![]() snoop wrote: Must be nice to walk on water! Actually, it's the water into wine trick that really wows the crowd I hang with... No apologies - the bizjet should have seen the glider. The glider also should have seen the bizjet. There may be reasons why that didn't happen - and I'll be the first to admit I've been guilty of late detection of aircraft nearby. If I screw up, I've got no problem admitting it - there really isn't much room for ego where flight safety is concerned. But I also know from first hand that all this hysteria about closing speed is BS. Even jet fighters can be seen in time to avoid. Airliners are huge and almost impossible to miss. Bizjets fit in between. But you have to be looking. Kirk |
![]() Stefan wrote: No. Yes. I've done it in fighters, light planes, and gliders. Dodged F-16s and AV-8Bs in Arizona for many years in my LS6. Of course, if you don't see it, for whatever reason, then yes it can hit you. If you were deaf, you could even get run over by a blimp! (except the shadow might warn you!). Worse case is getting run down from behind. It helps if you hear the fighters and throw up a wing so they see you (done that too - it worked just fine). You do have to be willing to move your glider around to look all around when you suspect there is someone in your blind spot. I'll keep on looking out the window instead of fiddling with my PDA. Cheers, Kirk 66 |
kirk.stant wrote:
Stefan wrote: No. Yes. I've done it in fighters, light planes, and gliders. Dodged F-16s and AV-8Bs in Arizona for many years in my LS6. Of course, if you don't see it, for whatever reason, then yes it can hit you. If you were deaf, you could even get run over by a blimp! (except the shadow might warn you!). Worse case is getting run down from behind. It helps if you hear the fighters and throw up a wing so they see you (done that too - it worked just fine). You do have to be willing to move your glider around to look all around when you suspect there is someone in your blind spot. Would you write an article for Soaring magazine about your techniques? It seems like an appropriate time. I know I don't see fighters soon enough, and I'm sure I could miss aircraft coming up behind me. I often see aircraft in the distance, but I know I haven't seen some airplanes of various types that were potential threats. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
![]() Eric Greenwell wrote: Would you write an article for Soaring magazine about your techniques? It seems like an appropriate time. I know I don't see fighters soon enough, and I'm sure I could miss aircraft coming up behind me. I often see aircraft in the distance, but I know I haven't seen some airplanes of various types that were potential threats. Eric, it's not so much a technique as paranoia about other traffic. There are some tricks that all pilots should know and use: have an absolutely clean canopy (inside and out - I'm amazed by how filthy most pilots let their canopies get), minimize reflections and obstructions (PDA's, big compasses, etc.), keep "inside the cockpit" tasks short, refocus at inifinity often while scanning, look for threats, not just passing airplanes (low or high is not very critical, what's on the horizon is dangerous!, and ALWAYS CLEAR YOUR FLIGHTPATH), look for motion or lack of it in the forward quadrant. Use every tool available - call out passing planes to other gliders and vice versa, listen to tower when passing a busy airport, look for shadows on the ground (good in the pattern), smoke trails or glints in the air, and sound - if anything makes the hairs on the back of your neck stand up, the turn and look around. Think about where the traffic will be coming from. When you are cruising and are near the VFR hemispheric altitudes, look in the direction the traffic will be coming from. Most power pilots will fly at "easy" altitudes (multiples of 500'). Avoid hanging around VORs, intersections, and following major interstates - lots of power traffic there, flying IFR (I follow roads)! Due to the speed difference it is hard for a glider to get away from a fast mover at close range, but if you are seen there is a good chance he will maneuver to avoid. And your cross section is basically the same whether turning or flying straight - it's just oriented different. But whip into a steep turn (45 degrees either way) and you will probably be seen - and you get to see other planes maneuver out of your way. I've seen everything from King Airs, 737s, and F-16s respond to a wing flash. Of course I've also seen a 737 fly right through my thermal just outside of Class B airspace (acturally right next to an approach/departure extension of the B airspace. I was carefully thermalling outside the Class B, watching the arrivals, and watched as one guy approached from the West. When it was obvious he was going to join me in my nice 7 knot thermal, I moved out of his way, let him by (no noise by the way) then re-entered the thermal and continued the climb. I've also heard jet noise, done a check turn, and been rewarded with the sight of 2 F-16s about a half mile away maneuvering hard to go around me. Final tip - if you see one jet fighter, start looking real hard for the other one, and for the additional two in trail. And if the one you see is going to pass about a mile to your side, then be real scared of the one you don't see that is in one mile spread formation, watching his leader, just like you are. Fighters almost never fly alone. Anybody else got good suggestions/techniques/tips? Kirk 66 |
Wow, so many aircrafts...
