'm out there. Occassionaly, they might call
up and ask how I'm doing, and just being friendly.
Ray Lovinggood
Carrboro, North Carolina, USA
At 12:36 30 August 2006, Doug Haluza wrote:
snoop wrote:
The one item, I'm curious to hear about, if, this
item, is on the
Reno/Minden Jeppesen IFR charts. I know it's on the
VFR sectionals, but
is there a glider icon on the IFR charts in that region?
Good point about getting the glider symbol on the IFR
charts. Most jet
jocks use these almost exclusively. The more we do
to raise awareness
the better.
Another way to raise awareness of glider trafiic is
to make Pireps. I
try to do this at least once on every good soaring
day, especially if
there is wave. Report your aircraft type as simply
a Glider (nobody
else will know or care what make/model you are flying).
You can just
report clear and 50 mi visibility, or give detailed
(and useful) info
on cloud layers and winds aloft. Pireps get wide dissemination
to
pilots, ATC and dispatchers, so this is a good way
to remind them that
we are out there too. Glider pilots who also fly commercially
will
appreciate hearing your Pirep when they are working
(try to make them
as jealous as possible by reporting from the top of
the climb!). You
can give Pireps to Flight Watch on 122.0 MHz, or you
can contact a FSS
or ATC facility on a discrete frequency. Check the
AIM for more info on
Pireps.
Another thing you can do is to get VFR flight following
if you have a
transponder. Again, just give your aircraft type as
a Glider. This lets
pilots and controllers in the section know we are out
there. It also
gets you a discrete transponder code. Most ATC sections
filter out 1200
VFR codes, and only view aircraft with discrete codes.
So in this case,
even if the glider's transponder was on, there is no
guarantee that the
controller even saw it, much less gave a traffic warning--they
are not
required to warn IFR aircraft of VFR targets anyway.
I know a lot of glider pilots like to stay out of the
system. But out
of sight is out of mind.
  #36
Old August 30th 06, 07:24 PM posted to rec.aviation.soaring
Eric Greenwell[_1_]
And you won't be detected by airplanes and gliders using a TPAS instrument.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
  #37
Old August 31st 06, 12:40 AM posted to rec.aviation.soaring
Greg Arnold
What is the difference between TCAS and TPAS?
  #38
Old August 31st 06, 02:22 AM posted to rec.aviation.soaring
Ramy
TPAS is passive, it does not interrogate, as such much less accurate,
but fraction of the price of TCAS. You can find them under $500.
Ramy
  #39
Old August 31st 06, 03:42 AM posted to rec.aviation.soaring
Mike Schumann
The transponder would be the last thing I turn off, no matter where I was.
Mike Schumann
"Marc Ramsey" wrote in message
m...
becker transponder (with encoder)and becker radio all of which run for at
including the precise mix of equipment (in particular, the current draw of
the encoder at altitude), frequency of interrogation, sensitivity of the
I have a transponder and a single 12 ah battery (and currently no room for
another, or for two 7/8.5 ah batteries), usually I can count on around 5
hours before I start losing the radio. Yes, things would be better with a
backup battery, and before Kinsell comes out of the woodwork, yes I could
go longer with a 14V system. But, I fly with the electrical system I
have, not the one I might want, so the transponder usually goes off in the
boonies...
Marc
Minden Vote - Results [email protected] Soaring 1 November 20th 05 06:01 PM
Minden In Two Weeks ADP Soaring 3 August 10th 04 01:51 AM
