Altitude Encoder w/ GPS Question
Old August 31st 06, 02:17 AM posted to rec.aviation.homebuilt
Jim Burns
Default Altitude Encoder w/ GPS Question
Our KLN94 is the same. Best thing the encoder can be used for in our unit
is to cancel the "Altitude Fail" message that pops up requiring you to
cancel it.
"Dave S" wrote in message
ink.net...
Ron Natalie wrote:
Scott Rodriguez wrote:
Looking at buying an altitude encoder for the transponder in my
yet-to-be-born homebuilt.
I see some altitude encoders have an RS-232 output for sending altitude
information to a GPS. What kind of functionality does this provide? Is
it
"real-world" useful?
It's required for IFR approach certification I believe.
Negative. The encoder can be used to provide altitude alerting functions
through the gps, but it's not precise enough for providing vertical
guidance in an approach. The typical serial encoder reports in 100 ft
increments.
Baro-vnav (which is not required to utilize an otherwise approach
certified GPS) requires a much more precise input signal.
My KLB 89B allows the connection of an encoder to it. It's sole usefulness
is in serving as an altitude alert, and in calculating density
altitude/true airspeed (not having to enter pressure altitude manually)
Dave
Question: Velocity/Cozy and high altitude Shin Gou Home Built 6 February 16th 05 02:03 AM
Altitude loss for 5h Duration Flight nyffeler Soaring 9 August 28th 04 11:12 AM
S-TEC 60-2 requires re-trim after altitude hold? Peter R. Owning 7 March 2nd 04 03:46 PM
Altitude encoder Chad Lemmen Owning 9 August 23rd 03 01:13 AM
