Hawker vs. Glider Midair - with photo!
Old August 30th 06, 11:33 PM posted to rec.aviation.piloting
Ron Natalie
Default Hawker vs. Glider Midair - with photo!
Stefan wrote:
Ron Natalie schrieb:
What we apparently have here (from preliminary data) is a massive
failure of see-and-avoid on the behalf of both parties.
Agreed. But, while no glider pilot I know would insist on his right: The
glider had the right of way.
Who the hell said anything about right of way here. Both aircraft have
a duty to see and avoid. The category preference only applies to
aircraft converging from other than head on (apply directly to the
forehead). I'm sure the NTSB will give study as to what the actual
tracks were and what the visual vantages were from both ships.
Old August 31st 06, 01:38 AM posted to rec.aviation.piloting
Aluckyguess[_1_]
I would have to believe this is going to be a no falt accident. This is a
freek.
m...
Old August 31st 06, 03:53 AM posted to rec.aviation.piloting
Having watched gliders from the ground and air, I've noticed that from
directly in front or behind, they nearly disappear because of the very
narrow wings and fuselage. If a jet is heading nearly head-on, I
imagine it will be nearly impossible to spot the glider until a
collision is all but avoidable, and that's if you know it's there. The
jet itself would only be somewhat more visible head-on.
I haven't been soaring that high, but I imagine this is a good example
of why flight following is a good thing. It isn't perfect, but it
can't hurt.
Old August 31st 06, 01:09 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
can't hurt.
It can't help if ATC can't see the targets, and if the glider doesn't have a
transponder they aren't likely to see it.
Old August 31st 06, 09:08 PM posted to rec.aviation.piloting
Morgans[_4_]
can't hurt.
It also makes me wonder if the glider had a transponder. It would seem like
a good idea, to carry one, and an altitude encoding one, if possible. That
way, the jet would have been able to get an alert from his collision
avoidance equipment, and this would have been a non-accident. A much better
day, for all those involved.
Jim in NC
Midair near Minden Fred Soaring 52 September 1st 06 11:41 AM
Cloud Flying Shawn Knickerbocker Soaring 48 August 30th 06 07:21 AM
Refinish a Glider in Europe Jim Culp Soaring 0 November 18th 05 04:00 PM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
Newbie seeking glider purchase advice Ted Wagner Soaring 19 January 2nd 04 07:00 PM