In the 7 years and about 2000 hours I flew my LS4, I never saw commercial traffic close by, and I fly most of the time in the Reno area. Maybe it has to do with the fact that I am using a transponder? I had one close call over airsailing with an airliner in the short time I flew club gliders without transponders (I believe they all have transponders now). Ramy kirk.stant wrote: Eric Greenwell wrote: Would you write an article for Soaring magazine about your techniques? It seems like an appropriate time. I know I don't see fighters soon enough, and I'm sure I could miss aircraft coming up behind me. I often see aircraft in the distance, but I know I haven't seen some airplanes of various types that were potential threats. Eric, it's not so much a technique as paranoia about other traffic. There are some tricks that all pilots should know and use: have an absolutely clean canopy (inside and out - I'm amazed by how filthy most pilots let their canopies get), minimize reflections and obstructions (PDA's, big compasses, etc.), keep "inside the cockpit" tasks short, refocus at inifinity often while scanning, look for threats, not just passing airplanes (low or high is not very critical, what's on the horizon is dangerous!, and ALWAYS CLEAR YOUR FLIGHTPATH), look for motion or lack of it in the forward quadrant. Use every tool available - call out passing planes to other gliders and vice versa, listen to tower when passing a busy airport, look for shadows on the ground (good in the pattern), smoke trails or glints in the air, and sound - if anything makes the hairs on the back of your neck stand up, the turn and look around. Think about where the traffic will be coming from. When you are cruising and are near the VFR hemispheric altitudes, look in the direction the traffic will be coming from. Most power pilots will fly at "easy" altitudes (multiples of 500'). Avoid hanging around VORs, intersections, and following major interstates - lots of power traffic there, flying IFR (I follow roads)! Due to the speed difference it is hard for a glider to get away from a fast mover at close range, but if you are seen there is a good chance he will maneuver to avoid. And your cross section is basically the same whether turning or flying straight - it's just oriented different. But whip into a steep turn (45 degrees either way) and you will probably be seen - and you get to see other planes maneuver out of your way. I've seen everything from King Airs, 737s, and F-16s respond to a wing flash. Of course I've also seen a 737 fly right through my thermal just outside of Class B airspace (acturally right next to an approach/departure extension of the B airspace. I was carefully thermalling outside the Class B, watching the arrivals, and watched as one guy approached from the West. When it was obvious he was going to join me in my nice 7 knot thermal, I moved out of his way, let him by (no noise by the way) then re-entered the thermal and continued the climb. I've also heard jet noise, done a check turn, and been rewarded with the sight of 2 F-16s about a half mile away maneuvering hard to go around me. Final tip - if you see one jet fighter, start looking real hard for the other one, and for the additional two in trail. And if the one you see is going to pass about a mile to your side, then be real scared of the one you don't see that is in one mile spread formation, watching his leader, just like you are. Fighters almost never fly alone. Anybody else got good suggestions/techniques/tips? Kirk 66 |
Isn't there a speed limitation in class G in the USA? (In Europe it's
250 knots max) J. N. |
![]() Ramy wrote: Wow, so many aircrafts... In the 7 years and about 2000 hours I flew my LS4, I never saw commercial traffic close by, and I fly most of the time in the Reno area. Maybe it has to do with the fact that I am using a transponder? I had one close call over airsailing with an airliner in the short time I flew club gliders without transponders (I believe they all have transponders now). Could be where you fly - in the Phoenix area (and most of NW AZ), there is a lot of traffic. Then again, It doesn't bother me to be around other airplanes - it's kind of neat to watch a big old airliner cruise by (and wonder if anyone in it saw me), or get checked out in a thermal by a couple of AV-8 (which happened to me up by the Grand Canyon - they altered course and came over to where I was thermalling at about 15,000', went by on either side of the thermal. I waved at them, of course). But just cuz you don't see it, don't mean it aint there! Kirk |
Kirk... Really, all the good suggestions etc... but let's not kid ourselves,
shall we? Please, do me a favor. Open your favorite word processor (while you are, obviously, reading R.A.S. at some sort of a computing device). Set font to Arial, size to 10 and zoom to 100%. Type letter o (lower case) on a blank page. Move the blinking cursor away. Step back 10 feet. This is the same angular size the Hawker was to the glider pilot only 20 seconds (one turn in thermal) before impact. Can you see it? If you can, congratulations -- you've got one heckofa vision. Now change the text color to *white*. Any more questions? The truth is, if you can't see this tiny *motionless* speck ...two miles away ...in the inversion haze ...on one thermalling turn, then it is going to hit you before you finish the next. Let alone, where can you go in those few seconds even if you do see 'em? -- Yuliy "kirk.stant" wrote in message ps.com... Eric Greenwell wrote: Would you write an article for Soaring magazine about your techniques? It seems like an appropriate time. I know I don't see fighters soon enough, and I'm sure I could miss aircraft coming up behind me. I often see aircraft in the distance, but I know I haven't seen some airplanes of various types that were potential threats. Eric, it's not so much a technique as paranoia about other traffic. There are some tricks that all pilots should know and use: have an absolutely clean canopy (inside and out - I'm amazed by how filthy most pilots let their canopies get), minimize reflections and obstructions (PDA's, big compasses, etc.), keep "inside the cockpit" tasks short, refocus at inifinity often while scanning, look for threats, not just passing airplanes (low or high is not very critical, what's on the horizon is dangerous!, and ALWAYS CLEAR YOUR FLIGHTPATH), look for motion or lack of it in the forward quadrant. Use every tool available - call out passing planes to other gliders and vice versa, listen to tower when passing a busy airport, look for shadows on the ground (good in the pattern), smoke trails or glints in the air, and sound - if anything makes the hairs on the back of your neck stand up, the turn and look around. Think about where the traffic will be coming from. When you are cruising and are near the VFR hemispheric altitudes, look in the direction the traffic will be coming from. Most power pilots will fly at "easy" altitudes (multiples of 500'). Avoid hanging around VORs, intersections, and following major interstates - lots of power traffic there, flying IFR (I follow roads)! Due to the speed difference it is hard for a glider to get away from a fast mover at close range, but if you are seen there is a good chance he will maneuver to avoid. And your cross section is basically the same whether turning or flying straight - it's just oriented different. But whip into a steep turn (45 degrees either way) and you will probably be seen - and you get to see other planes maneuver out of your way. I've seen everything from King Airs, 737s, and F-16s respond to a wing flash. Of course I've also seen a 737 fly right through my thermal just outside of Class B airspace (acturally right next to an approach/departure extension of the B airspace. I was carefully thermalling outside the Class B, watching the arrivals, and watched as one guy approached from the West. When it was obvious he was going to join me in my nice 7 knot thermal, I moved out of his way, let him by (no noise by the way) then re-entered the thermal and continued the climb. I've also heard jet noise, done a check turn, and been rewarded with the sight of 2 F-16s about a half mile away maneuvering hard to go around me. Final tip - if you see one jet fighter, start looking real hard for the other one, and for the additional two in trail. And if the one you see is going to pass about a mile to your side, then be real scared of the one you don't see that is in one mile spread formation, watching his leader, just like you are. Fighters almost never fly alone. Anybody else got good suggestions/techniques/tips? Kirk 66 |
Bravo Yuliy, perfect example!
In the meantime, Let's hope the sky stays big this Labor Day weekend, as with the current forecast, many will be smoking the skies near Minden :-) Ramy Yuliy Gerchikov wrote: Kirk... Really, all the good suggestions etc... but let's not kid ourselves, shall we? Please, do me a favor. Open your favorite word processor (while you are, obviously, reading R.A.S. at some sort of a computing device). Set font to Arial, size to 10 and zoom to 100%. Type letter o (lower case) on a blank page. Move the blinking cursor away. Step back 10 feet. This is the same angular size the Hawker was to the glider pilot only 20 seconds (one turn in thermal) before impact. Can you see it? If you can, congratulations -- you've got one heckofa vision. Now change the text color to *white*. Any more questions? The truth is, if you can't see this tiny *motionless* speck ...two miles away ...in the inversion haze ...on one thermalling turn, then it is going to hit you before you finish the next. Let alone, where can you go in those few seconds even if you do see 'em? -- Yuliy "kirk.stant" wrote in message ps.com... Eric Greenwell wrote: Would you write an article for Soaring magazine about your techniques? It seems like an appropriate time. I know I don't see fighters soon enough, and I'm sure I could miss aircraft coming up behind me. I often see aircraft in the distance, but I know I haven't seen some airplanes of various types that were potential threats. Eric, it's not so much a technique as paranoia about other traffic. There are some tricks that all pilots should know and use: have an absolutely clean canopy (inside and out - I'm amazed by how filthy most pilots let their canopies get), minimize reflections and obstructions (PDA's, big compasses, etc.), keep "inside the cockpit" tasks short, refocus at inifinity often while scanning, look for threats, not just passing airplanes (low or high is not very critical, what's on the horizon is dangerous!, and ALWAYS CLEAR YOUR FLIGHTPATH), look for motion or lack of it in the forward quadrant. Use every tool available - call out passing planes to other gliders and vice versa, listen to tower when passing a busy airport, look for shadows on the ground (good in the pattern), smoke trails or glints in the air, and sound - if anything makes the hairs on the back of your neck stand up, the turn and look around. Think about where the traffic will be coming from. When you are cruising and are near the VFR hemispheric altitudes, look in the direction the traffic will be coming from. Most power pilots will fly at "easy" altitudes (multiples of 500'). Avoid hanging around VORs, intersections, and following major interstates - lots of power traffic there, flying IFR (I follow roads)! Due to the speed difference it is hard for a glider to get away from a fast mover at close range, but if you are seen there is a good chance he will maneuver to avoid. And your cross section is basically the same whether turning or flying straight - it's just oriented different. But whip into a steep turn (45 degrees either way) and you will probably be seen - and you get to see other planes maneuver out of your way. I've seen everything from King Airs, 737s, and F-16s respond to a wing flash. Of course I've also seen a 737 fly right through my thermal just outside of Class B airspace (acturally right next to an approach/departure extension of the B airspace. I was carefully thermalling outside the Class B, watching the arrivals, and watched as one guy approached from the West. When it was obvious he was going to join me in my nice 7 knot thermal, I moved out of his way, let him by (no noise by the way) then re-entered the thermal and continued the climb. I've also heard jet noise, done a check turn, and been rewarded with the sight of 2 F-16s about a half mile away maneuvering hard to go around me. Final tip - if you see one jet fighter, start looking real hard for the other one, and for the additional two in trail. And if the one you see is going to pass about a mile to your side, then be real scared of the one you don't see that is in one mile spread formation, watching his leader, just like you are. Fighters almost never fly alone. Anybody else got good suggestions/techniques/tips? Kirk 66 |
VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 6th 06 11:13 PM |
Yet another A36 crash | H.P. | Piloting | 10 | April 23rd 05 05:58 PM |
Seniors Contest | Bob Fidler | Soaring | 68 | March 17th 05 03:50 AM |
Sport Pilot - School Won't Offer | Gary G | Piloting | 38 | February 16th 05 10:41 AM |
Announce/USA: FAA Glider Flying Handbook / Bob Wander | SoarBooks | Soaring | 0 | August 11th 03 03:55 PM |
